跳转到主内容
iPhone 6 Plus 逻辑主板更换
你所需要的
  1. iPhone 6 Plus 逻辑主板更换, 五角螺丝: 步骤 1 中的图像 1,1
    • 在拆卸前,请确保您的iPhone 电池电量在25%以下。充满电的锂离子电池如果意外刺破,可能会引起火灾和/或爆炸。
    • 在开始拆卸之前请把iPhone关机。
    • 移除lightning接口两边的2颗3.6mm P2五角螺丝。
    I prefer to remove the SIM card as the very first step since it's safer to do so while the phone is fully assembled.
    estebanfallasf - 回复
    I stripped one of the two screws - at a dead stop.
    Margaret Patterson - 回复
    Before you even start: get the iOpener or hairdryer out. You’ll need it
    GPZ - 回复
    If a lightning connector won’t provide a charge or needs to be wiggled carefully to provide a charge, power off the device, then try using precision tweezers to scrape the innermost wall of the lightning jack in a pinching motion to check for lint buildup. Pocket lint or other debris can accumulate inside the jack, compacting each time a cable is inserted. This can prevent a lightning cable from seating fully. Clearing the lint may restore functionality without replacing the part.
    Andrew Dolan - 回复
    A few hints:
    * heating up the phone works great. I used a heating pad that you put in the microwave to heat sports injuries.
    * also, I made a sheet to help you keep track of the screws as you remove them. Print out the page, then place double sided tape below each color-coded listing of screws, and stick the screws to the tape as you disassemble. This helps prevent losing the screws and keeps track of what screws are what for easier reassembly. https://drive.google.com/file/d/1pLSvKvB...
    Paul Faulstich - 回复
    Additional hints, for anyone who needs them:
    * stick the screws to the tape in the same positions as they are shown in the guide. This will make it easier to identify them during reassembly.
    * if the screws get mixed together, the ‘mm’ (millimetre, millimeter) measurements given in the guide can be used to identify them. Compare the lengths of the threaded shafts to each other to determine which screw is which.
    Friendly Advice -
  2. iPhone 6 Plus 逻辑主板更换, 反向钳使用指南: 步骤 2 中的图像 1,3 iPhone 6 Plus 逻辑主板更换, 反向钳使用指南: 步骤 2 中的图像 2,3 iPhone 6 Plus 逻辑主板更换, 反向钳使用指南: 步骤 2 中的图像 3,3
    • 接下来的两个步骤演示了如何使用反向钳,一个旨在简化打开过程的工具。 如果你不使用 反向钳,请跳过这两个步骤以使用替代方法。
    • 有关如何使用 反向钳的完整说明,请查看本指南
    • 将蓝色手柄拉向铰链以解锁反向钳的手臂。
    • 将反向钳手臂滑过 iPhone 的左边缘或右边缘。
    • 将吸盘放在靠近 iPhone 底部边缘的位置——一个在正面,一个在背面。
    • 向下推吸盘以将吸力施加到所需区域。
    • 如果发现设备表面太光滑而反向钳无法吸住,请使用包装胶带来创造一个更容易抓握的表面。
  3. iPhone 6 Plus 逻辑主板更换: 步骤 3 中的图像 1,3 iPhone 6 Plus 逻辑主板更换: 步骤 3 中的图像 2,3 iPhone 6 Plus 逻辑主板更换: 步骤 3 中的图像 3,3
    • 将蓝色手柄向前拉,以锁定双臂。
    • 顺时针旋转手柄 360 度,直到吸盘开始拉伸。
    • 确保吸盘 保持相互对齐。如果它们开始滑出对齐位置,请稍微松开吸盘,然后重新对齐支臂。
    • 当反向钳创造出足够大的间隙时,将撬片插入屏幕下方。
    • 如果反向钳没有创造出足够的间隙,则对该区域施加更多的热量,并将手柄旋转四分之一圈。
    • 每次转动不要超过四分之一圈,每圈之间要等一分钟。让反向钳和时间为你工作。
    • 跳过下边两个步骤
    Use clear nontextured tape place that over the phone screen. Refer to any guide that addresses replacing a shattered screen
    Abigail Cherry - 回复
    I know it's tough with cracked glass. You just need enough to get in a plstic pry tool or guitar pick. Then you can pry it apart. Just be patient, I cannot stress that enough; the electronics are very, very small and fragile.
    Mike - 回复
  4. iPhone 6 Plus 逻辑主板更换, 前面板组件: 步骤 4 中的图像 1,1
    • 如果你没有 iSclack,使用单个吸盘来打开前面板:
    • 把吸盘放到屏幕上,正好在 home 键上面一点。
    • 确保吸盘和屏幕吸得很紧。
    Avec la ventouse, l’ouverture est brutale, tout s’est déclipsé d’un seul coup. Faire attention.
    Paul Briffaut - 回复
    English Please!
    tom mozeleski -
    With the sucker, the opening is brutal, everything was cleared at once. Pay attention. (Paul’s comment translated by Google)
    Steve Schlotter - 回复
    May need to burp the sticker before it sticks. Need to let the air out. Once Idid that, no problem. Except it was still hard to get the cover to start up.
    Patricia Tucker - 回复
    Don’t waste your time with the suction cup - it doesn’t work! insert the blade of a box cutter just below the lower screen edge below the home button and gently pry just enough to start cracking the seal.
    Stephen Smith - 回复
  5. iPhone 6 Plus 逻辑主板更换: 步骤 5 中的图像 1,1
    • 一只手把 iPhone 按下的同时,把吸盘轻轻地往上拉,使前面板组件和后机壳分离。
    • 慢慢来,使用恒定的力量。显示屏组件比大多数的设备都要紧。
    • 使用塑料撬棒,开始轻轻地把后机壳撬下来,在这个过程中继续拉吸盘。
    • 前面板组件和后机壳有几个夹扣连接,所以你需要使用吸盘和撬棒工具组合。
    Be extra careful here. If you don’t take your time, your front panel may jerk back on you, causing you to overextend and break the front camera/mic flex cable; happened to me. Slowly peel back the front panel, opening it no more than 90º.
