简介
使用本指南更换 iPad Pro 12.9" 第三代的 USB-C 充电端口。
本指南使用 WiFi + Cellular 版本(型号 A2014)编写。如果你的机型不同,可能会有一些视觉上的差异,但不会影响操作步骤。
有些照片显示电池接口被两根卡条堵住了。虽然这是一种可选方法,但对电池完全放电更为可靠。请在阅读本指南时忽略这种视觉差异。
你所需要的
在这个步骤中使用的工具:Clampy - Anti-Clamp$24.95
向后拉蓝色手柄,松开反向钳臂。
在 iPad 下方放置一个物体,使其平放在吸盘之间。
将吸盘放在右边缘中间附近,一个在上,一个在下。
稳住反向钳底部,用力向下按顶部的吸盘以产生吸力。
当顶部边缘粘合剂软化时,请注意以下事项:
角落附近有两个环境光传感器。 此处插入撬片的深度请勿超过 1 毫米。
前置摄像头和附加传感器位于顶部边缘的中心。 请勿将撬片镐插入此处 - 粘合剂厚度不足 1 毫米,可能会损坏组件。
将新的替换部件与原部件进行比较--在安装之前,您可能需要转移剩余部件或去除新部件上的背胶。
要重新组装设备,请按照相反的顺序遵循以下说明。
将您的电子垃圾送到R2 或 e-Stewards 认证的回收商。
维修没有按计划进行?请尝试一些基本故障排除,或向我们的iPad Pro 12.9" 第3代社区寻求帮助。
9等其他人完成本指南。
由衷感谢以下译者:
100%
Yanqi Wang正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
5指南评论
Thank you! I replaced the USB-C Port with this guide and fixed my iPad Pro 12.9 2018, easily!
I followed every step, excluding Steps 38-41 (in my case, it wasn't needed to access the charging port at Step 42). Still, things were very straight forward and this guide definitely brought success to fixing my problems!
My local stores were trying to charge $220+ for the same fix.. instead got it done myself for $50 buying whatever needed.
Hi there.
I'm glad your repair went well! You're also right about not having to follow steps 38–41, so I got rid of them!
Is there a separate guide for replacing all these things? Like I'm not sure that I fully understand how to handle the adhesive when placing parts.
Legend Ilu - 回复 分享
Thank you for the information. I was wondering, is there a specific type of hardware that has to be purchased, in order to keep the USB data transfer function? Like is there a replacement USB-C piece that just charges - and a different one that includes the pins for data transfer & charging?
(Had my charging port replaced on IPad Pro 12.9 6th gen - charges fine - no longer recognizes any kind of data) at my wits end
TIA
Is there a proper guide for removing the old adhesive and correctly applying the new adhesive strips? I was hoping there would be some sort of instructions included, but I can’t even tell which protective film to remove first—there are no numbers or markings at all. The advice to “just follow the steps in reverse order” isn’t helpful at all.
Is there a reason why there are no detailed tutorials on how to reassemble iPads?
