简介
若要简化维修过程, 请使用我们的工具 fix kit 并遵循指示 this shorter guide 来更换你 iPhone 的全部显示组件 (屏幕总成).
对于更熟练的维修者, 本教程将帮助您*仅*更换 iPhone 5s 的 LCD 显示器和触摸组件 (即俗称的“外屏”) 而无需更换全部的显示组件 (屏幕总成). 这需要你在安装前从你旧有的屏幕总成上转移一些组件到新的触摸组件 (外屏) 上 — 包含前置摄像头组件, 听筒组件, LCD 保护背板和 Home 键组件.
对于上述维修, 转移原有的 Home 键组件到新触摸组件 (外屏) 上是必要且重要的, 因为它们对于维持 Touch ID 正常工作而言是必要的.
你还可以使用此教程来更换如下组件:
工具
视频概述
握紧iSclack的把手,打开它的吸盘口。
把你iPhone的底部放置在两个吸盘之间,紧紧靠住塑料的深度计。
上面吸盘应该刚好在home健的上方位置。
使用iSclack把手把钳口合上。把吸盘放到手机中间,并且把吸盘牢牢地按到iPhone屏幕上和机身底部。
若要重新组装你的设备,请以逆序参考本说明的以下步骤。
1016等其他人完成本指南。
特别感谢这些译者︰
62%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
85条评论
FYI Vibrate motor
Just did one of these last night, worked perfectly except that the vibrate motor stopped working, took it back apart and realized that the little prong on the ear speaker cover sometimes gets bent a little with removal. I just pushed it back in and the vibrate motor then had enough room to work again. Make sure that you push it back in all the way first time unless you want to do more work than you have to! These phones have no space to spare!
For some reason after doing this the home button seems to have sunk and requires a much much harder press for it to work. I think it's the adhesive? Any ideas?
If the rubber gasket is not seated correctly, it may have wrinkle in it, thus hindering is action.
During reassembly be very, VERY careful when pressing the display assembly into the rear frame. Many displays are damaged because the phone was dropped and the rear frame hit a hard surface. The rear frame may be slightly bent or out of shape. When pressing the new display in place it might not fit easily and applying even light pressure can BREAK the new display assembly (I know from experience). Supper lame to get literally to the very last step and crack the new display. %&*#!!!
kevindfrye - 回复
just happened to me i also got reboot logo stuck