    Thomas - 回复
    watch out for the left side of the phone the adhesive bunches up around the inner clips, i didn’t realize it and the upper left of my screen cracked pretty bad. But this guide is awesome follow every direction to the letter
    Aaron Fitzpatrick - 回复
    Note: this comment is written for the iPhone 6 Plus, but may also apply to other models of iPhone.
    Disassembly:
    The clips in the rear case attach to small slotted shapes under the edges of the display assembly, and these attachment points alternate from one side to the other. Moving from bottom to top, gently pulling the rear case away at these points will help to separate the two halves without using too much force.
    Reassembly:
    Ensure that the plastic clips along the top edge of the front panel (shown in step 8) are fitted properly inside the rear case, then gently press the display assembly into the rear case at these points, moving from top to bottom. There may be a small click sound as the clips in the rear case engage with the slots on the display assembly, and the rear case should fit flush with the edges of the display assembly.
    Friendly Advice - 回复
    This was challenging. For me, the suction cup could only create a tiny bit of motion and at first, no actual gap at all. You might have to pull the suction cup away from the base a few times just to loosen things up a tiny bit. Eventually, I got my fingernail in, and then after a few minutes got the plastic tool in.
    Also, use the plastic tool to gently pry along the sides of the phone once there’s light there. I was afraid of using too much leverage and breaking the screen as per the other comments, but starting at the bottom and then going around the sides slowly worked for me.
    FixingMyiPhone - 回复
  6. iPhone 6 Plus 逻辑主板更换: 步骤 6 中的图像 1,2 iPhone 6 Plus 逻辑主板更换: 步骤 6 中的图像 2,2
    • 拉住吸盘上的塑料凸起,破坏真空环境。
    • 把吸盘从显示屏组件上移除。
    There is an adhesive strip all along the edge between the top and bottom of the phone. Is that just adhesive or is it wire of some sort?
    Larry Ingerling - 回复
    @lingerling The adhesive strip was introduced on the iPhone 6s and 6s Plus (one model year later than what’s shown on this page). Guides specific to each model can be found here—be sure to use the correct one for your particular phone. And yes, just adhesive, no wires. ;)
    Jeff Suovanen - 回复
  7. iPhone 6 Plus 逻辑主板更换: 步骤 7 中的图像 1,3 iPhone 6 Plus 逻辑主板更换: 步骤 7 中的图像 2,3 iPhone 6 Plus 逻辑主板更换: 步骤 7 中的图像 3,3
    • 拉起 home 键一端的前面板组件,以手机顶端为轴。
    • 把显示屏打开到角度为 90º ,把它如图所示靠在某物上。
    • 使用橡皮筋把显示屏固定在盒子上。这可以避免对显示屏电线不必要的拉扯。
    • 如果手边找不到合适的物品,你也可以用没打开的易拉罐来固定。
    Be careful If we leave the screen connected and set it to 90 degrees, the speaker / sensor flex may break. With an opening of 60 degrees it is convenient to completely disconnect the screen. The headset's flex is short, and if we put it at 90º, it can break. Guiding me from the images of iFixit, I have broken two cables.
    Español:
    Cuidado. Si dejamos la pantalla conectada y lo ponemos a 90 grados, el flex del altavoz/sensor puede romperse. Con una abertura de 60 grados es conveniente desconectar enteramente la pantalla. El flex del auricular es corto, y si lo ponemos en 90º , se puede romper. Guiándome de las imágenes de iFixit, se me han roto dos cables.
    txaukos - 回复
    At 60º the display will block access to all the screws and the phone would be practically unserviceable, so I’m having trouble making sense of this comment. The cables on a factory original display are pretty tough and designed with enough slack that a 90º angle is no problem. Same with any decent aftermarket display.
    Jeff Suovanen - 回复
    If you look at the enlarged image, you can see how the flex cable from the camera / speaker is in tension. This is my opinion. Sorry for my bad English
    Si usted se fija en la imagen ampliada, puede ver cómo el flex cable de la cámara/altavoz está en tensión. Esta es mi opinión.
    Perdón por mi mal inglés
    txaukos - 回复
    your English isn’t the issue, it’s the proposed 60 degree opening space that doesn’t allow for the removal of the screws of the mounting plate where the connectors connect to the main pcb…
    if can make a recommendation here; it helps if the can is full and not refrigerated, the weight helps in keeping the phone where it should stay without adding additional tension to the ‘flex’ ribbon cable. it’s called flex for a reason people, if your breaking these the phones already been overheated too much, the cables become brittle and should also be replaced. i replaced my battery without disconnecting the screen, at 90 degrees with a rubber band around an empty beer can. pierced the orig. battery and caused sparks. albeit, i wasn’t in a hurry and it took me a good 30+ minutes, removal of the battery and stickers is by far the most challenging, especially when NOT disconnecting the screen…
    it’s not a race, take your time. move slowly but precisely with forethought and persistent force…
    circuitbender 477 - 回复
    Werkt dit ook voor iPhone 7(plus)?
    Christina Pegtel - 回复
    Werkt dit hetzelfde voor iPhone 7 (plus)?
