跳转到主内容
iPhone 8 Plus Lightning Connector Assembly Replacement
你所需要的
  1. iPhone 8 Plus Lightning Connector Assembly Replacement, Pentalobe Screws: 步骤 1 中的图像 1,1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.5 mm pentalobe screws from the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 8 Plus Lightning Connector Assembly Replacement, Mark your opening picks: 步骤 2 中的图像 1,3 iPhone 8 Plus Lightning Connector Assembly Replacement, Mark your opening picks: 步骤 2 中的图像 2,3 iPhone 8 Plus Lightning Connector Assembly Replacement, Mark your opening picks: 步骤 2 中的图像 3,3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. iPhone 8 Plus Lightning Connector Assembly Replacement, Tape over any cracks: 步骤 3 中的图像 1,3 iPhone 8 Plus Lightning Connector Assembly Replacement, Tape over any cracks: 步骤 3 中的图像 2,3 iPhone 8 Plus Lightning Connector Assembly Replacement, Tape over any cracks: 步骤 3 中的图像 3,3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone 8 Plus Lightning Connector Assembly Replacement, Anti-Clamp instructions: 步骤 4 中的图像 1,3 iPhone 8 Plus Lightning Connector Assembly Replacement, Anti-Clamp instructions: 步骤 4 中的图像 2,3 iPhone 8 Plus Lightning Connector Assembly Replacement, Anti-Clamp instructions: 步骤 4 中的图像 3,3
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 5 中的图像 1,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 5 中的图像 2,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 5 中的图像 3,3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 6 中的图像 1,2 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 6 中的图像 2,2
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  7. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 7 中的图像 1,1
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about 90 seconds in order to soften up the adhesive underneath.
  8. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 8 中的图像 1,2 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 8 中的图像 2,2
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
  9. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 9 中的图像 1,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 9 中的图像 2,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 9 中的图像 3,3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick or other thin pry tool a few millimeters into the gap.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  10. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 10 中的图像 1,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 10 中的图像 2,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 10 中的图像 3,3
    • Slide your pick around the corner and up the left edge of the phone, moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
  11. iPhone 8 Plus Lightning Connector Assembly Replacement, Screen information: 步骤 11 中的图像 1,1
    • There's a delicate cable along the right edge of your iPhone. Don't insert your pick here, as you may damage the cable.
  12. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 12 中的图像 1,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 12 中的图像 2,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 12 中的图像 3,3
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
  13. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 13 中的图像 1,1
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
  14. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 14 中的图像 1,1
    • Pull on the small nub on the suction cup to remove it from the front panel.
  15. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 15 中的图像 1,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 15 中的图像 2,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 15 中的图像 3,3
    • Slide an opening pick underneath the display along the top edge of the phone to loosen the last of the adhesive.
  16. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 16 中的图像 1,2 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 16 中的图像 2,2
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
  17. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 17 中的图像 1,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 17 中的图像 2,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 17 中的图像 3,3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • Remove four Phillips (JIS) screws securing the lower display cable bracket to the logic board, of the following lengths:
    • Two 1.3 mm screws
    • One 1.4 mm screw
    • One 2.7 mm screw
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  18. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 19 中的图像 1,1
    • Remove the lower display cable bracket.
  19. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 20 中的图像 1,2 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 20 中的图像 2,2
    • Use the point of a spudger to pry the battery connector up from its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  20. iPhone 8 Plus Lightning Connector Assembly Replacement, Display Assembly: 步骤 21 中的图像 1,2 iPhone 8 Plus Lightning Connector Assembly Replacement, Display Assembly: 步骤 21 中的图像 2,2
    • Use the tip of a spudger or a fingernail to disconnect the large lower display connector by prying it straight up from its socket.
    • To re-attach press connectors like this one, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
  21. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 22 中的图像 1,2 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 22 中的图像 2,2
    • Disconnect the second lower display cable connector, directly behind the one you disconnected in the previous step.
  22. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 23 中的图像 1,2 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 23 中的图像 2,2
    • Remove the two tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
    • One 1.0 mm screw
    • One 1.2 mm screw
  23. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 24 中的图像 1,1
    • Remove the bracket covering the front panel sensor assembly connector.
  24. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 25 中的图像 1,2 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 25 中的图像 2,2
    • Use the tip of a spudger or a fingernail to disconnect the front panel sensor assembly connector from its socket.
