跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
iMac Intel 21.5 英寸显示器胶条更换
你所需要的
  1. iMac Intel 21.5 英寸显示器胶条更换, 放置iMac支架: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    iMac Intel 21.5" Cardboard Service Wedge
    • 一旦铰链可以自由移动,iMac 将失去平衡,难以操作。在支架上放置一个 iMac 支架 以稳定 iMac。
    • 如果使用 iFixit iMac支架,请按照 本组装教程 进行组装。
    • 如果没有 iMac 支架,请小心操作,因为如果 iMac 意外移动,显示屏很容易脱落和损坏。
    I made one out of a square cardboard box, and working well so far
    Will Moindrot - 回复
  2. iMac Intel 21.5 英寸显示器胶条更换, 移除旧的胶条: 步骤 2 中的图像 1,2 iMac Intel 21.5 英寸显示器胶条更换, 移除旧的胶条: 步骤 2 中的图像 2,2
    • 安装新胶条之前,请清除后机箱周边的所有旧胶条。
    • 如果要重复使用现有的显示屏,还必须清除显示屏背面的旧粘胶。
    • 用镊子或手指剥离旧的胶条。从底部开始,向设备顶部向上剥离。
    • 清除所有旧胶条后,用高浓度异丙醇(90% 或更高)和无绒布仔细擦去胶条残留物。顺着一个方向擦拭,不要来回擦拭。
    • 请不要跳过这一步,否则新胶条可能无法正常粘合,显示屏可能会从 iMac 中脱落。
    The aluminum frame have a plastic zone. Could the isopropyl alcohol damage the plastic surface?
    Fer Triva - 回复
    Hello! Isopropyl alcohol should not damage the plastic surface.
    Arthur Shi -
    It’s not clear if you’re supposed to remove the black strips under the adhesives from the screen. Sometimes they come off when removing the main adhesives, but they seem to be two separate layers.
    online - 回复
    Only the adhesive should be removed—the black strips underneath them should stay in place.
    Arthur Shi -
    “Only the adhesive should be removed—the black strips underneath them should stay in place.”
    By fault I’ve removed the black strips, now there is a gap between the glass and the aluminum frame in the bottom.
    the display is perfectly pasted, it’s only a matter of appearance…
    If I open the computer again, what kind of adhesive tape (caption tape?) could I use to eliminate the gap between the glass and the frame?
    Or it’s better to let it go…
    Thanks for your support
    Massimiliano Nannetti - 回复
    Hi Massimiliano ,
    You should be fine. The bottom edge doesn’t have black strips. It should be bare metal. However, there shouldn’t be any gaps between the glass and the frame. Make sure that the adhesive is fully adhered on the bottom edge.
    Arthur Shi -
    Hi Arthur,
    my English is not perfect…
    I would mean that I removed all the black strips under the adhesives on the screen; so I believe that the glass has become too thin compared to the bottom aluminium frame.
    I thought to open the Mac again and put some black strips to increase the thickness of the glass screen but I don’t know what kind of tape I should use (Kapton or other?).
    And then I will put a new set of ifixit adhesives strips.
    Maybe it’s a waste of time… it’ s only an aesthetic matter
    Thanks again
    Thanks for the clarification. Since there is always a chance to crack the screen glass when cutting the adhesive, I’d suggest not to open up the iMac again. However, if you do open it, I suggest using Tesa tape.
    Arthur Shi -
    Thanks Arthur,
    I will follow your suggestion… I will not open again my computer…
    Now it works very well and fast.
    So, the bit about the adhesive strips really needs to be clarified. Nowhere in the instructions is there talk about multiple layers of adhesive, one that should be removed and one that should remain. And looking at the pictures further on, clearly the wider sections where the adhesive go are completely clean of any black strips. However, on the screen side, I’ve noted that indeed there are two layers, at least on the top. And removing both layers leads to the adhesive *not* really taking hold and the screens falling out. Really wish this had been clearer. I’ve helped dozens of people upgrade their iMac but after the first time that I had to replace a screen due to it falling and breaking, I’ve been using clear strong adhesive tape externally on the corners to ensure that the screen stays in place. Ugly, but better than the risk.
    David - 回复
    Are you sure there are 2 layers of tape? My replacement tape comes with the sections that sticks over the 2x antenna sections on the right side of the screen (looking at the screen). The old tape has antenna section left over because only the thinner edge part was cut so that section separated.