  8. iPhone 6 Plus 逻辑主板更换: 步骤 8 中的图像 1,2 iPhone 6 Plus 逻辑主板更换: 步骤 8 中的图像 2,2
    • 在手机顶端有几个夹扣,显示屏可以像书一样翻动。
    • 在组装过程中,把夹扣对齐后机壳顶部边缘。然后滑动前面板和后机壳扣上。
    I would recommend protecting the screen once the display is free and the suction cup has been removed. This will help avoid any possibility of accidental scratching of the display crystal while the remaining steps are being performed. I used an inexpensive screen protector then removed it after reassembling and testing are complete.
    anthonyspampinato - 回复
  9. iPhone 6 Plus 逻辑主板更换: 步骤 9 中的图像 1,1
    • 将以下00号十字螺丝从电源接口盖移除
    • 一个2.3 mm长的00号十字螺丝
    • 一个3.1 mm长的00号十字螺丝
    for the iPhone 6 Plus, all screws were Phillips #000
    Michael Adams - 回复
    I had difficulty removing the 3.1mm (iPhone 6 Plus / Phillips #000); had to give it significant downward pressure to get it started.
    Allen Matheson - 回复
    stripped the 2.3mm screw attempting to remove, had to use excessive force to successfully remove
    Matthew Gao - 回复
    The Phillips bits provided in the kit would not engage the Phillips heads enough to loosen them. Luckily I had my own small screwdriver set that worked like a charm.
    David Davis - 回复
    Same issue. Could not remove the screw. Dead in the water.
    Tiffany - 回复
    Agree with above comments regarding the supplied Phillips bit. It is not the correct size.
    Use a Phillips #000.
    bobgottner - 回复
    Phillips #000 is what’s included in the kit. As others mentioned above, firm downward pressure is key. The phone is not that delicate; just press hard and crank it.
    Jeff Suovanen -
    Is this step necessary ?\
    Asianay - 回复
    @asianay0129 Yes, disconnecting the battery is necessary. You can sometimes get away with skipping it, at the risk of destroying something important and potentially bricking your phone. Not a wise gamble for the sake of skipping two screws.
    Jeff Suovanen - 回复
  10. iPhone 6 Plus 逻辑主板更换: 步骤 10 中的图像 1,1
    • 将电源接口的金属盖从iPhone中移除
    Was not able to remove the battery connector bracket as one of the cable connectors was glued/stuck to the underside. Instead moved the bracket out of the way to disconnect the battery. Care should be taken not to over bend/stretch the ribbon cable.
    dwtan - 回复
    That may be just the foam connector adhering to the bracket. If you pull up gently and twist slightly it should separate.
    Evan Noronha -
    It was the foam connector, and it did twist free with a gentle pull
    Al Taylor - 回复
  11. iPhone 6 Plus 逻辑主板更换: 步骤 11 中的图像 1,1
    • 用塑料撬棍从主板上撬下电池排线的接头。
    • 注意只在排线接口上用力,不要伤到主板上的接口插座。如果你撬到了接口插座,你可能会直接把接口弄坏。
    you may consider placing a thin non-conductive item between the connector and the socket like a bit of rubber band to prevent any power flowing during this procedure
    Michael Adams - 回复
    It was too close to other parts to pry up with either end of plastic tool. Finally used 1 tine of tweezer to lift edge. Came free easily
    Al Taylor - 回复
    J’ai pris une loupe pour bien observer l’endroit où placer l’outil.
    Paul Briffaut - 回复
    Magnification is key for many tasks and this is certainly one.
    Kenneth Gilbert - 回复
    I couldn’t use the iFixit blue opening tool to pry that battery connector. I used the top of the black spudger near the hole where the 3.1mm screw was in step 9-10 to easily pry it open!
    Alyssa Sayuki - 回复
    The blue plastic board breaker can easily cause damage here. Professionals would recommend using the human fingernail as the ideal tool for this job.
    Jessa Jones - 回复
  12. iPhone 6 Plus 逻辑主板更换: 步骤 12 中的图像 1,1
    • 保持前面板张开立起约90度,卸下前面板排线固定板上的五颗Phillips螺丝。
    • 三颗1.2 mm螺丝
    • 一颗1.7 mm螺丝
    • 一颗3.1mm螺丝
    There's an other panel with one screw in the middle.........
    Herbert - 回复
    Sounds like you have an iPhone 6s Plus, rather than a 6 Plus. Be sure to use the correct guide! And make sure you’ve ordered the correct part, as they’re not cross-compatible.
    Jeff Suovanen -
    I _love_ the color coding of screws. I know this is a little OCD, but it would be incredibly useful if there were an 8.5 X 11 you could print with indicated homes for where to drop items from each step of disassembly. That is, in the box for step 9, little colored circles for where to place each screw type. As long as you don't jostle the paper, it would make it a lot easier to know exactly where you are in reassembly.
    cscarlson47shop - 回复
    I have done the exact same thing. Created a sheet where each screw goes.
    Chris Murphy -
    I used the 000 bit from the ifixit 54 piece kit.
    hhandh - 回复
    Actually you don’t need to do steps 12 to 18 if you attach the display panel to the iPhone box as shown in step 7 and handle your iPhone with care during the replacement. I didn’t disconnect the display panel mainly because the more you work on the interior of your phone the higher is the chance you break something.
    Dany Castillo - 回复
    Since this guide is for DISPLAY replacement, I don’t see how you can skip the steps for disconnecting and removing the DISPLAY.
    Jim Bateman -
    That's what I was thinking.
    The Wizard - 回复
    I skipped this series of steps too. I was very careful when removing the battery and never had an issue with the screen leaning back against the box that this battery shipped in. I even broke half of the third strip of adhesive but used a plastic card to slide under the battery and it slowly lifted out without applying heat.
    mark - 回复
    I'm having trouble with one screw not wanting to come out. Any suggestions to keep from stripping the head and getting it?
    Patric - 回复
    which screws are which sizes cause i ordered new ones and cant figure it out
    MONsterHEIT - 回复
    I also did not see the need to remove the display assembly for this repair. However I did place a can of corn against the vertically positioned display and then secured the display to the can with a rubber band.
    whiteshephard - 回复
    I recommend removing the display assembly, I didn’t and somehow damaged the home button cable. At least remove the cover to ease the tension on the cables.
