简介
Use this guide to replace the rear-facing cameras in your iPhone 14.
This guide was created using the A2882 (international) model. If you're fixing a different iPhone 14 model, there may be some visual discrepancies, but the procedure should be the same.
You’ll need replacement adhesive to reattach the screen when reassembling the device. Your device will function normally, but will most likely lose its IP (Ingress Protection) rating.
你所需要的
Power off your iPhone before beginning disassembly.
Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Lay overlapping strips of clear packing tape over the iPhone's rear glass until the whole face is covered.
If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the rear glass with that instead.
Follow this guide to secure your screen with the included tape.
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
Use a hair dryer to heat along the bottom edge of the iPhone. The glass should feel slightly too hot to touch.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick under the rear glass when the Anti-Clamp creates a large enough gap.
Skip the next two steps.
Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the rear glass is slightly too hot to touch.
Apply a suction handle to the bottom edge of the rear glass, while avoiding the very edge of the glass.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the case.
Insert an opening pick into the gap.
Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the rear glass is slightly too hot to touch.
Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the rear glass in place.
Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the rear glass is slightly too hot to touch.
Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the rear glass is slightly too hot to touch.
Insert your pick underneath the top right edge of the phone. Slide it around the top-right corner and halfway across the top edge.
Remove your suction handle from the rear glass.
Slowly open your iPhone by swinging the rear glass up from the left side, like the back cover of a book.
Lean the rear glass against something to keep it propped up while you're working on the phone.
If you don't have anything at hand to lean the rear glass against, your suction handle can do the trick.
Use a Y000 screwdriver to remove the two 1.3 mm-long screws securing the battery connector cover.
Use the pointed end of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
Use a Y000 screwdriver to remove the single 1.0 mm-long screw securing the charging coil connector cover.
Use a pair of tweezers to remove the charging coil connector cover.
Use the pointed end of a spudger to disconnect the charging coil cable by prying the connector straight up from its socket.
Use a spudger to disconnect the two rear facing camera cables by prying the connectors straight up from their sockets.
Use a Phillips screwdriver to remove the three 2.1 mm-long screws securing the rear camera assembly.
Insert the pointed end of a spudger underneath the top edge of the rear-facing camera assembly.
Pry up with the spudger to loosen the rear-facing camera assembly.
Use a pair of tweezers or your fingers to remove the rear-facing camera assembly.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
另外一个人完成了本指南。
一条评论
Be Careful!! In certain models you also have to unplug the cable that goes over the camera cables, and lift it slightly out of the way. (this cable plugs in just below where the wireless coil plugs in) failure to do so will rip this cable.
