本指南有最近更改,您可查看未经巡查的最新版本。
简介
Pre-requisite only guide to remove the volume button cable assembly from an iPad Air 2. Following this guide, you can either further take apart the assembly in order to replace the volume cable, or you can remove the volume buttons for replacement.
你所需要的
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
在这个步骤中使用的工具:Anti-Clamp$24.95
Elevate the iPad enough for the Anti-Clamp's arms to rest above and below the screen.
Pull the blue handle towards the hinge to disengage opening mode.
Position the suction cups near the top edge of the iPad—one on the front, and one on the back.
Push down on the cups to apply suction to the desired area.
Push the blue handle away from the hinge to engage opening mode.
Turn the handle clockwise until you see the cups start to stretch.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
Skip the next two steps.
Slide a battery isolation pick underneath the battery connector area of the logic board, and leave it in place while you work.
Alternatively, make a battery blocker using a playing card and slide it underneath the logic board connector to disconnect the battery.
Remove the following four Phillips screws securing the upper component cable bracket to the tablet.
Two 1.6 mm
Two 1.3 mm
Slide the upper component cable bracket out from under the protective flaps and remove it from the iPad.
Use the flat end of a spudger to disconnect the iSight camera from its socket on the logic board.
Remove the iSight camera.
Remove the 1.2 mm Phillips screw from the bracket covering the volume button cable connector.
