跳转到主内容
iRobot Roomba 692 Battery Replacement
Demi Muyuela
Demi Muyuela 另一个贡献者
最后更新于 May 11, 2023
5分钟
简单
This guide will teach you how to access, remove, and replace your iRobot Roomba 692 battery. If you are replacing the battery, ensure that you have the right battery for the Roomba 692 prior to removal.
Remember to review the iRobot Roomba 692 Troubleshooting Page before attempting any maintenance or repairs on your vacuum.
  1. iRobot Roomba 692 Battery Replacement, Battery: 步骤 1 中的图像 1,3 iRobot Roomba 692 Battery Replacement, Battery: 步骤 1 中的图像 2,3 iRobot Roomba 692 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • To access the iRobot Roomba 692 battery compartment, flip your iRobot Roomba 692 upside down.
    • Using the Phillips #0 screwdriver, remove the 4.0mm screw in the center of the yellow side brush and lift the part out.
  2. iRobot Roomba 692 Battery Replacement: 步骤 2 中的图像 1,3 iRobot Roomba 692 Battery Replacement: 步骤 2 中的图像 2,3 iRobot Roomba 692 Battery Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove the four black 3.5 mm screws on the bottom panel.
    • Remove the bottom panel.
    • Can't find the screws? Refer to the red circles in the Step 1 image.
  3. iRobot Roomba 692 Battery Replacement: 步骤 3 中的图像 1,3 iRobot Roomba 692 Battery Replacement: 步骤 3 中的图像 2,3 iRobot Roomba 692 Battery Replacement: 步骤 3 中的图像 3,3
    • Using the black tabs on both short ends of the battery pack, gently pull the battery up and out of its slot.
结论
另外一个人完成了本指南。
Demi Muyuela
于03/14/23注册
483 声望
创作了5篇指南
团队
UMass Dartmouth, Team 1-4, Shaddix Spring 2023 UMass Dartmouth, Team 1-4, Shaddix Spring 2023 的会员
UMASSD-SHADDIX-S23S1G4
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 28
总计 1,336