    I played around with different screwdrivers to get certain screws out. I made sure I wasn’t applying heavy pressure so I wouldn’t strip the head. Apple is crazy for doing this to us lol.
    Anyways invest in a magnetized mat to organize your screws. It was really difficult to keep things organized and still, especially with these tiny screws…
    Jeffrey Robinos - 回复
    what happens if i forgot to put the ribbon cable shield back on? the phone is now working but i forgot to put the shield back on and i am missing 2 screws. can i leave the shield off?
    Fred ticoman. - 回复
    @ticoman12 It’ll work without the shield, but the connectors may pop out unexpectedly.
    Jeff Suovanen -
    Just be really careful remembering which screw is which. I drew a quick sketch of the bracket, then put the screws in the relevant places. There’s no way I would have been able to figure them out otherwise - my eyes can’t see the difference between a 1.2 and 1.5mm screw!
    Paul Johnson - 回复
    The most fiddly part of the job.
    Much easier if you put the screwdriver head on the screw and then insert it into the opening. The slight magnetism will hold it in place. Don’t fully tighten a screw until all the screws are in place. Much like installing lug nuts on a car.
    GPZ - 回复
    I also skipped steps 12-18 as Danny had suggested. It made this repair quite easy, so thank you and others for suggesting this. I was also very careful to allow the battery to discharge before starting the process.
    Bruce Platt - 回复
    I question whether Steps 12-18 (separating the display from the case) is actually necessary? The battery can be removed/replaced with the display connected (but standing upright, as displayed in Step 7.
    Leaving the display attached obviates the most difficult steps (re-connecting the various control ribbons — 3/4 of ‘em!
    I followed this manual completely and the repair was successful. But if I had this to do over, I’d leave the display connected.
    Dana Smith - 回复
    I skipped the steps 12-18 as well and thank goodness I did so I won’t have to worry about issues with any of the cables.
    my panel is different from what is pictured anyway ‘cause I have one screw in the middle like what Herbert said on the first comment.
    Maria Filamor-Robinson - 回复
    I realized too late just how handy the magnetic mat is that they have in their shop. So I organized the screws with a piece of clear packing tape. On the smooth side, use a sharpie to draw spacious circles with “R” “O” and “Y” inside each circle to represent the color coded screws and then use the sticky side to keep the screws in place. I found that using the tweezers to take them off the screwdriver helps you stick them head first to the tape better.
    Selena Castillo - 回复
  13. iPhone 6 Plus 逻辑主板更换: 步骤 13 中的图像 1,1
    • 从主板上取下前面板排线固定板。
  14. iPhone 6 Plus 逻辑主板更换: 步骤 14 中的图像 1,2 iPhone 6 Plus 逻辑主板更换: 步骤 14 中的图像 2,2
    • 在接下来的四个步骤中,使用撬棒时注意只撬排线接口,而不是接口插座。
    • 使用撬棒的平头断开前摄像头和传感器排线接口。
    Why does the screen need to come off?
    Sterling Coffey (N0SSC) - 回复
    Because the cables are delicate, and following steps are easier if phone halves are not flopping around together, especially for amateurs.
    Matthew Goheen - 回复
    I don't know if anyone will see this but here it goes: for the life of me I can't get the front-facing camera and earpiece speaker connector to seat. Everything else went back together fine but this one connector will not go in. Sometimes it seems like it's in even though it doesn't really pop in and it'll kinda sit there for a sec and then it pops out.
    Any insight would be greatly appreciated, thank you
    Droopy Caledonia - 回复
    Try starting at one end instead of in the middle. It's to easy to bend a connector and this way, I can get a safe start and go from there.
    Rongwey - 回复
  15. iPhone 6 Plus 逻辑主板更换: 步骤 15 中的图像 1,2 iPhone 6 Plus 逻辑主板更换: 步骤 15 中的图像 2,2
    • 用撬棍的平头断开Home键排线接口。
  16. iPhone 6 Plus 逻辑主板更换: 步骤 16 中的图像 1,2 iPhone 6 Plus 逻辑主板更换: 步骤 16 中的图像 2,2
    • 用撬棒的平头断开显示排线接口。
    • 重新组装手机时,显示排线可能会从插座上松动,这回导致重开机时屏幕显示白线或者直接白屏。如果出现这种情况,只需再次装好排线并将手机电源重置一次。重置手机电源最好的方式就是将电池排线断开再装上
    The piece of advice about power cycling the phone by disconnecting and reconnecting the battery proved crucial to the success of my repair (camera and lens replacement). At first when charging the phone after closing it, I got a dark, blank screen with an intermittent buzzing noise. After re-opening the phone and making sure all cables had been properly reconnected, I ignored the advice to power cycle the phone. Still all I got was a dark, blank screen (and intermittent buzzing if charging t). Then I opened it a third time (leaving the screen connected and attached at a 90 degree angle) and I only disconnected and reconnected the battery. Voila! When I closed the phone and powered it up, I got the screen to light up!
    Gianni - 回复
    how did you disconnect and reconnect the battery?
    Teresa Trevino - 回复
    If you’ve been following the guide, you already disconnected it in this step. To reconnect it, just line up the connector and press it into place.
    Jeff Suovanen -
    After replacing the battery, the phone seems dead. I thought it just needed recharging so I left it charging all night. Still dead in the morning. Now I think it might be because the display data cable is off, and I should open the phone and check it. But the battery might be on full power in that case, and they don’t advice to open the phone when battery if full. What can I do?
    Ila Awasthi - 回复
    The advice aims at avoiding battery fire. Just be careful.