    Furthermore, the replacement tape on the antenna section is only sticky on 1 side (facing the chassis) and no sticky surface to the screen (other than the thin 5-6mm width edge like the rest of the none antenna section.
    As for falling off, I'm guessing there are 1. cheap tapes that looks the part but don't stick as well 2. surfaces not cleaned and primed 3) 2 top corner breathing channel (hot air rise and go out there) got sealed off as Step 6 below + pulling and stretching the tape sealed off that channel. Happened to me the first time, had to cut back to expose the air channel. On subsequent efforts, didn't pull to stretch the tape. Went gradually a couple of inches at a time so the tape don't stretch.
    Howard -
    I’m putting in an SSD, don’t have any strips. Would super glue work?
    natfrey - 回复
    no! don't do that. if for any reason in the future you need to open it up again, you will only destroy your screen. you can get strips really cheap on Amazon.
    David -
    I too started removing the second layer of adhesive strips before reading these comments. PLEASE update the article to reflect that the other black strips should stay!
    Mark Sandell - 回复
    A few key notes
    2 top corners have air gaps to let the hot air out. When applying the new tapes, its easy to stretch the tape and seal this hole using the method outlined below. Best to go slowly small section at a time to avoid stretching the tape. 2 people is helpful.
    Before peeling the tape facing the LCD, its good to mount the LCD with masking tape (avoid covering mic holes) to test everything. I like to use Photo Booth and record a video to ensure camera and mics are all working properly.
    2 people also helpful on the final reseal. I like to stand the iMac up vertically so can power on and do final check after LCD connection before reseal. The screen is pivots on the bottom edge and iMac chassis is wobbly on its stand so 2 people is helpful. For final check, I like to make sure screen powers on and display shows before final reseal.
    Howard - 回复
  3. iMac Intel 21.5 英寸显示器胶条更换: 步骤 3 中的图像 1,2 iMac Intel 21.5 英寸显示器胶条更换: 步骤 3 中的图像 2,2
    • 胶条上应预留麦克风缺口,标有 4R。
    • 如果你的 4R 胶条不包含凹槽,请查看本指南
    As far as I can tell, this model still had the mic at the top near the webcam, not at the bottom, so this notch is not needed for this model (2014 21.5” iMac A1418)
    Neddy - 回复
  4. iMac Intel 21.5 英寸显示器胶条更换: 步骤 4 中的图像 1,2 iMac Intel 21.5 英寸显示器胶条更换: 步骤 4 中的图像 2,2
    • 事先铺好胶条,这样就不会不小心把胶条装错位置:
    • 胶条1在左上方摆放
    • 胶条2在右上方摆放
    • 胶条3在右侧垂直摆放
    • 胶条 4R 在右下方摆放,暗面朝上
    • 胶条 4L 在左下方摆放,暗面朝上
    • 胶条5在左侧垂直摆放
  5. iMac Intel 21.5 英寸显示器胶条更换, 撕掉第一条胶带上的背胶: 步骤 5 中的图像 1,3 iMac Intel 21.5 英寸显示器胶条更换, 撕掉第一条胶带上的背胶: 步骤 5 中的图像 2,3 iMac Intel 21.5 英寸显示器胶条更换, 撕掉第一条胶带上的背胶: 步骤 5 中的图像 3,3
