跳转到主内容
Apple AirPort Express Base Station Power Supply Kit
正翻译步骤 34
英语
中文
步骤 34
Apple AirPort Express Base Station Power Supply Kit: 步骤 0 中的图像 1,2 Apple AirPort Express Base Station Power Supply Kit: 步骤 0 中的图像 2,2
  • Give the plastic beads a few seconds to cool, then remove them and mash them together until they form one piece.
  • The plastic beads should be fairly warm still, but their container will likely be extremely hot. Use care when removing and handling the beads.
  • Stretch the glob of plastic into a thin strip that will fill one of the gaps between the case halves.
  • Press the plastic into the crevices and smooth it out with your finger.
  • If the plastic becomes too hard to work with, you can re-apply heat to loosen the plastic.
  • Be cautious if you reheat the plastic while it's in the case. Allow cooling periods between reheating so you don't accidentally de-solder any components.
在此插入翻译
在此插入翻译
在此插入翻译
在此插入翻译
在此插入翻译
在此插入翻译
您的所有投稿皆享有基于开源创作共享许可协议(CC BY-NC-SA)著作权利
