跳转到主内容
iPod Shuffle 2nd Generation Battery Replacement
Andrew Bookholt
Andrew Bookholt7 其他贡献者
最后更新于 June 18, 2024
1 - 2 小时
非常困难
特色指南
Use this guide to replace your Shuffle's battery. Replacing the battery requires a fine-tipped soldering iron and knowledge of surface-mount soldering.
你所需要的
配件
工具
查看更多...
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. iPod Shuffle 2nd Generation Battery Replacement, Logic Board Assembly: 步骤 1 中的图像 1,1
    • Before beginning, be sure your Shuffle is turned off as shown.
    Why is that button green ?!
    Edit : I think he put the button the wrong way.
    Gabriel-Science - 回复
  2. iPod Shuffle 2nd Generation Battery Replacement: 步骤 2 中的图像 1,2 iPod Shuffle 2nd Generation Battery Replacement: 步骤 2 中的图像 2,2
    • Use the edge of an iPod opening tool to pry the plastic cover off the headphone jack side of the Shuffle.
    • Remove the plastic cover and set it aside.
    Make sure to insert the tool right between the plastic cover and the steel cover. If you go too deep, you will pry the steel cover and bend it. The plastic cover is taped to the steel one with some low force glue.
    Tug - 回复
  3. iPod Shuffle 2nd Generation Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the two Phillips screws from the headphone jack side of the Shuffle.
  4. iPod Shuffle 2nd Generation Battery Replacement: 步骤 4 中的图像 1,2 iPod Shuffle 2nd Generation Battery Replacement: 步骤 4 中的图像 2,2
    • Use the edge of an iPod opening tool to remove the steel cover from the headphone jack side of the Shuffle.
  5. iPod Shuffle 2nd Generation Battery Replacement: 步骤 5 中的图像 1,2 iPod Shuffle 2nd Generation Battery Replacement: 步骤 5 中的图像 2,2
    • Use the edge of an iPod opening tool to pry the plastic cover off the controls side of the Shuffle.
    The On-Off switch here is turn around. Usually it is green when the iPod is turned on.
    Nils Kober - 回复
    The plastic cover has small clips at either edge in the middle and alongside the button. Put the iPod opening tool in about a third of the way in from either end to avoid breaking the clips.
    Daniel Foster - 回复
  6. iPod Shuffle 2nd Generation Battery Replacement: 步骤 6 中的图像 1,2 iPod Shuffle 2nd Generation Battery Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to remove the hold and shuffle sliders from the Shuffle.
    Thanks for this great instruction. Little note: Not important for the function, but contrary to the images the green side of the on/off-slider originally must point in the opposite (inner) direction.
    Martin - 回复
  7. iPod Shuffle 2nd Generation Battery Replacement: 步骤 7 中的图像 1,1
    • Remove the two Phillips screws on the controls side of the Shuffle.
  8. iPod Shuffle 2nd Generation Battery Replacement: 步骤 8 中的图像 1,2 iPod Shuffle 2nd Generation Battery Replacement: 步骤 8 中的图像 2,2
    • Use the edge of an iPod opening tool to remove the steel plate from the controls side of the Shuffle.
  9. iPod Shuffle 2nd Generation Battery Replacement: 步骤 9 中的图像 1,1
    • Use the edge of an iPod opening tool to slightly pry the steel plate on the headphone jack side of the Shuffle away from the lip cut into the outer case.
  10. iPod Shuffle 2nd Generation Battery Replacement: 步骤 10 中的图像 1,2 iPod Shuffle 2nd Generation Battery Replacement: 步骤 10 中的图像 2,2
    • Use your iPod opening tool to push the logic board assembly out of the outer case enough to grab the logic board by its edges.
    • Pull the logic board assembly out of the outer case.
  11. iPod Shuffle 2nd Generation Battery Replacement, Battery: 步骤 11 中的图像 1,2 iPod Shuffle 2nd Generation Battery Replacement, Battery: 步骤 11 中的图像 2,2
    在这个步骤中使用的工具:
    • Use the edge of an iPod opening tool to peel the adhesive under the battery that secures it to the logic board.
    • Flip the battery upwards to reveal the solder pads soldered to the logic board.
    • Before desoldering the battery, be sure to scrape the protective resin off both solder points.
    • Desolder the battery from the logic board by heating up the solder joint with a soldering iron and simultaneously using a pair of tweezers to pull the battery wire away from the logic board.
    • Do not touch the + and - leads together.
    • If you have never soldered before, we have a guide that makes it easy.
    Using the Soldering tip to heat the resin covering the Battery Wire Connections will allow easy removal of the Resin Covering Without Damageing the Logic Board with Scraping.
    lloyd193 - 回复
    Battery is Lithium 3.7 volt 100-120 mA dimensions 3mm x 23mm x 23mm
    Search on eBay for 3.7 v 032323
    chi tran - 回复
    How do i know if the battery is faulty?
    jaithish - 回复
    If after leaving the charger plugged into a known good power source overnight and the green indicator light on the shuffle is not lit, there’s a pretty good chance the battery is dead.