    • 从第 03 条开始,它位于后机箱的右侧垂直面上。
    • 在撕下任何背胶之前,将胶带沿着 iMac 的框架对比,以了解它的位置。
    • 抓住蓝色标签,从条带背面剥下一小块背胶,露出一段粘合剂,将其固定在外壳上。
  6. iMac Intel 21.5 英寸显示器胶条更换, 粘贴第一条胶条: 步骤 6 中的图像 1,2 iMac Intel 21.5 英寸显示器胶条更换, 粘贴第一条胶条: 步骤 6 中的图像 2,2
    • 将撬棒的尖端插入刚刚移除一层背胶的胶条末端的孔中。 从仍有一层白色背胶的一侧插入撬棒。
  7. iMac Intel 21.5 英寸显示器胶条更换: 步骤 7 中的图像 1,3 iMac Intel 21.5 英寸显示器胶条更换: 步骤 7 中的图像 2,3 iMac Intel 21.5 英寸显示器胶条更换: 步骤 7 中的图像 3,3
    • 在撬棒仍然从胶带上的孔中戳出的情况下,将撬棒尖端推入 iMac 框架上相应的孔中。
    • 使用孔和撬棒固定胶条的位置,将胶条与右边缘对齐,轻轻向上拉动撬棒以确保胶条拉紧,然后将其粘贴到框架上。
  8. iMac Intel 21.5 英寸显示器胶条更换: 步骤 8 中的图像 1,2 iMac Intel 21.5 英寸显示器胶条更换: 步骤 8 中的图像 2,2
    • 对齐胶条的下半部分后,将较长的背衬从胶条后面剥离。
    • 如果下半部分未正确对齐,你可以小心地将其剥离并重新粘贴,然后再剥离下背衬条。 请务必使用撬棒尖端固定顶部。
  9. iMac Intel 21.5 英寸显示器胶条更换: 步骤 9 中的图像 1,2 iMac Intel 21.5 英寸显示器胶条更换: 步骤 9 中的图像 2,2
    • 将胶条的上半部分与后外壳的右边缘对齐,然后将其粘贴下来。
  10. iMac Intel 21.5 英寸显示器胶条更换: 步骤 10 中的图像 1,2 iMac Intel 21.5 英寸显示器胶条更换: 步骤 10 中的图像 2,2
    • 用手指抚平胶条。确保它与框架的右侧整齐对齐,并且平整。
    • 先不要剥离前面的背胶。
  11. iMac Intel 21.5 英寸显示器胶条更换, 贴上剩余的胶条: 步骤 11 中的图像 1,1
    • 按逆时针方向,在 iMac 的四周,以同样的方式再添加三条胶条:
    • 右上方的胶条2
    • 左上方的胶条1
    • 左侧垂直的胶条5
  12. iMac Intel 21.5 英寸显示器胶条更换, 黏上底部胶条: 步骤 12 中的图像 1,3 iMac Intel 21.5 英寸显示器胶条更换, 黏上底部胶条: 步骤 12 中的图像 2,3 iMac Intel 21.5 英寸显示器胶条更换, 黏上底部胶条: 步骤 12 中的图像 3,3
    • 接下来的几个步骤将展示如何安装右下角的胶带(胶带 4R),其中包括一个必须与麦克风对齐的凹口。
    • 在尝试操作之前,请通读此步骤和接下来的四个步骤。
    • 抓住条带 4R 上的红色拉片,拉动使约 2 英寸(5 厘米)的白色背胶与胶条分离。
    These steps instruct you to install the lower strips to the iMac frame first, as that is what Apple instructs their techs to do. If you have an iMac without a microphone hole, you can choose to install the lower strips onto the display first. Peel the blue tab instead of the red to expose the adhesive. Carefully place the adhesive along the bottom edge of the display. The L-bend on the adhesive should match the display contours.
    Arthur Shi - 回复
    i have no microphone hole - which is good . . . because the 4R and 4L stips must be labelled incorrectly as the L’s are on the wrong side. Also the strips don’t completely cover the bottom. And there are no holes in these strips making placement less secure. Someone certainly goofed. (Reckon I’ll use snipped off L’s to cover the open space.
    George Guess - 回复
    Ah, the L strips don’t overlap - so they’re long enuf, but they are still reversed.
    George Guess - 回复
    Die Löcher in den Klebestreifen passen nicht (mehr) zu den Löchern im Rahmen. Ich habe mich an den breiten Stellen orientiert und die Klebestreifen daran ausgerichtet. Das ging besser.
    The holes in the adhesive strips no longer match the holes in the frame. I oriented myself towards the wide areas and aligned the adhesive strips with them. That worked better.
