简介
如果你的iPhone 12 mini 屏幕破裂,无法响应触摸或在手机开机时未显示图片,请使用本指南通过新屏幕(也称为显示屏部件)将iPhone恢复到正常工作状态。
固定在显示器背面的组合式听筒扬声器+传感器组件已在工厂与您的单个iPhone配对,因此在更换任何显示器时,必须将其从旧显示器转移到新显示器上。它包含泛光照明器,这是生物特征Face ID安全功能的一部分。如果它已损坏或更换,则Face ID将停止工作,因此请格外小心,以免在此过程中损坏任何这些组件。如果损坏,则只有Apple或Apple授权的技术人员才能恢复Face ID功能。
'“注意”':更换屏幕后,即使使用原始Apple屏幕,True Tone功能也被禁用。
在重新组装设备时,你需要在重组时更换粘合剂。
你所需要的
将透明胶带条重叠地放在 iPhone 屏幕上,直至覆盖整个表面。
如果在接下来的几步中无法让吸盘粘住,请将一块强力胶带(例如管道胶带)折叠成把手形状,然后用它来抬起屏幕。
向后拉蓝色手柄以解锁反向钳臂。
将支撑臂滑过 iPhone 的左边缘或右边缘。
将吸盘放置在 iPhone 底部边缘附近 - 一个位于正面,一个位于背面。
将吸盘挤压在一起,对所需区域施加吸力。
you need to clarify that you're heating the metal frame, not the glass. I gently heated the glass front with a heat gun and proceeded to pull the display apart, destroying it. :-(
Jim Harger - 回复
如果你使用的是单个吸柄,则将其应用到手机的底部边缘,并尽可能靠近边缘。
如果显示器严重破裂,请用透明的包装胶带覆盖显示器,以使吸盘粘附。或者,可以使用非常坚固的胶带代替吸盘。如果其它所有方法都失败,则可以将吸盘粘在破碎的筛子上。
用恒定的恒定压力向上拉动吸盘,以在前面板和后壳体之间形成一个很小的间隙。
将撬片插入屏幕边框下方的间隙中。
I ended up separating my screen rather than getting under the scren casing.. BE CAREFUL TO MAKE SURE YOU ARE UNDER THE PLASTIC PART - otherwise you just ruin your screen... No mention of this precaution here and as a result, my phone is more broken than when I started
使用吹风机加热 iPhone 的右边缘(有电源按钮的边缘)90 秒或直到屏幕稍微热到无法触摸。
The pictures show the left side. I know that the left side is the correct one to heat, but for others it might be confusing. 😊
@dviosz You mean the right edge! The picture shows the left edge but the right edge is the correct one to heat. As described in the text next to it. Opening the phone from the left will damage it!
Yeah, sorry, you are right! (tried to make something less confusing and created more confusion by accident… 😃 )
沿着iPhone的右下角和右下角滑动开口挡片,穿过将显示屏固定到位的粘合剂。
Be very careful your tool does NOT go in between the screen and the screen frame but rather in between the screen frame and the phone frame. If not you will damage the screen and need a new one. This has happened to MANY people. The screen is attached to the screen frame with an adhesive that can also be accidentally pried apart if not done carefully. This is probably more likely if your tool is too thin, if you dont heat enough, or dont suction and pull enough to create a big enough separation between the screen frame and the phone frame.
在 iPhone 的左下角插入第二个三角撬片。
同时扭转两个撬片,直到左边缘卡扣松开。
Don't go from just one corner (like on the right side). I've done that (forgot this step) and broke my screen.
拧下1.25毫米长的Y000螺丝,以固定电池和显示屏连接器护盖支架。
拧下5个1毫米长的Y000螺丝,以固定前传感器组件盖支架。
what 3 are the small ones? I don't know anymore
in case anyone else reads this, the 3 small ones screw directly onto the board. the two longer ones screw into standoffs (the two top screws, based on the picture above)
Skyejobs -
卸下听筒扬声器和前传感器组件。
接近传感器
泛光照明器
模块的位置必须确保这些组件不会被任何粘合剂阻塞。
将新的替换零件与原始零件进行比较——在安装之前,你可能需要转移剩余的组件或从新零件上取下粘性衬板。
'''要重新组装设备,请按逆序执行上述步骤。'
将你的电子垃圾带到R2或e-Stewards认证回收商。
维修没有按计划进行吗?维修没有按计划进行吗?尝试一些[[修复后的问题|基本故障排除],或向我们的iPhone 12 mini 社区寻求故障排除帮助。
27等其他人完成本指南。
由衷感谢以下译者:
50%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
4条评论
The only way to pair the new sceen to the phone to retain Tue Tone is to buy a dedicated board that copy the data from the original screen to the new.
This guide was impeccable! The hardest part is definitely getting the screen glue off. Ended up separating the frame of the screen from the display itself. All worked out in the end though!
Should the phone turn ON and screen work with out speaker/sensor module?
is it oem apple battery, because at some photo shows(Ifixit) and another shows (apple) ... wait your answer?
karim - 回复
BEWARE! This screen isn’t the same as older iPhone models’ screens. The iPhone mini 12-screen comes with a thin plastic frame around the screen on its back. Thus, make sure you don’t insert the pick in between the screen and its plastic frame, as you’ll seperate the screen and leave the plastic frame still sitting in the phone’s metal housing (this cost me 100 dollars…). Carefully heat the sides of the metal housing and do not heat directly on the glass, as doing so will potentially loosen the glue from the plastic frame stuck to the screen. My suggestion is that you watch a video of this repair as this step-by-step-guide is undercooked.
Dan - 回复
This is an excellent comment. Following this step-by-step guide to the letter will break your screen; it's by far the worst iFixit guide I've seen to date.
Dormouse -
