跳转到主内容
加入维修社区 - 创建账户
iPad Mini 6 Volume Buttons Replacement
浏览量: 4929
View statistics:
Past 24 Hours:
11
Past 7 Days:
47
Past 30 Days:
153
All Time:
4,929
评论: 1
1 guide comment.
Go to guide comments
已完成: 2
2 people have marked this guide "completed." Will you be next?
收藏: 0
暂时还没有人收藏(和订阅)本指南。你会是第一个收藏(和订阅)的人吗?
所需时间: 1 - 2 小时
难度: 中等
Use this guide to replace the volume buttons in your iPad mini 6.
The volume buttons consist of the volume button board and the plastic buttons themselves.
You'll need replacement adhesive in order to complete this repair.
你所需要的
工具
    1. iPad Mini 6 Volume Buttons Replacement, Apply tape to a cracked screen: 步骤 1 中的图像 1,3 iPad Mini 6 Volume Buttons Replacement, Apply tape to a cracked screen: 步骤 1 中的图像 2,3 iPad Mini 6 Volume Buttons Replacement, Apply tape to a cracked screen: 步骤 1 中的图像 3,3
      • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
      • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
      • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
      询问修复机器人
      添加评论
    1. iPad Mini 6 Volume Buttons Replacement, Heat the bottom edge: 步骤 2 中的图像 1,1
      • Completely power off your device before you begin.
      • Apply a heated iOpener to the bottom edge of the device for 90 seconds to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
      询问修复机器人
      添加评论
    2. iPad Mini 6 Volume Buttons Replacement, Screen removal information: 步骤 3 中的图像 1,3 iPad Mini 6 Volume Buttons Replacement, Screen removal information: 步骤 3 中的图像 2,3 iPad Mini 6 Volume Buttons Replacement, Screen removal information: 步骤 3 中的图像 3,3
      • While you're waiting for the adhesive to loosen, note the following:
      • The areas at the top and bottom of the screen are sensitive to prying.
      • Don't insert a pick more than 3 mm to avoid damaging the screen.
      • There's a long circuit board attached to the screen that sits parallel to the left edge.
      • Don't insert a pick more than 1.5 mm to avoid damaging the circuit board.
      • The first two images are mirrored for demonstration purposes.
      询问修复机器人
      添加评论
    3. iPad Mini 6 Volume Buttons Replacement, Insert an opening pick: 步骤 4 中的图像 1,3 iPad Mini 6 Volume Buttons Replacement, Insert an opening pick: 步骤 4 中的图像 2,3 iPad Mini 6 Volume Buttons Replacement, Insert an opening pick: 步骤 4 中的图像 3,3
      • Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
      • Lift the screen with the suction handle to create a small gap between the screen and the frame.
      • Insert an opening pick into the gap between the frame and the screen.
      • Don't insert the pick more than 1.5 mm to avoid damaging the circuit board.
      • Leave the opening pick in place to prevent the adhesive from resealing.
      询问修复机器人
      添加评论
    4. iPad Mini 6 Volume Buttons Replacement, Separate the bottom adhesive: 步骤 5 中的图像 1,3 iPad Mini 6 Volume Buttons Replacement, Separate the bottom adhesive: 步骤 5 中的图像 2,3 iPad Mini 6 Volume Buttons Replacement, Separate the bottom adhesive: 步骤 5 中的图像 3,3
      • Slide the pick along the bottom edge of the device towards the bottom-right corner.
      • Leave the pick in to prevent the adhesive from resealing.
      询问修复机器人
      添加评论
    5. iPad Mini 6 Volume Buttons Replacement, Heat the right edge: 步骤 6 中的图像 1,1
      • Apply a heated iOpener to the right edge of the device for 90 seconds to loosen the adhesive underneath.
      询问修复机器人
      添加评论
    6. iPad Mini 6 Volume Buttons Replacement, Separate the bottom-right corner adhesive: 步骤 7 中的图像 1,3 iPad Mini 6 Volume Buttons Replacement, Separate the bottom-right corner adhesive: 步骤 7 中的图像 2,3 iPad Mini 6 Volume Buttons Replacement, Separate the bottom-right corner adhesive: 步骤 7 中的图像 3,3
      • Rotate the opening pick around the bottom-right corner of the device.