    Stefan - 回复
  13. iMac Intel 21.5 英寸显示器胶条更换: 步骤 13 中的图像 1,3 iMac Intel 21.5 英寸显示器胶条更换: 步骤 13 中的图像 2,3 iMac Intel 21.5 英寸显示器胶条更换: 步骤 13 中的图像 3,3
    • 将剥下的白背胶底折成直角,用手指捏住折痕。
    • 这样就会露出 2 英寸的粘合剂,同时将红色标签折叠出来。
  14. iMac Intel 21.5 英寸显示器胶条更换: 步骤 14 中的图像 1,3 iMac Intel 21.5 英寸显示器胶条更换: 步骤 14 中的图像 2,3 iMac Intel 21.5 英寸显示器胶条更换: 步骤 14 中的图像 3,3
    • 麦克风孔是 中心孔,两侧有两个较大的孔。
    • 将麦克风槽口对准麦克风孔,将胶条对准底部边缘。
    • 如果你的 iMac 没有麦克风孔,请对齐胶条的右端,使 L 形弯头位于右侧垂直粘合剂旁边. L 形弯曲不应与右侧垂直胶条重叠。
    • 胶条很容易撕裂。注意不要用力过猛拉扯胶条。
    • 对齐胶条后,小心地将左侧露出的边缘固定在 iMac 上,以确保对齐。
    The strips that I received from OWC do not have a notch cut out for the microphone. The instructions advise you, for 2017 and later 21.5” iMacs, to cut about 2 inches off from the left side of the strip so you do not cover the microphone hole.
    Peter Hillman - 回复
    As far as the remaining 2 inches I cut off, I snipped off a little more on the right side to leave a small gap for the microphone and placed that small remaining part in the center where it should have been if there was no microphone, just to complete the adhesive.
    Peter Hillman - 回复
    I have done quite a few of these now. It is easier to apply the bottom strips to the Display, rather than the housing. With the Red tabs folded at 90 degrees to the adhesive. You can then remove these tabs with the display kind in place, secured by painters tape on the out side before closing it up.
    Charlie Nancarrow - 回复
    Don't make the mistake i just did - if you want to cut a notch, cut the BOTTOM 2/3rds section of the strip, not the top! :P
    Also, here's a some pics of the mic location in the 2017 retina version from iFIXit: Muffled Microphone - iMac 21.5" (mid 2017) - Following Adhesive Strips.
    Philip Sedlmair - 回复
  15. iMac Intel 21.5 英寸显示器胶条更换: 步骤 15 中的图像 1,3 iMac Intel 21.5 英寸显示器胶条更换: 步骤 15 中的图像 2,3 iMac Intel 21.5 英寸显示器胶条更换: 步骤 15 中的图像 3,3
    • 剥去胶条后面的白色背胶,露出剩余的粘合剂。
  16. iMac Intel 21.5 英寸显示器胶条更换: 步骤 16 中的图像 1,3 iMac Intel 21.5 英寸显示器胶条更换: 步骤 16 中的图像 2,3 iMac Intel 21.5 英寸显示器胶条更换: 步骤 16 中的图像 3,3
    • 用手指沿着胶条的长度从左到右划,确保胶条平直无皱,边划边向下按,将胶条粘在 iMac 上。
  17. iMac Intel 21.5 英寸显示器胶条更换: 步骤 17 中的图像 1,3 iMac Intel 21.5 英寸显示器胶条更换: 步骤 17 中的图像 2,3 iMac Intel 21.5 英寸显示器胶条更换: 步骤 17 中的图像 3,3
  18. iMac Intel 21.5 英寸显示器胶条更换, 安装屏幕: 步骤 18 中的图像 1,2 iMac Intel 21.5 英寸显示器胶条更换, 安装屏幕: 步骤 18 中的图像 2,2
    • 将显示屏轻轻放在 iMac 上,并仔细对齐。
    In my experience, it is easier to lay the Mac flat on its back, especially if you do not have a wedge, because the display will tilt up and down and you do not want that happening. With the Mac on its back, I removed all the front adhesive strips and then angled the display (not a big angle) against the chin making sure it was even on both sides. Then reconnect the video cables and gently bring the display down into the proper position. Step 23 below seems too much of a hassle to try and get the bottom adhesive strips out while the display is resting on them, and taping the bottom of the display in Step 19 also seems to be a hassle.
    Peter Hillman - 回复
  19. iMac Intel 21.5 英寸显示器胶条更换: 步骤 19 中的图像 1,2 iMac Intel 21.5 英寸显示器胶条更换: 步骤 19 中的图像 2,2
    • 使用宽胶带将显示屏底部边缘暂时固定在 iMac 机箱上。
    • 胶带可保持显示屏的对齐,并允许你安全地打开显示屏的顶部边缘,以触及到显示屏排线。
    • 不要将胶带缠绕在 iMac 背面,否则在连排线时可能会弄碎屏幕。
    Noooo!! I followed this step and promptly cracked my screen!!!! You need to be extremely careful NOT to wrap the tape around the back of the computer. These images make it look like it's wrapped around, but if you do that, you won't be able to lift the screen at all to attach the display cables. Why?!!!!!