    Katherine Williams - 回复
  17. iPhone 6 Plus 逻辑主板更换: 步骤 17 中的图像 1,2 iPhone 6 Plus 逻辑主板更换: 步骤 17 中的图像 2,2
    • 用撬棒的平头断开触摸层排线接头。
    • 当你要组装触摸层排线时, 请不要按压接头的中间地方。按压接头的一端, 接着再按压另一端。因为若是按压接头中间时, 有可能造成触摸层变形损坏。
    some images and guidance regarding reassembly would be helpful. You don't need to use the spudger to get them back on: fingers are better because there's a really subtle click you feel when you get them seated properly.
    When you're reassembling, a note that this is the step where you should test for proper screen function would be really useful. First time I reassembled, I didn't seat something properly, got all the screws back together and then realized the screen wasn't functioning properly. Had to disassemble back down to step 14 and then re-reassemble.
    I am having this issues right now! I have unplugged and plugged in these cables at least 20 times and each time I get white lines. I finally have it to where there are only 4 white lines and I am almost willing to live with it. Any suggestions?
    mattmay002 -
    Clean the screen connectors incase they are not making a clean connection
    Karen Jones - 回复
    I'm having nightmares with the digitizer connector. Simply can't get it to work unless I'm applying some pressure on the connectors. Everything seems almost microscopically clean. Any suggestions friends?
    Henry A -
    could it be the replacement screen? test with your old screen and see if you have the same problem.
    Charles - 回复
    To ++mattmay002++  Did you power cycle the phone? Check out the comments on the previous step for a how to.
    Robert Liles - 回复
    I had issues with it too. When connecting this cable, make sure to rock finger side to side after connecting. It’s a wide connector so try to listen for 2 clicks on this one connector. That’s how I fixed mine
    Albert Einstein - 回复
    Re-attaching this cable is the only tricky part to replacing the battery on my 6+. It had a bow on the middle that I had to flatten out before pressing the connector on with finger first on one edge and then on the other. I had white tire tracks on the screen and no touch screen until I connected it correctly. The front has to rest in just the right place on the back while attaching this thing so the cables aren’t strained the front doesn’t fall down. Small fingers would be a plus at this step.
    richard - 回复
    Reseating these connectors on reassembly is definitely the most difficult part of this repair. It took me several attempts before the lowermost connector would seat properly and I did accidentally bend it slightly in the process. Fortunately I was able to get it straight again and get it to click in. The other three went in fine though and no lasting damage seems to have been done.
    Andy Gibbons - 回复
    Another thing - These cables can become overlapped in the wrong way and make you think they are in a different order than they should be. Eg. it’s easy to mix up the ones from step 15 and 17. You can actually unravel the cables and re-layer them on top of each other in any order, so remember this! They look like they’re one solid mass but they’re not.
    domarius - 回复
    I never removed the last digitizer connctor. I removed the first three connectors, left the screen propped at 90 deg tied to a box and removed the battery, there is minimal movement. In fact when I reattached the connectors, only the first and maybe second connector feels taut, so it’s necessary to only remove the first connector if you can be gentle with it. Less headache. And my guess why so many people had issues is that micro dust gets into the connectors and cause connection loss. You be surprised how little dust can cause havoc.
    darrcc - 回复
    And forgot one thing, keep a can of air duster woth you to remove as must dust as you can see. A camera air blower will also do nice.
    darrcc - 回复
    I haven’t removed my screen in past battery replacements, I found it easier. However, this time I followed the instructions because my old battery was very stuck, and I needed the screen gone to get the battery out…
    When I replaced the screen, at first it wouldn’t even boot/start up. (Yes, I inserted my own testing step, as someone here suggested, before final reassembly).
    The screen would just show a fuzzy image, and the board that all the cables attach to would heat up, then it would turn itself off. I tried reconnecting them carefully 3 times, and even made sure to get a little “click”, all to no avail.
    The final try, I used my fingernail to really press down on the back side of the digitizer cable. I heard more clicking, though I thought I might be tearing the cable too. With nothing left to lose, I continued across the back, and heard several more clicking/tearing sounds.
    This worked, and it booted after that. It still had white lines, but those faded away overnight.
    Morgan Giddings - 回复
    About the digitizer connector: its flat cable is so short that the when I attempted to seat the next connector, its flat cable pressed on the digitizer cable, which can pull on the connector and dislodge it. That happened several times for me before success.
    Robert Bernard 27 Nov 19
    Robert H Bernard - 回复
    Nous n’apercevons pas bien les nappes et l’ordre dans lesquelles elles doivent être replacer
    Patrick AZOULAY - 回复
  18. iPhone 6 Plus 逻辑主板更换: 步骤 18 中的图像 1,1
    • 此时,前面板可以彻底与机身分离了。
    Never remove the screen without disconnecting the battery. It's possible the back light can be blown and that's a even more difficult repair. Always, ALWAYS, disconnect battery before repairing items. (Unless it's not possible.)
    Marvin Ballard - 回复
    How do you disconnect the battery from the screen?
    Shamil Bhatti -
    The Step 11 disconnects the battery :)
    jeffxtechs - 回复
    I think you mean Step 8 :)
    Jeff Suovanen -
    I tried it once and
    Brian - 回复
    And what? I tried it once and here’s a million dollars?
    Oh I get it… they got him! :(
    https://www.youtube.com/watch?v=UlznqpBg...
    domarius -
    When disassembling the iphone at this point note the cables, and there placement/orientation.
    GERARD SZAREK - 回复
    Be really careful with the step after this. Do not commence until you have read all the comments. You need to get a good hold of the plastic strips preferably before they double over on themselves. You have to avoid puncturing the battery at all costs. Slowness and caution here will save you a lot of long term pain.