      询问修复机器人
      添加评论
    7. iPad Mini 6 Volume Buttons Replacement, Separate the remaining adhesive: 步骤 8 中的图像 1,2 iPad Mini 6 Volume Buttons Replacement, Separate the remaining adhesive: 步骤 8 中的图像 2,2
      • Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
      • When you slice near the front camera, don't insert the pick more than 1.5 mm to avoid damaging or smearing the camera.
      询问修复机器人
      添加评论
    8. iPad Mini 6 Volume Buttons Replacement, Reposition the screen: 步骤 9 中的图像 1,3 iPad Mini 6 Volume Buttons Replacement, Reposition the screen: 步骤 9 中的图像 2,3 iPad Mini 6 Volume Buttons Replacement, Reposition the screen: 步骤 9 中的图像 3,3
      • If there's still resistance around the edges of the screen, use an opening pick to cut the adhesive again.
      • Don't try to remove the screen all the way yet; it's still connected to the frame by a flex cable.
      • With the bottom of the device facing you, pull the right edge of the screen up and towards the left edge of the device.
      • Rest the screen upside down and parallel to the frame before continuing.
      • Don't twist the screen or move it too far away from the frame to avoid damaging the flex cable.
      询问修复机器人
      添加评论
    9. iPad Mini 6 Volume Buttons Replacement, Unfasten the display cable bracket: 步骤 10 中的图像 1,2 iPad Mini 6 Volume Buttons Replacement, Unfasten the display cable bracket: 步骤 10 中的图像 2,2
      • Use a Phillips #000 screwdriver to remove the five 1.2 mm-long screws securing the frame bracket to the frame.
      询问修复机器人
      添加评论
    10. iPad Mini 6 Volume Buttons Replacement, Remove the display cable bracket: 步骤 11 中的图像 1,2 iPad Mini 6 Volume Buttons Replacement, Remove the display cable bracket: 步骤 11 中的图像 2,2
      在这个步骤中使用的工具:
      • Use tweezers, or your fingers, to remove the display cable bracket from the frame.
      询问修复机器人
      添加评论
    11. iPad Mini 6 Volume Buttons Replacement, Disconnect the display: 步骤 12 中的图像 1,3 iPad Mini 6 Volume Buttons Replacement, Disconnect the display: 步骤 12 中的图像 2,3 iPad Mini 6 Volume Buttons Replacement, Disconnect the display: 步骤 12 中的图像 3,3
      • Use the flat end of a spudger to pry up and disconnect the display cable's two press connectors secured to the frame.
      询问修复机器人
      添加评论
    12. iPad Mini 6 Volume Buttons Replacement, Remove the screen: 步骤 13 中的图像 1,2 iPad Mini 6 Volume Buttons Replacement, Remove the screen: 步骤 13 中的图像 2,2
      • Remove the screen from the frame.
      询问修复机器人
      添加评论
    1. iPad Mini 6 Volume Buttons Replacement, Disconnect the battery: 步骤 14 中的图像 1,2 iPad Mini 6 Volume Buttons Replacement, Disconnect the battery: 步骤 14 中的图像 2,2
      • The the flat end of a spudger to pry up and disconnect the battery's press connector secured to the frame.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      询问修复机器人
      添加评论
    1. iPad Mini 6 Volume Buttons Replacement, Unfasten the front camera shield: 步骤 15 中的图像 1,2 iPad Mini 6 Volume Buttons Replacement, Unfasten the front camera shield: 步骤 15 中的图像 2,2
      • Use a Phillips #000 screwdriver to remove the two 1.2 mm screws securing the front camera shield to the frame.
      询问修复机器人
      添加评论
    2. iPad Mini 6 Volume Buttons Replacement, Disconnect the volume button board: 步骤 16 中的图像 1,2 iPad Mini 6 Volume Buttons Replacement, Disconnect the volume button board: 步骤 16 中的图像 2,2
      • Use the tip of a spudger to pry up and disconnect the volume button board's coaxial cable.
      • During reassembly, these can be tricky to reconnect. Hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
      询问修复机器人
      添加评论
    3. iPad Mini 6 Volume Buttons Replacement, Unfasten the volume button board's coaxial cable: 步骤 17 中的图像 1,2 iPad Mini 6 Volume Buttons Replacement, Unfasten the volume button board's coaxial cable: 步骤 17 中的图像 2,2
      • Use a Phillips #000 screwdriver to remove the 1 mm screw securing the volume button board's coaxial cable to the frame.