    Mark Sandell - 回复
    Oh no! I'm so sorry to hear this! Thank you for sharing your experience—I'm going to add a warning into the step.
    Arthur Shi -
  20. iMac Intel 21.5 英寸显示器胶条更换, 测试屏幕: 步骤 20 中的图像 1,2 iMac Intel 21.5 英寸显示器胶条更换, 测试屏幕: 步骤 20 中的图像 2,2
    • 此时,最好测试一下你的修复工作,以确保你的 iMac 能正常工作,然后再将其重新封好。请按照以下三个步骤暂时重新连接显示屏排线,并在从胶条上撕下保护膜之前启动 iMac。
    • 如果你已确认 iMac 工作正常,并准备将其密封,请跳过下一步。
    • 将显示屏电源线插入主板上的插座。
    I am powering the unit back up to test all is working. Screen is black but fan is running loud. I’ve decoupled the power and confirmed both the display cables are connected. Note - I replaced both the HDD with a SSD as well as upgraded the RAM from 8GB to 16GB.
    Neil Harfert - 回复
  21. iMac Intel 21.5 英寸显示器胶条更换: 步骤 21 中的图像 1,3 iMac Intel 21.5 英寸显示器胶条更换: 步骤 21 中的图像 2,3 iMac Intel 21.5 英寸显示器胶条更换: 步骤 21 中的图像 3,3
    • 用镊子或另一只手将显示数据排线插口轻轻插入主板上的插座。
    • 确保将其直接按入插座,并完全插入。
    • 将显示屏数据线上的金属保护罩向下朝向主板固定。
    While the previous step refers to “cables,” plural, this step suggests that only the display cable needs to be reinstalled in order to test working order. In my experience (iMac 21-1/2" Retina 4K Display, late 2015), I found that I had to also reconnect the camera/microphone cable in order for the screen to work. [6/7/21]
    Gary Heurich - 回复
  22. iMac Intel 21.5 英寸显示器胶条更换: 步骤 22 中的图像 1,2 iMac Intel 21.5 英寸显示器胶条更换: 步骤 22 中的图像 2,2
    • 将显示屏装回 iMac 的后机箱。
    • 此时,请插入 iMac 电源,并测试你的修复工作,然后再继续实际密封电脑。请务必检查已移除或断开连接的硬件是否完全正常。
    • 完成后,请关闭 iMac 并拔下电源线,然后再继续。
    At this point I tested everything to make sure it worked, including the microphone. It was a bit muffled so I poked it with a pin to try and clear it. This was incredibly stupid because (a) the muffling was due to the backing which I was about to remove from the strip (b) poking with a pin broke the microphone.
    I’m not going to buy a new microphone (£72 apparently) and a new set of strips, so I’ll get an external USB microphone instead.
    But to anyone else, if the microphone sound is muffled, don’t worry!
