跳转到主内容
iMac G5 17" Model A1058 Hard Drive Replacement
Walter Galan
Walter Galan10 其他贡献者
最后更新于 March 31, 2020
10 - 20 分钟
中等
特色指南
Upgrade your hard drive for an instant increase in storage space.
你所需要的
配件
工具
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
  • TR10 Torx Security Screwdriver
查看更多...
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. iMac G5 17" Model A1058 Hard Drive Replacement, Rear Panel: 步骤 1 中的图像 1,1
    • Lay the iMac display-side down on a flat surface.
    • Loosen the three Phillips screws securing the rear panel to the iMac.
    • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
  2. iMac G5 17" Model A1058 Hard Drive Replacement: 步骤 2 中的图像 1,3 iMac G5 17" Model A1058 Hard Drive Replacement: 步骤 2 中的图像 2,3 iMac G5 17" Model A1058 Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Lift the rear panel slightly from the bottom edge of the iMac.
    • Pull the rear panel toward yourself and remove it from the iMac.
  3. iMac G5 17" Model A1058 Hard Drive Replacement, Fan Cover: 步骤 3 中的图像 1,2 iMac G5 17" Model A1058 Hard Drive Replacement, Fan Cover: 步骤 3 中的图像 2,2
    • Remove the two Phillips screws securing the fan cover to the midplane.
    • The shouldered screw belongs in the lower left corner of the fan cover.
    • Lift the fan cover up off midplane.
  4. iMac G5 17" Model A1058 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • Disconnect the hard drive thermal sensor cable from the hard drive thermal sensor.
    • During reassembly, plug in the hard drive thermal sensor before lowering your new hard drive into the midplane.
  5. iMac G5 17" Model A1058 Hard Drive Replacement: 步骤 5 中的图像 1,2 iMac G5 17" Model A1058 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Remove the three Phillips screws securing the hard drive to the midplane.
    • Lift the hard drive from its right edge and maneuver it out of the midplane.
    • The hard drive is still connected to the motherboard.
  6. iMac G5 17" Model A1058 Hard Drive Replacement: 步骤 6 中的图像 1,2 iMac G5 17" Model A1058 Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Insert the flat end of a spudger between the SATA power cable connector and the body of the hard drive.
    • Twist the spudger counter-clockwise to slightly separate the SATA power cable connector from its socket on the hard drive.
    • Pull the SATA power cable connector away from the hard drive.
  7. iMac G5 17" Model A1058 Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Pull the SATA data cable connector away from the hard drive.
  8. iMac G5 17" Model A1058 Hard Drive Replacement, Hard Drive: 步骤 8 中的图像 1,2 iMac G5 17" Model A1058 Hard Drive Replacement, Hard Drive: 步骤 8 中的图像 2,2
    • Remove the two T10 Torx screws from both sides of the hard drive (four screws total).
  9. iMac G5 17" Model A1058 Hard Drive Replacement: 步骤 9 中的图像 1,1
    • Lift the hard drive bracket off the hard drive.
    • Hard drive remains.
    • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
结论
140等其他人完成本指南。
5指南评论
I can't imagine why this disassembly is called "moderate." This has to be one of the easiest Macs to open up and gain access. Interestingly, the very next model, the 1144, is one of the most difficult and painful macs (that I know) to open up for access to the most rudimentary parts (drive and memory). The designers of the 1144+ iMacs should all be taken outside and shot!
Maybe the Quadra 700 is easier - no tools required! Or the G4 and G5 towers. Dunno about the later ones...
Boris - 回复
Awesome, thanks for helping me breathe life back into my G5, it's going to become the band computer for storing videos/recordings, as well as some mastering and whatnot.
michaelmontanez - 回复
Very easy, thank you!
MadameX - 回复
Thank you. This was fast and without pains. Now I will be able now to recover the information from a computer that did not worked at all.
Sergio Dore - 回复
This was great in helping me resuscitate my old iMac G5 and upgrade it in the process! Part of my searching for assistance revolved around what to do with the thermal sensor (mine was attached to the dead hard drive itself rather than the hard drive bracket). Luckily for me, your clear photos helped me determine I could simply pry up the thermal sensor and reattach it elsewhere (like to the hard drive bracket as depicted). Thanks!
a_karalis - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 39
过去 30 天: 133
总计 89,651