      询问修复机器人
      添加评论
    4. iPad Mini 6 Volume Buttons Replacement, Reposition the coaxial cable: 步骤 18 中的图像 1,2 iPad Mini 6 Volume Buttons Replacement, Reposition the coaxial cable: 步骤 18 中的图像 2,2
      在这个步骤中使用的工具:
      • Use tweezers, or your fingers, to pull the coaxial cable away from the frame, making sure to separate the tape keeping it in place.
      询问修复机器人
      添加评论
    5. iPad Mini 6 Volume Buttons Replacement, Disconnect the volume button board: 步骤 19 中的图像 1,2 iPad Mini 6 Volume Buttons Replacement, Disconnect the volume button board: 步骤 19 中的图像 2,2
      • Use a spudger to pry up and disconnect the volume button board's press connector secured to the frame.
      询问修复机器人
      添加评论
    6. iPad Mini 6 Volume Buttons Replacement, Reposition the volume button board's cable: 步骤 20 中的图像 1,2 iPad Mini 6 Volume Buttons Replacement, Reposition the volume button board's cable: 步骤 20 中的图像 2,2
      • Use tweezers, or your fingers, to peel back the volume button board's cable from the top speaker.
      询问修复机器人
      添加评论
    7. iPad Mini 6 Volume Buttons Replacement, Unfasten the volume button board: 步骤 21 中的图像 1,2 iPad Mini 6 Volume Buttons Replacement, Unfasten the volume button board: 步骤 21 中的图像 2,2
      • Use a Phillips #000 screwdriver to remove the eleven screws securing the volume button board to the frame:
      • One 2.1 mm screw
      • Six 1.4 mm screws
      • Two 2.2 screws
      • Two 1.2 mm screws
      询问修复机器人
      添加评论
    8. iPad Mini 6 Volume Buttons Replacement, Separate the volume button bracket: 步骤 22 中的图像 1,2 iPad Mini 6 Volume Buttons Replacement, Separate the volume button bracket: 步骤 22 中的图像 2,2
      • Use an opening pick, or a spudger, to pry the volume button bracket out of its plastic clips.
      询问修复机器人
      添加评论
    9. iPad Mini 6 Volume Buttons Replacement, Separate the volume button board's adhesive: 步骤 23 中的图像 1,3 iPad Mini 6 Volume Buttons Replacement, Separate the volume button board's adhesive: 步骤 23 中的图像 2,3 iPad Mini 6 Volume Buttons Replacement, Separate the volume button board's adhesive: 步骤 23 中的图像 3,3
      • The volume button board is lightly adhered to the frame.
      • Insert an opening pick between the volume button board and the frame.
      • Slice while prying up with the pick to separate the adhesive.
      询问修复机器人
      添加评论
    10. iPad Mini 6 Volume Buttons Replacement: 步骤 24 中的图像 1,3 iPad Mini 6 Volume Buttons Replacement: 步骤 24 中的图像 2,3 iPad Mini 6 Volume Buttons Replacement: 步骤 24 中的图像 3,3
      • Gently peel the volume button board away from the frame to completely separate the adhesive.
      询问修复机器人
      添加评论
    11. iPad Mini 6 Volume Buttons Replacement, Remove the volume button board: 步骤 25 中的图像 1,2 iPad Mini 6 Volume Buttons Replacement, Remove the volume button board: 步骤 25 中的图像 2,2
      • Use your fingers to remove the volume button board.
      询问修复机器人
      添加评论
    12. iPad Mini 6 Volume Buttons Replacement, Remove the volume buttons: 步骤 26 中的图像 1,3 iPad Mini 6 Volume Buttons Replacement, Remove the volume buttons: 步骤 26 中的图像 2,3 iPad Mini 6 Volume Buttons Replacement, Remove the volume buttons: 步骤 26 中的图像 3,3
      • Use tweezers, or your fingers, to remove the volume buttons from their slots in the frame.
      询问修复机器人
      添加评论
结论
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad mini 6 Answers community for help.
取消:我没有完成这个指南。
2等其他人完成本指南。
Alex Diaz-Kokaisl
于01/16/22注册
250,762 声望
创作了1,200篇指南
团队
Guide Team Guide Team 的会员
Staff
10 名成员
创作了62,132篇指南
1指南评论
It's nice that you have instructions, but where do I find the parts? My volume up button stopped working after it got a little wet. Is that a tell for Apple that it had moisture exposure?
RobCow - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 47
过去 30 天: 153
All Time: 4,929