    rjbusenet - 回复
  23. iMac Intel 21.5 英寸显示器胶条更换, 密封iMac: 步骤 23 中的图像 1,3 iMac Intel 21.5 英寸显示器胶条更换, 密封iMac: 步骤 23 中的图像 2,3 iMac Intel 21.5 英寸显示器胶条更换, 密封iMac: 步骤 23 中的图像 3,3
    • 继续之前,请确认 iMac 已关闭并拔下电源插头。
    • 确认 iMac 功能正常后,断开显示屏排线,小心地将显示屏向前倾斜。
    • 用镊子从上方伸入,然后从显示屏的底部边缘向上拉蓝色拉片,从两个底部条带上取下薄膜。
  24. iMac Intel 21.5 英寸显示器胶条更换, 重新连接显示屏排线: 步骤 24 中的图像 1,3 iMac Intel 21.5 英寸显示器胶条更换, 重新连接显示屏排线: 步骤 24 中的图像 2,3 iMac Intel 21.5 英寸显示器胶条更换, 重新连接显示屏排线: 步骤 24 中的图像 3,3
    • 最后一次重新连接显示器电源线和数据线。
    • 切记固定显示屏数据线上的金属保护壳。
  25. iMac Intel 21.5 英寸显示器胶条更换, 清除剩余的背胶: 步骤 25 中的图像 1,3 iMac Intel 21.5 英寸显示器胶条更换, 清除剩余的背胶: 步骤 25 中的图像 2,3 iMac Intel 21.5 英寸显示器胶条更换, 清除剩余的背胶: 步骤 25 中的图像 3,3
    • 检查摄像头正前方的玻璃是否有灰尘和其他污染物。如有必要,在密封显示屏前用超细纤维布擦拭。
    • 在以下步骤中取下保护膜时,用一只手稳住显示屏,或将显示屏轻轻靠在 iMac 的外壳上。
  26. iMac Intel 21.5 英寸显示器胶条更换: 步骤 26 中的图像 1,3 iMac Intel 21.5 英寸显示器胶条更换: 步骤 26 中的图像 2,3 iMac Intel 21.5 英寸显示器胶条更换: 步骤 26 中的图像 3,3
    • 垂直向上拉动胶带 01 的拉片,将其撕下。
  27. iMac Intel 21.5 英寸显示器胶条更换: 步骤 27 中的图像 1,2 iMac Intel 21.5 英寸显示器胶条更换: 步骤 27 中的图像 2,2
    • 从胶带 1 上撕下背胶的另一面。
  28. iMac Intel 21.5 英寸显示器胶条更换: 步骤 28 中的图像 1,1
    • 重复前面的步骤,撕掉所有剩余胶条上的背胶。
  29. iMac Intel 21.5 英寸显示器胶条更换: 步骤 29 中的图像 1,3 iMac Intel 21.5 英寸显示器胶条更换: 步骤 29 中的图像 2,3 iMac Intel 21.5 英寸显示器胶条更换: 步骤 29 中的图像 3,3
    • 为确保粘合牢固,请小心地将 iMac 背面平放(屏幕朝上),然后小心而用力地按压显示屏的所有四个边缘。
    • 撕下将显示屏固定到后壳的胶带。
    • 24 小时后检查显示屏,确保它在 iMac 上没有松动。
    Yo lo pongo sobre una manta con la pantalla apoyada sobre la manta.Pongo trapos o papel de cocina doblado alrededor de la pantalla y lo sujeto con pinzas de tender ropa.Lo dejo así 24 horas y queda perfecto. Saludos y gracias por el tutorial.
    JAIME GARCIA MARTINEZ - 回复
终点
70等其他人完成本指南。
由衷感谢以下译者:
en zh
95%
Yanqi Wang正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Arthur Shi
于01/03/18注册
281,611 声望
创作了584篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,409篇指南
7条评论
Useful guide, thank you very much :-)
Dariusz - 回复
Used this guide and the official iFixit strips and everything worked great, until about 6 months later when the screen fell out. I had cleaned off all dust and checked the screen 24 hours later as recommended. Is there anything I could have done better? When I reattach it with new strips I’m going to lay it upward with light pressure around the edges for 24 hours.
Grayson Lynch - 回复
I’m sorry to hear that! If you can, please contact our customer support and give them some details on where the adhesive gave out. It may have been defective strips—they can get you sorted out if that’s the case!
Arthur Shi -
In the final stage of removing the numbered tab, the blue tab for the lower portion of strip 3 cam off before revealing any of the white release film. Do you have any tips on how to remove it once it’s stuck everywhere else or is it a case of just leaving it.
Adam Court - 回复
Hey Adam! You can try inserting a needle or the point of a pair of tweezers underneath the white liner. You may be able to loosen the liner enough to grasp and remove it. Otherwise, if it's a small portion, I wouldn't worry too much about it.
Arthur Shi -
Worked perfectly. Great kit, loved the Haribo. Fantastic guys.
Kenny Gair - 回复
Thanks for the usefull guide.
I peeled of the rubber-like adhesive on the back of the display, but there stays a kind of black foil. It´s clued tight to the display all around where the rubber-like adhesive was. Do I have to peel it off, too?
Thanks!
Robert - 回复
添加评论
浏览统计数据:
过去 24 小时: 21
过去 7 天: 103
过去 30 天: 298
总计 25,730
