跳转到主内容
当前版本的文档还未经巡查,您可以查看最新的已查核版本
你所需要的
  1. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 1 中的图像 1,1
    • Heat an iOpener and apply it to the left edge of the device for two minutes.
  2. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 2 中的图像 1,3 : 步骤 2 中的图像 2,3 : 步骤 2 中的图像 3,3
    • While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
    • Front camera
    • Antennas
    • Display cables
  3. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 3 中的图像 1,3 : 步骤 3 中的图像 2,3 : 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    Anti-Clamp
    $24.95
    购买
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  4. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 4 中的图像 1,3 : 步骤 4 中的图像 2,3 : 步骤 4 中的图像 3,3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 5 中的图像 1,2 : 步骤 5 中的图像 2,2
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  6. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 6 中的图像 1,3 : 步骤 6 中的图像 2,3 : 步骤 6 中的图像 3,3
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
    • Insert an opening pick into the gap between the digitizer and the frame.
  7. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 7 中的图像 1,3 : 步骤 7 中的图像 2,3 : 步骤 7 中的图像 3,3
    • Insert a second opening pick into the gap you just created.
    • Slide the pick toward the bottom-left corner of the device to separate the adhesive.
    • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
    • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
  8. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 8 中的图像 1,3 : 步骤 8 中的图像 2,3 : 步骤 8 中的图像 3,3
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
  9. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 9 中的图像 1,3 : 步骤 9 中的图像 2,3 : 步骤 9 中的图像 3,3
    • Slide the first opening pick towards the top-left corner of the device to separate the adhesive.
    • Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
  10. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 10 中的图像 1,1
    • Heat an iOpener and apply it to the top edge of the device for two minutes.
  11. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 11 中的图像 1,3 : 步骤 11 中的图像 2,3 : 步骤 11 中的图像 3,3
    • Rotate the pick around the top-left corner of the device to separate the adhesive.
  12. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 12 中的图像 1,3 : 步骤 12 中的图像 2,3 : 步骤 12 中的图像 3,3
    • Slide the opening pick along the top edge of the device, stopping just before you reach the front camera.
    • Avoid sliding the pick over the front camera, as you may damage the lens. The following steps will show how to prevent this.
  13. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 13 中的图像 1,3 : 步骤 13 中的图像 2,3 : 步骤 13 中的图像 3,3
    • Pull the pick out until only the tip is between the digitizer and the frame.
    • Slide the pick above the front camera to separate the adhesive.
    • Leave the pick near the right side of the front camera before continuing.
  14. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 14 中的图像 1,3 : 步骤 14 中的图像 2,3 : 步骤 14 中的图像 3,3
    • Re-insert the pick and slide it towards the top-right corner of the device to completely separate the top adhesive.
    • Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
  15. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 15 中的图像 1,1
    • Heat an iOpener and apply it to the right edge of the device for two minutes.
  16. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 16 中的图像 1,3 : 步骤 16 中的图像 2,3 : 步骤 16 中的图像 3,3
    • Rotate the pick around the top-right corner of the device to separate the adhesive.
  17. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 17 中的图像 1,3 : 步骤 17 中的图像 2,3 : 步骤 17 中的图像 3,3
    • Insert a new opening pick and slide it to the middle of the iPad's right edge.
    • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding once you reach three inches from the bottom of the iPad.
  18. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 18 中的图像 1,1
    • Heat an iOpener and apply it to the bottom edge of the device for two minutes.
  19. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 19 中的图像 1,3 : 步骤 19 中的图像 2,3 : 步骤 19 中的图像 3,3
    • Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
    • Don't fully rotate the pick around the corner, as you may damage the antenna.
    • Leave the pick in the bottom-left corner before moving to the next step.
  20. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 20 中的图像 1,3 : 步骤 20 中的图像 2,3 : 步骤 20 中的图像 3,3
    • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
    • Slide the pick over the antenna, stopping just before the home button.
    • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
    • Leave the pick to the left of the home button before continuing.
  21. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 21 中的图像 1,3 : 步骤 21 中的图像 2,3 : 步骤 21 中的图像 3,3
    • Insert an opening pick into the gap you just created.
    • Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
    • Only insert the pick up to 1 mm to avoid damaging the right antenna.
  22. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 22 中的图像 1,3 : 步骤 22 中的图像 2,3 : 步骤 22 中的图像 3,3
    • Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-right corner.
    • Leave the pick to the right of the home button before continuing.
  23. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 23 中的图像 1,1
  24. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 24 中的图像 1,2 : 步骤 24 中的图像 2,2
    • Be very careful with this step. Take your time, ensure the adhesive is hot and soft, and make sure you separated all of the adhesive with a pick. Don't be afraid to stop and reheat.
    • Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
    • If there's a significant amount of resistance, reheat the edges and work along them with an opening pick.
  25. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 25 中的图像 1,2 : 步骤 25 中的图像 2,2
    • Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
  26. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 26 中的图像 1,3 : 步骤 26 中的图像 2,3 : 步骤 26 中的图像 3,3
    • While supporting the digitizer, slide an opening pick between the two display cables to separate the last of the adhesive.
  27. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 27 中的图像 1,2 : 步骤 27 中的图像 2,2
    • Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
    • During reassembly, clean the remaining adhesive from the frame—and the digitizer if you're re-using it—with isopropyl alcohol. Replace the adhesive with our adhesive strips or pre-cut adhesive cards.
    • Be mindful of the display cables when reassembling the device. Make sure they are folded properly underneath the LCD screen to prevent any damage.
  28. , LCD: 步骤 28 中的图像 1,3 , LCD: 步骤 28 中的图像 2,3 , LCD: 步骤 28 中的图像 3,3
    • 剥离固定LCD屏幕螺丝上的胶带。
  29. : 步骤 29 中的图像 1,1
    • 拆下固定LCD屏幕的Phillips螺丝。
    • 3个4.0 mm螺丝
    • 1个4.8 mm螺丝
  30. : 步骤 30 中的图像 1,3 : 步骤 30 中的图像 2,3 : 步骤 30 中的图像 3,3
    • 因为LCD屏幕任然在Home键附近有许多排线与iPad Air主体相连,切勿尝试完全的将LCD屏移开。 仅可从前置摄像头尾端处抬起屏幕。
    • 使用撬棒扁平的一段来从前置摄像头一边撬起一道可以让你手指抓住LCD 屏幕的缝隙。
    • 从前置摄像头处提起iPad Air 的LCD屏幕,就像翻书一样将它翻转到Home键一侧。
    • 小心驶得万年船,切勿操之过急。在您进行翻转的时候请同时盯着LCD排线。
    • 放下LCD屏幕,以便来处理LCD的排线。
    • 请将LCD屏幕放置在柔软、干净、无绒的表面。
  31. : 步骤 31 中的图像 1,3 : 步骤 31 中的图像 2,3 : 步骤 31 中的图像 3,3
    在这个步骤中使用的工具:
    Battery Blocker
    $3.99
    购买
    • 卸下将电池连接器固定到主板的 2.3 毫米十字螺丝。
    • 为降低短路风险,你可以 插入电池隔离片或修改后的撬片来断开电池。
    • 使用电池隔离片隔离电池时要非常小心。 电池触点容易损坏,造成不可逆转的损坏。
    • 将电池阻挡器滑到主板的电池接口区域下方,并在工作时将其留在原位。
    • 如果你在主板下方安装电池隔离片时遇到问题,你可以尝试使用扑克牌断开电池连接。
  32. : 步骤 32 中的图像 1,1
    • 取下3个显示排线支架上的1.4 mm Phillips螺丝。
  33. : 步骤 33 中的图像 1,2 : 步骤 33 中的图像 2,2
    • 使用撬棒扁平一段来将支架从逻辑板上撬起。
    • 显示屏的排线就在支架下方,因此请勿将撬棒深入过深,这样可能会损坏排线。
  34. : 步骤 34 中的图像 1,1
    • 取下LCD显示屏。
终点
19等其他人完成本指南。
Evan Noronha
于02/05/15注册
223,466 声望
创作了168篇指南
一条评论
muy buen servicio
Pedro Acevedo - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 22
过去 30 天: 110
总计 17,386