    Laura Houghton - 回复
  19. iPhone 6 Plus 逻辑主板更换, 5G WiFi天线: 步骤 19 中的图像 1,1
    • 取下固定天线 铁片的螺丝。
    • 一颗1.5mm的飞利浦00号螺丝。
    • 一颗2.8mm的飞利浦00号螺丝。
    This is not the top cellular antenna.
    Tom Chai - 回复
  20. iPhone 6 Plus 逻辑主板更换: 步骤 20 中的图像 1,1
    • 用镊子夹住 5G WiFi 天线的固定片并取下来。
  21. iPhone 6 Plus 逻辑主板更换: 步骤 21 中的图像 1,1
    • 用塑料撬棒小心取下连在主板上的5G WiFi天线。
  22. iPhone 6 Plus 逻辑主板更换: 步骤 22 中的图像 1,2 iPhone 6 Plus 逻辑主板更换: 步骤 22 中的图像 2,2
    • 用镊子夹住5G WiFi天线排线并轻轻使其从 主板的固定扣中分离出来。
  23. iPhone 6 Plus 逻辑主板更换: 步骤 23 中的图像 1,2 iPhone 6 Plus 逻辑主板更换: 步骤 23 中的图像 2,2
    • 这两个排线也许是黏在一起的。如果是这样,就应该成对一起取下。
    • 拨开主板上的电池排线和音频排线。
    Is this cable connector replaceable? I seem to have misplaced it when putting the phone back together. Actually don’t remember taking it out, but must have.
    vansan - 回复
  24. iPhone 6 Plus 逻辑主板更换: 步骤 24 中的图像 1,1
    • 取下拧紧在后壳上固定5G WiFi天线的螺丝。
    • 一颗2.8mm的飞利浦00号螺丝
    • 两颗1.6mm的飞利浦00号螺丝
    One of the two 1.6 mm screws is covered by a black sticker fwi
    Dirk Gunderson - 回复
  25. iPhone 6 Plus 逻辑主板更换: 步骤 25 中的图像 1,2 iPhone 6 Plus 逻辑主板更换: 步骤 25 中的图像 2,2
    • 用镊子夹住5G WiFi天线并使其从机身中分离出来。
    • 在重装的时候,确保在5G WiFi天线的左上角放个塑料垫圈。
    Thank you for teaching me, i have my iphone 6 plus just got grayed wifi and circling bluetooth, i tried network reset, didnt work yet, thanks alot
    William - 回复
  26. iPhone 6 Plus 逻辑主板更换, 振动器: 步骤 26 中的图像 1,2 iPhone 6 Plus 逻辑主板更换, 振动器: 步骤 26 中的图像 2,2
    • 用撬棒的平头挑开扣在主板上的振动器排线。
    Both on my original and on my replacement, there was adhesive on the underside of this connector and it blended in with the color of the speaker (instead of being gray, as in the photo), so that it looked like it was attached to the speaker itself. In reality, it is part of the lightning connector and headphone jack assembly that is being replaced and that is stuck to the case (cf. steps 34–38). If yours is similar, go ahead and peel it off of the top of the speaker now, and the speaker will come right out when you get to that step.
    grabauski - 回复
  27. iPhone 6 Plus 逻辑主板更换: 步骤 27 中的图像 1,1
    • 用撬棒的尖头挑开扣在主板上的天线排线。
  28. iPhone 6 Plus 逻辑主板更换: 步骤 28 中的图像 1,2 iPhone 6 Plus 逻辑主板更换: 步骤 28 中的图像 2,2
    • 用镊子夹住天线排线小心的沿着振动器组件线路拖动。
  29. iPhone 6 Plus 逻辑主板更换: 步骤 29 中的图像 1,1
    • 松开把振动器固定在后盖上的2颗2.5mm飞利浦#00螺丝。
    These two screws are stuck on my phone. Does anyone have any suggestions for loosening them. The heads are becoming stripped the more i try to take them out. I appreciate any suggestions
    tony aviles - 回复
    if you have some spare crummy screwdrivers - like the kind that come with the replacement screens - you can try supergluing it. You just have to be super careful and not get glue anywhere else. make sure you have the screwdriver set in the screw as snugly as possible and let it sit a day or two before you gently try to unscrew it. You can google that method.
    Sarah Ybarra - 回复
    There's a few common methods for this issue.First let me say that not all the screw heads are the EXACT SAME SIZE.You strip the screws when you use a driver that is too small so let's get that out of the way first so that you don't have this problem in the future.
    Now,Method one: use a rubberband
    Method two: A brass Penelope or the higher end kind,Not the little black ones that come in common kits but the ones that come with slightly better kits for example they are usually orange.You must first try constant firm very firm that is,pressure when extracting.You want to basically gouge a pentelope head into the screw,if head on fails then go to an angle after that.Be extremely careful with this method as it's better than the rubberband and I find it's always worked for me,You gotta remain careful when doing this or you might end up slipping and causing catastrophic damage to the board.
