简介
我们无法将每一片芯片ID都放进我们的iPhone 13 Pro拆解中。因此,如果你渴望更多,这篇文章是对iPhone 13 Pro主板上的芯片更加深入的了解。
特别感谢我们的社区成员Chunglin Chin为此做出的贡献!
主板,第一面:
Apple APL1W07 A15仿生芯片 堆叠封装在很可能是 6 GB 海力士 LPDDR4x SDRAM上
Apple APL1098 电源管理IC
Apple 338S00762-A1 电源管理IC
意法半导体 STB601A05 电源管理IC
Apple 338S00770-B0 电源管理IC
德州仪器 TPS65657B0 显示屏电源管理IC
恩智浦半导体 CBTL1616A0 显示屏端口多路复用器
主板,第2面和第3面(续):
Bosch Sensortec 6轴加速度计/陀螺仪
由衷感谢以下译者:
100%
Alyssum正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
8条评论
Does anyone know anything more about the USI 339S00761 WiFi/Bluetooth module? Specifically, it would be really interesting to understand if there is Bluetooth LE Audio capabilities hidden there.
please i need a help my iphone 13 pro i try to restore and gave me error unable to restore idevice (-1)
Logic board For IPhone 13 pro
do you have a schematic diagram of data connector flex for iPhone 13 PRM model... thank you in advnce
The light blue rectangle is what we would call the charging ic. It is a variant of the earlier Tigris and later Yangtze chips that are commonly damaged by rogue chargers. The function of this chip is to create the main power rail from the battery or charger voltage, and control charging of the battery while on the charger. Due to the lack of public schematics for iPhone 13 series, we'd like to propose calling this chip "Genesee" following the river naming convention. The Genesee river is in Rochester, NY
jessabethany - 回复
The purple chip is a new generation of the usb port communication hub. In earlier models this is the famous tristar chip, later called hydra in the iPhone 8 and then Kraken in iPhone 11.
jessabethany - 回复
