简介
此指南会教导你如何更换变形或是受损的后盖, 或是其他外观所造成的问题。由于后盖上覆盖许多零组件, 因此, 若要更换后盖, 就必须将上面的零组件全部拆卸下来。
若要更换上面的零组件, 你也可以参考以下的维修指南。
- Loudspeaker Mount
- Microphone Mount
- Front Panel Clips
工具
卸下电池排线固定架上的2颗十字 #00 螺丝。
1颗2.9 mm螺丝
1颗2.2 mm螺丝
如要组装的话, 请按逆序操作一下步骤。
如要组装的话, 请按逆序操作一下步骤。
77等其他人完成本指南。
特别感谢这些译者︰
100%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
8条评论
I can't get the phillips 000 screw out on step 52, now it's become too hollow within to open. What do I do?
Stripped screws are the worst! We have a guide on how to remove stripped screws that you may find helpful. Remember to maintain lots of pressure on the screw and stop applying force and try a different method if the bit is still slipping.
Every thing works fine except I have no sound, either on speakerphone or normally. Did I break the upper component cable? I've checked all the plug connections and they seem ok.
I have no sound at all from the normal speaker or in speakerphone mode. I have good cellular and Wi-Fi connections and the phone sees to work perfectly otherwise. The battery charges fine through the Lightning connector. Can't use it as a phone though! Did I break the upper component cable in the disassembly? Any other ideas?