  25. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 26 中的图像 1,1
  26. iPhone 8 Plus Lightning Connector Assembly Replacement, Rear-Facing Cameras: 步骤 27 中的图像 1,2 iPhone 8 Plus Lightning Connector Assembly Replacement, Rear-Facing Cameras: 步骤 27 中的图像 2,2
    • Remove the two Y000 screws securing the rear camera connector cover bracket:
    • One 1.4 mm screw
    • One 1.4 mm (nonferrous) screw
    • This screw tends to not be attracted to a magnetized screwdriver. Make sure to reinstall it in the correct place—a magnetized screw may interfere with the compass.
  27. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 28 中的图像 1,1
    • Remove the bracket.
    • Remove the two screws securing the rear camera module cover plate:
    • One 1.8 mm Phillips screw
    • One 2.7 mm (nonferrous) standoff screw
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage nearby components.
  28. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 30 中的图像 1,1
    • Remove the cover plate from the rear camera module.
  29. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 31 中的图像 1,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 31 中的图像 2,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 31 中的图像 3,3
    • Use an iFixit opening tool or a fingernail to disconnect the two camera cable connectors by prying them straight up from their sockets.
  30. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 32 中的图像 1,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 32 中的图像 2,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 32 中的图像 3,3
    • Use the flat end of a spudger to pry up the rear-facing camera assembly from the top edge of the iPhone.
    • If you have trouble, switch to the point of your spudger and lever the camera out from its top right corner.
  31. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 33 中的图像 1,1
    • Remove the rear-facing camera assembly.
  32. iPhone 8 Plus Lightning Connector Assembly Replacement, Top Left Antenna: 步骤 34 中的图像 1,1
    • Remove three Phillips screws securing the upper left antenna component:
    • Two 1.3 mm screws
    • One 3.1 mm screw
  33. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 35 中的图像 1,1
    • Remove the 1.3 mm Phillips screw securing the antenna component to the top edge of the rear case.
  34. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 36 中的图像 1,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 36 中的图像 2,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 36 中的图像 3,3
    • The screw boss at the top of the antenna component is tucked into a small recess in the top edge of the iPhone.
    • Tilt the antenna component up towards the top of the phone.
    • Slide the screw boss down and out of its recess.
  35. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 37 中的图像 1,1
    • Remove the top left antenna component.
  36. iPhone 8 Plus Lightning Connector Assembly Replacement, Wi-Fi Diversity Antenna: 步骤 38 中的图像 1,2 iPhone 8 Plus Lightning Connector Assembly Replacement, Wi-Fi Diversity Antenna: 步骤 38 中的图像 2,2
    • Remove the three screws securing the L-shaped bracket next to the Taptic Engine:
    • One 1.3 mm Y000 screw
    • One 2.6 mm Phillips screw
    • One 3.5 mm Phillips screw
  37. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 39 中的图像 1,1
  38. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 40 中的图像 1,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 40 中的图像 2,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 40 中的图像 3,3
    • Use an opening pick to gently separate the adhered portion of the antenna flex cable from the top surface of the speaker.
    • This portion of the flex cable is lightly adhered in place. If necessary, apply a little heat from an iOpener or hair dryer to soften the adhesive. This makes it easier to separate (and re-adhere) the flex cable safely.
  39. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 41 中的图像 1,2 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 41 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the antenna flex cable from the logic board.
  40. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 42 中的图像 1,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 42 中的图像 2,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 42 中的图像 3,3
    • Use the point of your spudger to pry up and disconnect the other end of the antenna flex cable from its socket, next to the Lightning Port.
    • Reconnecting this cable can be tricky. Make it easier by using your tweezers to hold the flex cable so the connector aligns with its socket. Then, gently press down on the connector with the flat of your spudger until it clicks into place.
  41. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 43 中的图像 1,1
    • Remove the Wi-Fi diversity antenna.
    • Remove the three screws securing the Taptic Engine:
    • Two 1.5 mm Phillips screws
    • One 2.4 mm standoff screw
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  42. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 45 中的图像 1,2 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 45 中的图像 2,2
    • Use the point of your spudger to pry up and disconnect the Taptic Engine flex cable.
  43. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 46 中的图像 1,1
    • Remove the Taptic Engine.
  44. iPhone 8 Plus Lightning Connector Assembly Replacement, SIM Card: 步骤 47 中的图像 1,3 iPhone 8 Plus Lightning Connector Assembly Replacement, SIM Card: 步骤 47 中的图像 2,3 iPhone 8 Plus Lightning Connector Assembly Replacement, SIM Card: 步骤 47 中的图像 3,3
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
    • Press firmly to eject the tray.
  45. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 48 中的图像 1,2 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 48 中的图像 2,2
    • Remove the SIM card tray from the iPhone.
    • The SIM card will fall out of the tray easily.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
    • A thin rubber gasket around the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM tray to protect your iPhone's internal components.
