跳转到主内容
加入维修社区 - 创建账户
iPhone 16 Pro Screen Removal
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. iPhone 16 Pro Screen Removal, Prepare the phone for disassembly: 步骤 1 中的图像 1,2 iPhone 16 Pro Screen Removal, Prepare the phone for disassembly: 步骤 1 中的图像 2,2
    • Allow the phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from the phone.
    • Hold the power and either volume buttons and slide to power off the phone.
  2. iPhone 16 Pro Screen Removal, Tape over any cracks: 步骤 2 中的图像 1,2 iPhone 16 Pro Screen Removal, Tape over any cracks: 步骤 2 中的图像 2,2
    • If the screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 16 Pro Screen Removal, Mark your opening picks: 步骤 3 中的图像 1,3 iPhone 16 Pro Screen Removal, Mark your opening picks: 步骤 3 中的图像 2,3 iPhone 16 Pro Screen Removal, Mark your opening picks: 步骤 3 中的图像 3,3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  4. iPhone 16 Pro Screen Removal, Remove the pentalobe screws: 步骤 4 中的图像 1,2 iPhone 16 Pro Screen Removal, Remove the pentalobe screws: 步骤 4 中的图像 2,2
    • Use a P2 pentalobe screwdriver to remove the two 7.4 mm‑long screws on either side of the USB-C port.
  5. iPhone 16 Pro Screen Removal, Create a gap with a suction handle: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    iOpener
    $14.99
    • The next two steps show how to create an initial gap using a suction handle.
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • You can also use an iOpener to heat the screen. Follow these instructions to heat and apply the iOpener properly.
  6. iPhone 16 Pro Screen Removal: 步骤 6 中的图像 1,3 iPhone 16 Pro Screen Removal: 步骤 6 中的图像 2,3 iPhone 16 Pro Screen Removal: 步骤 6 中的图像 3,3
    • Apply a suction handle to the bottom edge of the screen.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • If you can't create a gap, apply more heat to the edge and try again.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 16 Pro Screen Removal, Screen information: 步骤 7 中的图像 1,1
    • As you slice the adhesive securing the screen in the following steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
    • Two delicate cables connecting the screen to the iPhone—one just above the Action button and the other about halfway along the left edge of the iPhone
    • Multiple spring contacts around the perimeter of the iPhone
  8. iPhone 16 Pro Screen Removal, Slice the bottom edge adhesive: 步骤 8 中的图像 1,3 iPhone 16 Pro Screen Removal, Slice the bottom edge adhesive: 步骤 8 中的图像 2,3 iPhone 16 Pro Screen Removal, Slice the bottom edge adhesive: 步骤 8 中的图像 3,3
    • Slide the opening pick along the bottom edge to release the adhesive.
    • Don't insert the pick deeper than 3 mm to avoid damaging the spring contacts.
    • If the adhesive feels difficult to slice, reheat the edge for a minute.
    • Leave the opening pick in the bottom-left corner to prevent the adhesive from resealing.
  9. iPhone 16 Pro Screen Removal, Heat the left edge: 步骤 9 中的图像 1,1
    • Use a hair dryer or heat gun to heat the left edge of the screen until it's hot to the touch.
  10. iPhone 16 Pro Screen Removal, Separate the left adhesive: 步骤 10 中的图像 1,2 iPhone 16 Pro Screen Removal, Separate the left adhesive: 步骤 10 中的图像 2,2
    • Don't insert your pick deeper than 3 mm to avoid damaging the spring contacts and cables.
    • Insert a second opening pick in the bottom-left corner, close to the existing pick.
    • Slide the opening pick along the left edge of the screen to separate the adhesive and release the metal clips.
    • You'll hear and feel the metal clips release as you pass them.
    • Leave the opening pick in the top-left corner to prevent the adhesive from resealing.
  11. iPhone 16 Pro Screen Removal, Separate the remaining adhesives: 步骤 11 中的图像 1,3 iPhone 16 Pro Screen Removal, Separate the remaining adhesives: 步骤 11 中的图像 2,3 iPhone 16 Pro Screen Removal, Separate the remaining adhesives: 步骤 11 中的图像 3,3
    • Repeat the heating and slicing procedure along the remaining screen edges.
  12. iPhone 16 Pro Screen Removal, Swing open the screen: 步骤 12 中的图像 1,3 iPhone 16 Pro Screen Removal, Swing open the screen: 步骤 12 中的图像 2,3 iPhone 16 Pro Screen Removal, Swing open the screen: 步骤 12 中的图像 3,3
    • At this point, the screen should be free from the frame. If the screen feels stuck, go back around the perimeter with your pick and carefully check for missed sections of adhesive or stuck clips.
    • Carefully lift the screen upwards until the clips along the long edges clear the frame.
    • Swing open the screen over the left edge of the iPhone and lay it flat on your work surface.
  13. iPhone 16 Pro Screen Removal, Remove the connector covers: 步骤 13 中的图像 1,1
    • Use a tri-point Y000 driver to remove the two 1.3 mm‑long screws securing the front sensor and display connector covers.
  14. iPhone 16 Pro Screen Removal: 步骤 14 中的图像 1,3 iPhone 16 Pro Screen Removal: 步骤 14 中的图像 2,3 iPhone 16 Pro Screen Removal: 步骤 14 中的图像 3,3
    • Use tweezers to grasp the front sensor connector cover near the screw hole.
    • Lift and remove the cover.
  15. iPhone 16 Pro Screen Removal: 步骤 15 中的图像 1,3 iPhone 16 Pro Screen Removal: 步骤 15 中的图像 2,3 iPhone 16 Pro Screen Removal: 步骤 15 中的图像 3,3
    • Repeat this process for the other cover.
  16. iPhone 16 Pro Screen Removal, Disconnect the screen: 步骤 16 中的图像 1,2 iPhone 16 Pro Screen Removal, Disconnect the screen: 步骤 16 中的图像 2,2
    • Use the tip of a spudger to pry up and disconnect the display press connector.
  17. iPhone 16 Pro Screen Removal: 步骤 17 中的图像 1,2 iPhone 16 Pro Screen Removal: 步骤 17 中的图像 2,2
    • Repeat this process for the front sensor press connector.
  18. iPhone 16 Pro Screen Removal, Remove the screen: 步骤 18 中的图像 1,1
    • Remove the screen.
结论
To reassemble your iPhone, follow these instructions in reverse order.
After your repair, calibrate a genuine replacement screen using Apple's Repair Assistant. Navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Pro Answers community for help.
另外一个人完成了本指南。
Nick Schultz
于03/24/24注册
43,497 声望
创作了252篇指南
团队
iFixit iFixit 的会员
Staff
125 名成员
创作了24,052篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 855