    GoodLuck
    Vegeta Barrett - 回复
  30. iPhone 6 Plus 逻辑主板更换: 步骤 30 中的图像 1,1
    • 从机身中取出振动器。
  31. iPhone 6 Plus 逻辑主板更换, SIM 卡: 步骤 31 中的图像 1,2 iPhone 6 Plus 逻辑主板更换, SIM 卡: 步骤 31 中的图像 2,2
    • 把卡针或者回形针插入卡槽的小孔中。
    • 按压推出卡槽。
    • 这可能需要一定的力量。
  32. iPhone 6 Plus 逻辑主板更换: 步骤 32 中的图像 1,1
    • 从机身中取出卡托。
    • 重新插入SIM卡的时候,确保SIM卡安装在卡槽上的方向是正确的。
  33. iPhone 6 Plus 逻辑主板更换, 后置摄像头: 步骤 33 中的图像 1,1
    • 用镊子撕开把后置摄像头盖板固定在后盖上的螺丝贴纸。
  34. iPhone 6 Plus 逻辑主板更换: 步骤 34 中的图像 1,1
    • 松开把后置摄像头盖板固定在后盖上的螺丝:
    • 1颗1.7mm飞利浦#00螺丝
    • 1颗2.3mm飞利浦#00螺丝
    In my case, the rear facing camera was connected to the antenna clip with a piece of black tape, the two can come off together if removed very carefully
    derwentx - 回复
  35. iPhone 6 Plus 逻辑主板更换: 步骤 35 中的图像 1,1
    • 向上拉起从后置摄像头上取出摄像头盖板。
    On my iPhone 6+, the screw removed in step 41 had to come off too as the part number A21-2247A is attached to this cover… seems to have a tiny coil or other component connecting the (ground) post at the 1.6mm screw in step 41
    Matthew Goheen - 回复
    Apparently the antenna clip in step 41 has self adhered to my rear facing camera cover… had I not already removed the screw from step 41 it would have broken when I pulled that cover with just two screws off
    Matthew Goheen - 回复
    WARNING:
    When doing this step 35, you must do step 41 (Simply undo the small screw under “One 2.3 mm Phillips #00 screw “ as well) .
    Step 42 shows a ribbon. This ribbon seems to be stuck on the rear-facing camera bracket (step 35).. so pulling rear-facing camera bracket off  , be careful it is not adhered and pulling off Step 42 ‘s ribbon!
    It is electronic and a ribbon.
    Anyname - 回复
  36. iPhone 6 Plus 逻辑主板更换: 步骤 36 中的图像 1,1
    • 用撬棒的平头挑开扣在主板上后置摄像头排线。
  37. iPhone 6 Plus 逻辑主板更换: 步骤 37 中的图像 1,1
    • 小心的夹住移动后置摄像头把其从机身中取出来。
  38. iPhone 6 Plus 逻辑主板更换, 逻辑主板: 步骤 38 中的图像 1,1
    • 松开把塑料垫圈固定在后盖上的单颗2.8mm飞利浦#00螺丝。
    hallo,
    ich habe versucht das Gehäuse zu wechseln, dabei ist mir diese schraube der Plastikklammer im Gehäuse kaputt gegangen, heißt der Schraubenkopf ist rund. Ich habe es auch schon mit Sekundenkleber versucht, hat aber auch nicht geholfen.
    Da wollte ich jetzt wissen welche Aufgabe die Plastikklammer hat und ob man die sich irgendwo bestellen kann.
    Mfg
    denisekoch163 - 回复
  39. iPhone 6 Plus 逻辑主板更换: 步骤 39 中的图像 1,1
    • 松开后盖顶部的单颗1.3mm飞利浦#00螺丝。
  40. iPhone 6 Plus 逻辑主板更换: 步骤 40 中的图像 1,2 iPhone 6 Plus 逻辑主板更换: 步骤 40 中的图像 2,2
    • 用镊子稳当的夹住塑料垫圈从机身中取出。
  41. iPhone 6 Plus 逻辑主板更换: 步骤 41 中的图像 1,1
    • 松开把天线垫圈固定在后盖上的单颗1.6mm飞利浦#00螺丝。
  42. iPhone 6 Plus 逻辑主板更换: 步骤 42 中的图像 1,2 iPhone 6 Plus 逻辑主板更换: 步骤 42 中的图像 2,2
    • 用镊子小心夹住天线垫圈从机身中取出。
    Hello
    My iPhone After opening the security screw Antenna
    Please help me find the antenna does not find
    saeed - 回复
    You may need this part… on mine it was stuck enough to the rear facing camera cover that it almost broke when I tried to remove the cover before taking this screw out.
    Matthew Goheen - 回复
    WARNING
    This should be done in Step 35!
    This ‘clip’ is a small ribbon with electronics on it. Be careful.
    This clip can be adhered to the Step 35 part removal. Careful to not rip it.
    Anyname - 回复
  43. iPhone 6 Plus 逻辑主板更换, 逻辑主板: 步骤 43 中的图像 1,1
    在这个步骤中使用的工具:
    Standoff Screwdriver for iPhones
    $5.49
    购买
    • 取下拧在后盖上固定主板的螺丝:
    • 2颗2.4mm的子母螺丝。
    • 要卸下子母螺丝最好使用一把专用的子母螺丝刀或子母螺丝刀组。您也可以使用一把一字型小螺丝刀来替代使用——注意不要损伤周围元件。
    • 1颗2.1mm的00号十字螺丝
  44. iPhone 6 Plus 逻辑主板更换: 步骤 44 中的图像 1,1
    • 从靠近尾插的部位捏住主板的底部轻轻抬起主板 不能有拖动的动作。
  45. iPhone 6 Plus 逻辑主板更换: 步骤 45 中的图像 1,1
    • 不要移动逻辑主板。还有1根天线排线扣在逻辑准备上。
    • 继续慢慢的小心从主板底部抬起主板直到与平面垂直。
    WARNING
    Antenna connector under top end of the board is what is being shown here, simply pry it down to disconnect it and you won’t have to flip the board up so high as seen in the photo.
    To reinstall, you then have to lift the board up somewhat to align it, and use tweezers. (careful the tweezers doesn’t touch a component on the top of the board)
    Anyname - 回复
  46. iPhone 6 Plus 逻辑主板更换: 步骤 46 中的图像 1,2 iPhone 6 Plus 逻辑主板更换: 步骤 46 中的图像 2,2
    • 小心的把主板翻一个面,然后把主板平躺在后盖的顶部。
    • 用平口撬棒挑开扣在主板背面的天线排线。
  47. iPhone 6 Plus 逻辑主板更换: 步骤 47 中的图像 1,1
    • 抬起移动主板使其从机身中分离出来。
    When replacing the Logic board don't forget to check the top two connectors above the battery to make sure that they are free and clear to replace on the board when the time comes.