  46. iPhone 8 Plus Lightning Connector Assembly Replacement, Lightning Connector Assembly: 步骤 49 中的图像 1,3 iPhone 8 Plus Lightning Connector Assembly Replacement, Lightning Connector Assembly: 步骤 49 中的图像 2,3 iPhone 8 Plus Lightning Connector Assembly Replacement, Lightning Connector Assembly: 步骤 49 中的图像 3,3
    • Use the point of a spudger to push the SIM card eject plunger out of the logic board's way.
  47. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 50 中的图像 1,1
    • Remove two Phillips screws securing the bracket over the upper cable connector:
    • One 3.1 mm screw
    • One 1.3 mm screw
    • Remember, the longer screw goes on the left.
  48. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 51 中的图像 1,1
    • Remove the upper cable connector bracket.
  49. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 52 中的图像 1,2 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 52 中的图像 2,2
    • Remove the two 1.2 mm Phillips screws securing the grounding clip at the top left edge of the logic board.
  50. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 53 中的图像 1,1
    • Remove the grounding clip.
  51. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 54 中的图像 1,2 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 54 中的图像 2,2
    • Remove the 1.2 mm Phillips screw securing the antenna flex cable to the top edge of the iPhone's rear case.
  52. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 55 中的图像 1,2 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 55 中的图像 2,2
    • Use a fingernail or the sharp end of an iFixit opening tool to pry up and disconnect the antenna flex cable connector from the logic board.
  53. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 56 中的图像 1,2 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 56 中的图像 2,2
    • Slide the flat edge of a spudger underneath the antenna flex cable to separate the adhesive holding it in place.
  54. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 57 中的图像 1,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 57 中的图像 2,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 57 中的图像 3,3
    • The screw boss at the top of the antenna flex cable is tucked into a small recess in the top edge of the iPhone.
    • Tilt the antenna flex cable up toward the top of the iPhone.
    • Remove the antenna flex cable.
  55. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 58 中的图像 1,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 58 中的图像 2,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 58 中的图像 3,3
    • Remove the three Phillips screws securing the lower speaker:
    • Two 1.4 mm screws
    • One 2.4 mm screw
    • During reassembly, press the speaker toward the bottom edge of the iPhone until the screw holes align, and hold it there while you install the screws.
  56. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 59 中的图像 1,1
    • Remove the lower speaker.
  57. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 60 中的图像 1,2 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 60 中的图像 2,2
    • Prying from the top edge, use your fingernail or a spudger to pry up and disconnect the upper cable connector.
  58. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 61 中的图像 1,2 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 61 中的图像 2,2
    • Use the point of a spudger to carefully pry up and disconnect the wireless charging coil's flex cable.
  59. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 62 中的图像 1,2 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 62 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the Lightning connector assembly's flex cable from the logic board.
  60. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 63 中的图像 1,2 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 63 中的图像 2,2
    • Remove the five screws securing the logic board:
    • Two 1.8 mm Phillips screws
    • One 2.3 mm standoff screw
    • One 2.7 mm standoff screw
    • Standoff screws are best removed using an [关联产品丢失或禁用: IF145-343] and driver handle.
  61. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 64 中的图像 1,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 64 中的图像 2,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 64 中的图像 3,3
    • Lift the logic board from the bottom edges and slide it toward the bottom of the iPhone to remove it.
    • Be careful not to snag the logic board on any cables.
    • During reassembly, note the position of the black grounding clip at the top right edge of the logic board, near the rear cameras. The logic board should slide underneath the clip.
  62. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 65 中的图像 1,2 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 65 中的图像 2,2
    • Remove the two Phillips screws securing the barometric vent at the bottom left corner of the iPhone:
    • One 3.2 mm screw
    • One 1.8 mm screw
  63. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 66 中的图像 1,2 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 66 中的图像 2,2
    • Gently push the barometric vent in the direction of the battery to separate the adhesive securing the vent to the bottom edge of the iPhone.
  64. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 67 中的图像 1,1
    • Remove the vent.
  65. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 68 中的图像 1,1
    • Remove the five Phillips screws securing the Lightning connector assembly to the rear case:
    • Two 1.2 mm screws
    • Two 2.4 mm screws
    • One 2.5 mm screw
  66. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 69 中的图像 1,1
    • Remove the two 1.3 mm Phillips screws securing the Lightning port to the bottom edge of the iPhone.
  67. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 70 中的图像 1,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 70 中的图像 2,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 70 中的图像 3,3
    • Use the sharp edge of an iFixit Opening Tool to pry the two microphones free from the adhesive securing them to the lower edge of the iPhone.
    • Don't try to completely remove the microphones; just separate the adhesive as shown.
