跳转到主内容
iPad Mini Wi-Fi Front Facing Camera Cable Replacement
Andrew Optimus Goldheart
Andrew Optimus Goldheart3 其他贡献者
最后更新于 May 7, 2024
没有估计
中等
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独使用。
你所需要的
工具
  1. iPad Mini Wi-Fi Front Facing Camera Cable Replacement, Front Facing Camera Cable: 步骤 1 中的图像 1,2 iPad Mini Wi-Fi Front Facing Camera Cable Replacement, Front Facing Camera Cable: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to peel up and remove the small piece of tape covering the front-facing camera cable connector.
  2. iPad Mini Wi-Fi Front Facing Camera Cable Replacement: 步骤 2 中的图像 1,2 iPad Mini Wi-Fi Front Facing Camera Cable Replacement: 步骤 2 中的图像 2,2
    • The front-facing camera cable connector is secured with pieces of tape that wrap up around the sides of the cable and are fastened to two small metal plates.
    • Use a plastic opening tool to gently pry the lower metal plate up from the front-facing camera cable connector.
    • Being careful not to break the plate or the tape attached to it, pry it up and fold it away from the front-facing camera cable connector.
  3. iPad Mini Wi-Fi Front Facing Camera Cable Replacement: 步骤 3 中的图像 1,2 iPad Mini Wi-Fi Front Facing Camera Cable Replacement: 步骤 3 中的图像 2,2
    • Gently pry the second metal plate up from the front-facing camera cable connector.
    • Again, carefully pry the plate up and away from the front-facing camera cable connector.
  4. iPad Mini Wi-Fi Front Facing Camera Cable Replacement: 步骤 4 中的图像 1,2 iPad Mini Wi-Fi Front Facing Camera Cable Replacement: 步骤 4 中的图像 2,2
    • Use a plastic opening tool to pry the front-facing camera cable's connector up from its socket on the logic board.
  5. iPad Mini Wi-Fi Front Facing Camera Cable Replacement: 步骤 5 中的图像 1,2 iPad Mini Wi-Fi Front Facing Camera Cable Replacement: 步骤 5 中的图像 2,2
    • Gently fold the front-facing camera cable upwards (roughly at a 90-degree angle), exposing the bottom side of it.
结论
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,446篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 46