    Andrew Lisenby - 回复
结论
78等其他人完成本指南。
20指南评论
Followed your clear instructions and made a successful battery change. It would be helpful to explain that both cover plates are held ond by double sided sticky tape and to give caution on the location of the miniclips on the control cover - I cut through 2 of them by mistake. Thanks for the help.
Regards, Frank, North yorkshire, UK
FrankF - 回复
I rarely find instructions so detailed and foolproof. I ended up with a "new" iPod saving a bunch of money.
Read on about the incidents I encountered.
The working end of the plastic pry tool snapped off rendering it useless, but not before it irreparably bent the pink housing. The suggested screwdriver for which I paid extra did not undo the tiny screws, and I eventually tapped them out with a miniscule eyeglass-repair screwdriver. (Is it a coincidence I did not see a screwdriver in any of the photos?)
Ditto on the suggestion that the super-sticky adhesive presents itself as an obstacle. A suggestion to apply pressure slowly as the adhesive releases would have been helpful.
robinondeck - 回复
I loved that the instructions were really easy to follow. It would be helpful to mention that the logic board ought to be really carefully pushed out. It was difficult in my case and I had to apply a considerable amount of force to slowly push it out.
Despite taking care to control my strength and push it out, part of the protective yellow tape got torn and one of the components was dislodged and broken. It must've been pretty important cuz unfortunately my iPod didn't work after I put it together in one piece. I'm sure the fault lies in my carelessness, the instructions were great. I hope you guys have better luck with yours (:
Jane - 回复
just to add what Frank said: the white plastic control cover has 6 tiny clips; two either side of the sliding switches and two in the middle. I found that gently levering the cover up by inserting the tip of an Xacto blade through the holes the sliders ride in avoids damaging the clips. Be careful not to turn the iPod on when you do this or scratch the green paint next to the on/off slider.
James - 回复
Does anyone have what the best approach to removing the resin from the solder points?
Matt Rausch - 回复
To remove the resin use a Q-tip and some solvent.
Rick - 回复
We followed the instructions, it worked!!
I scraped the epoxy off of the solder points with the end of the #00 screwdriver (using it like a file).
My FIL did the soldering, with a big blunt tip, he's amazing.
Thank you!!
Running Around - 回复
Do you know anyone who will perform this process for me? Also, is it still possible to get batteries for the 2nd generation Ipod shuffles?
burt34 - 回复
Really.. I am thankful to you (Andrew Bookholt), Also it would be more helpful if you mention the link where the original battery will be available.
Senthilvelan K - 回复
Mine had no clips at the plastic control cover because it was glued to the metal stripes with double-sided adhesive tape. It tooks a while until I realized this but I didn't damage something. I used a thin piece of metal, to separate the plastic cover from the metal stripes.
Andreas - 回复
Does anyone know where I can buy a battery for this iPod?
Eva Cruz - 回复
Taking apart didn’t seem too difficult with this instruction and the comments (glued covers). Lets see now for part 2 (getting a replacement battery and soldering) and part 3 ( putting it together).
Pesche B - 回复
Where do you get a replacement battery for a 2nd gen shuffle?
formathe - 回复
Ebay or Amazon. Generic size is 302323 Li-polymer 100mA to 110mA battery. Got mine for $3 each from aliexpress.
Herburger -
I have had success by soaking each end in 99% isopropyl alcohol for a few hours to let it break down the adhesive. That way you won’t break tabs on the switch side.
Also, to remove the resin - you can melt it off with the soldering iron instead of using a metal implement to scrape it off.
Herburger - 回复
Thank you! Seems to have worked OK - charging the new battery now…. - I’ll see if it plays when it’s charged up I used alcohol to ease the sticky tape, as advised by another person on here…. VERY fiddly and I should have used a much smaller soldering iron tip - maybe a thin nail or something. Need good eyesight!.
Peter Quinnell - 回复
Hi, change ipod battery’s is very hard but these instructions are very helpful.
Most harder is desoldering battery because the space between + and - is very little.
thanks a lot
A French guy
Aurélien - 回复
This stops at taking the battery out. Is there nothing about putting a new battery in, and the process of reassembly (and what may be required, e.g. more soldering, epoxy, etc.)?
Phillip Clark - 回复
I was wondering this too. Plan on trying this out once I have all the parts and tools. 🤞
Perpetually Learning -
Excellent tutorial!!!
bernard saucier - 回复
添加评论
浏览统计数据:
过去 24 小时: 34
过去 7 天: 260
过去 30 天: 1,328
总计 212,175
