跳转到主内容
iMac 2012-2017 SSD Replacement
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. iMac 2012-2017 SSD Replacement, Replace the hard drive with an SSD: 步骤 1 中的图像 1,3 iMac 2012-2017 SSD Replacement, Replace the hard drive with an SSD: 步骤 1 中的图像 2,3 iMac 2012-2017 SSD Replacement, Replace the hard drive with an SSD: 步骤 1 中的图像 3,3
    • Follow the remaining steps if you are replacing your hard drive with an SSD kit.
    • If your SSD enclosure looks like the first image, follow this guide instead.
    • Line up the SSD connectors with the metal enclosure's sockets.
    • Press the drive against the enclosure sockets until the SSD is firmly seated.
    • The SSD connects with the enclosure in only one direction. If the connectors don't line up, rotate the SSD and try again.
  2. iMac 2012-2017 SSD Replacement: 步骤 2 中的图像 1,3 iMac 2012-2017 SSD Replacement: 步骤 2 中的图像 2,3 iMac 2012-2017 SSD Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips screwdriver to install the four silver screws (two on each side) along the edges of the SSD to secure it to the enclosure.
  3. iMac 2012-2017 SSD Replacement: 步骤 3 中的图像 1,2 iMac 2012-2017 SSD Replacement: 步骤 3 中的图像 2,2
    • Plug the included sensor-enabled combo cable into the enclosure's port.
    • The cable is keyed to connect in only one orientation. If you can't connect the cable, rotate it 180° and try again.
  4. iMac 2012-2017 SSD Replacement: 步骤 4 中的图像 1,3 iMac 2012-2017 SSD Replacement: 步骤 4 中的图像 2,3 iMac 2012-2017 SSD Replacement: 步骤 4 中的图像 3,3
    • Peel the white liner off the back of the small temperature sensor board in order to expose the adhesive.
    • Adhere the temperature sensor board to an exposed, metal surface of the SSD, close to the SATA connector.
    • Fold the excess temperature sensor wires so that they are out of the way while you install the enclosure.
  5. iMac 2012-2017 SSD Replacement: 步骤 5 中的图像 1,2 iMac 2012-2017 SSD Replacement: 步骤 5 中的图像 2,2
    • Use a T8 driver to install the mounting pins from the old hard drive onto the sides of the enclosure.
  6. iMac 2012-2017 SSD Replacement: 步骤 6 中的图像 1,2 iMac 2012-2017 SSD Replacement: 步骤 6 中的图像 2,2
    • Attach any mounting brackets removed from the old hard drive onto the enclosure.
  7. iMac 2012-2017 SSD Replacement: 步骤 7 中的图像 1,2 iMac 2012-2017 SSD Replacement: 步骤 7 中的图像 2,2
    • Connect the iMac's combo cable to the new temperature-enabled combo cable.
  8. iMac 2012-2017 SSD Replacement: 步骤 8 中的图像 1,3 iMac 2012-2017 SSD Replacement: 步骤 8 中的图像 2,3 iMac 2012-2017 SSD Replacement: 步骤 8 中的图像 3,3
    • The images used in this step come from a 2017 iMac. Your cables may look slightly different, but the procedure remains the same.
    • Slide the SSD enclosure into the space previously occupied by the hard drive.
    • Route the cables so that they will not interfere with any other components.
    • Try to keep the cables free from any sharp bends, and route them such that they are not pinched.
结论
另外一个人完成了本指南。
Arthur Shi
于01/03/18注册
313,710 声望
创作了729篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,758篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 590