    Mark Waddington - 回复
    Advice on reassembly
    Look carefully with reading glasses at the ribbon connections. Make sure there is no damage or any spec inside the connection. To put together a ribbon onto the board, start with a side and press down. LOOK at the connection carefully and take your time. IF you align it on top of it instead of starting on a side, then press down and lift the phone up in different directions to see different angles of the ‘fit’. You want it flat and not have a side of the connection sticking out of the board at all. You will reassemble the phone and have lines on the screen or abnormal operation if you don’t be careful and attentive with the cable connections.
    Make sure the grove the display fits in - is clean. Make sure the grove of the display is clean.
    Make sure you have mapped out where the screws go… they are different sizes, and head shapes.. look for a washer on one of them.. very top left wifi black plastic part. (Step 24 =red)
    Step 29-30 .. 2 springs under it.
    Step 42 & 35 done at the same time.
    Anyname - 回复
结论
请倒序重组你的设备。
182等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Jeff Suovanen
于08/06/13注册
428,716 声望
创作了259篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,299篇指南
31条评论
Hello. Good job on these teachings of disassembly. I need help in changing the logic board of my iphone 5 and iphone 6. Where can i buy the logic board? I reside in Nigeria
Kesiah - 回复
HI do you know who replaces logic boards on iPhone 6?
neffangelica -
I am on Step 29 and the upper-right screw was stripped in manufacturing and I am not able to remove? What is the best way to remove the stripped screw?
Jon Pellant - 回复
if u can melt a pen and stick it on then twist it if that dosen’t work use a dermel cut the screw and use a flahead
Albert lam -
Is there anyone who has this service Im willing to pay someone who's legit
IBeDECK - 回复
can someone tell me where to buy this logic board cant find it
greg -
La verdad es muy fácil el cambio
Bonifacio Godinez - 回复
Is there a certain logic board for each company like sprint and T-Mobile?
octoturtleouss - 回复
is there any difference in 6 plus logic boards, I'm trying to buy a new logic board but I need to know if any 6plus logic board will do or if I have to follow model number
DeVaughn Carmon - 回复
try fully charging your battery and the white lines may resolve themselves. I had that issue and read a lot of repair specialists say that resolved the white line issue after about 24 hours. I ended up needing a new screen. My husband damaged my digitizer connectors when he tried to fix my phone.
Nellydlally - 回复
What does the logic board do? My little boy wet my phone and plugged it in and said it vibrated and died. It won't come on. I would like to fix it on my own. I fixed both my 5s's. It's just depressing how much money in broken "I" devices I have laying around!
Nellydlally - 回复
I need help in changing the logic board of my iPhone 6 plus. Where can i buy the logic board in Saudi Arabia?
alatawi1pd - 回复
iphone 6plus is not charging, already changed the lightning ribbon cable along the bottom, anything else to try?
kev mc - 回复
how much does the mother board cost?
annahub - 回复
What kind of the board do u need ?
Fixing up -
Is step 46 a discenection of a gps flex?
Michal Míka - 回复
I have a 6 with a good logic board and a 6s with water damage, are the logic boards in the 6 and 6s interchangeable?
Steven Weeks - 回复
No way. those are different
David Reva -
If i replace the mother board and logic board will it fix the touch screen issue? Is there a replacement kit that comes with the mother board and logic board and the home button so i can have the touch id
Amanda Henderson - 回复
Yes it will fix the issue, but only way to pair I touch is by Apple authorized service
hersheys247 -
I´m just replaced logic board but iPone don´t turn on. Wha can I do?
David Reva - 回复
I completed this guide because I had the touch disease problem with my iPhone, I cust out Post-IT’s (7pieces) on the glued side of them so they would stay on top of each other and applied them directly on the touch IC on the back side of the logic board. Put everything back together and now after 3 weeks, my iPhone still works as expected! Thanks a lot for this very clear tear down!
Wannes - 回复
Where would be a good place to find an iphone 6s+ motherboard with a home button?
Santiago Fernandez - 回复
My iPhone 6 plus does not boot - it’s always black, and nothing pops up in iTunes when connected with my Mac.
How could I know what issue it is and buy the right parts? It could be battery, screen, or logic board…
Peter F - 回复
Great instructional document! Was not able to repair the water damage to the logic board, but WAS able to disassemble and reassemble perfectly. The phone fired right back and was acting the same as when I took it apart. If I can find a new logic board, I feel confident enough to try this again with the new part! THANKS!!
Anne Hamilton - 回复
Thank you somuch…. I have replaced my Apple iPhone 6 Plus logic board with the help of this guide and now is working well… thanks to good work and keep it up…
Cheers…..
Shiran Gunasekara - 回复
I see where there are Bare Motherboards for less than $20. How difficult is it to use the Bare Motherboards?
. Naturally some units have to be added to the Bare Motherboard.
John Drew - 回复
Unfortunately bare boards are useful for soldering practice, and little else. In order to source a complete set of chips and SMT components, solder them to the board, test everything and get it working, you’d need so much skilled labor that it would probably outweigh the cost of just buying a new phone many times over. It’d be a heck of a cool project, but not practical for any repair purpose. Sorry!
Jeff Suovanen -
Nice format of part removal to mother board, to be more complete add re-assembly with cautions… great photography , Walter from Massachusetts
waltert2005 - 回复
very good… i like so mx
João - 回复
My iPhone 6 plus won't turn on after I played Roblox too much it overheated and shut off. It kept shutting off and turning back on but I didn't really care lol. How do I know if the problem is the motherboard cuz I literally changed the entire battery and it still ain't turning on. Idk wut to do
Blair Asher - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 37
过去 30 天: 173
总计 264,999
