你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
视频概述
记住从旧的屏幕上取下Home键安装在新屏幕上(大多数情况,新屏幕是没有Home键)。Home键的橡胶垫圈是很薄的注意不要拉断。同时,观察替换的屏幕上是否有听筒网,如果没有,从旧屏幕上取下再装上去即可。
在安装新的屏幕前一定要撕下屏幕保护贴纸(通常是蓝色或者粉红色)。
如果你更换的新屏幕没有直径7mm的前置摄像头固定圈,从旧屏幕上取下安装在新屏幕上即可。
小心拉直屏幕排线和数字转换排线然后从中板打孔处穿过去。图片中图的做法是错误的,使橡皮圈和数字转换排线一起穿过开孔。中图展示的橡皮圈。
这个照片展示了屏幕组件被错误的安装的样子,在数字排线之间留有太多空隙,最终会导致排线弯曲/缠绕最终被卡在凹槽上。第三张照片展示了这个凹槽。
要重新组装你的设备,请按照相反的顺序阅读这些说明。
2760等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
164指南评论
Helpfull tip... I printed these instructions and then taped each screw to the spot in the instructions with scotch tape.
Kevin Keenan - 回复 分享
AWESOME guide - very impressed. All works but I did wind up with an extra part so I must've improved upon Apple's design. The part is a small, rectangular grounding clip (black and gold) with a single brass finger and a hole through the black part... this is NOT the one mentioned in Step 26. Not sure from where it came off & not inclined to dig back into it - but would love to know where it was from. It's 1:30 am here and I may be overlooking something idiotic... any help would be much appreciated. Thanks again, Jim
Jim McAward - 回复 分享
Turns out my "extra" part was the one that James Molyneux mentioned, which comes out as part of Step 5. (The clip provides a bit of extra ground contact between the back of the WiFi antenna and the rear case.) Again, totally awesome instructions - thanks!
Jim McAward - 回复 分享