  68. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 71 中的图像 1,1
    • Apply an iOpener or use a hair dryer to heat the rear case behind the Lightning connector flex cable. This will soften the adhesive securing the flex cable, making it easier to separate.
  69. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 72 中的图像 1,1
    • Use the flat edge of a spudger to gently fold the battery flex cable connector away from the upper portion of the Lightning connector assembly.
    • In the following steps, as you separate the Lightning connector assembly, be careful not to accidentally damage the battery flex cable.
  70. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 73 中的图像 1,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 73 中的图像 2,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 73 中的图像 3,3
    • Slide an opening pick or thin pry tool underneath the top portion of the Lightning connector assembly flex cable.
    • Gently slide the pick toward the outside edge of the iPhone (away from the battery).
    • Part of the wireless charging coil lies directly underneath this portion of the Lightning connector flex cable. Aggressive prying may damage the coil.
    • If needed, use your hair dryer or iOpener repeatedly to re-heat the area behind the Lightning connector assembly flex cable in order to make it easier to separate.
  71. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 74 中的图像 1,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 74 中的图像 2,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 74 中的图像 3,3
    • Continue separating the upper portion of the Lightning connector flex cable, being careful not to damage any other components along the way.
    • Keep the battery connector gently folded to the side so as not to damage it.
    • Be very careful not to damage the battery itself. A punctured battery can leak dangerous chemicals and/or catch fire.
  72. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 75 中的图像 1,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 75 中的图像 2,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 75 中的图像 3,3
    • Continue separating the Lightning connector assembly's flex cable until you pass the lower edge of the battery.
  73. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 76 中的图像 1,2 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 76 中的图像 2,2
    • Carefully slide your pick from the corner of the battery to the corner of the iPhone to separate the portion of the flex cable adhered to the outer frame.
  74. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 77 中的图像 1,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 77 中的图像 2,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 77 中的图像 3,3
    • Slide your pick across the width of the iPhone to separate all the remaining areas of the Lightning connector assembly from the rear case.
  75. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 78 中的图像 1,2 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 78 中的图像 2,2
    • Remove the Lightning connector assembly.
    • Before installing or replacing the Lightning connector assembly:
    • Use a plastic tool to scour any bits of adhesive residue from the rear case.
    • Thoroughly clean any remaining residue from the surface with isopropyl alcohol (90% concentration or greater) and a lint-free cloth. Wipe in one direction only, not back and forth.
  76. iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 79 中的图像 1,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 79 中的图像 2,3 iPhone 8 Plus Lightning Connector Assembly Replacement: 步骤 79 中的图像 3,3
    • A rubber gasket on the bottom of the Lightning connector protects your iPhone from liquid and dust intrusion. If you are installing a new Lightning connector assembly, you may need to carefully remove and transfer the gasket to the new part.
    • The small adhesive patch on the bottom of each microphone also protects your iPhone from liquid and dust intrusion. For best results, replace the two adhesive patches before installing your Lightning connector assembly.
    • Important: During installation, correctly position your new Lightning connector assembly so that the cutouts in the cable are exactly centered around the four screw bosses in the rear case. Otherwise, the flex cable will be misaligned and you won't be able to reconnect it to its socket on the logic board.
结论
73等其他人完成本指南。
Jeff Suovanen
于08/06/13注册
422,204 声望
创作了259篇指南
团队
iFixit iFixit 的会员
Staff
140 名成员
创作了15,214篇指南
16条评论
40 minutes seems crazy fast for this repair. If anyone can do this entire repair from beginning to end utilizing these steps in 40 minutes… they should spend a day or two practicing the Rubik’s cube and go smash the world record.
The guide helped me accomplish the repair. So, for that, thank you very much.
andystills - 回复
Very well done and easy to follow. Great piece of work and I appreciate the time spent putting it all together.
Have repaired 2 other iPhones, 6 and 6S, using the guides found here. When confronted with the iPhone 8 plus repair this is the site I came to.
Again, very well done indeed.
Kudos
Rick W - 回复
Where dose one find a new gasket for the lighting cable?
Joshua spaulding - 回复
You will not find a more comprehensive or thorough or accurate guide to dismantling and replacing the charging port on an iPhone 8 Plus than this. Awesome guide, thanks for your attention to detail and thoroughness! Bravo!
Will White - 回复
Thank you very much for the very detailed repair instructions. My microphone wasn’t working properly and I was able to get it fixed for just $12! (got the replacement from eBay)
Vishvaka Ranasinghe - 回复
添加评论
浏览统计数据:
过去 24 小时: 38
过去 7 天: 261
过去 30 天: 1,058
总计 100,058
