跳转到主内容
Apple AirPort Express Base Station Power Supply Kit
正翻译步骤 9
英语
中文
步骤 9
Apple AirPort Express Base Station Power Supply Kit: 步骤 0 中的图像 1,3 Apple AirPort Express Base Station Power Supply Kit: 步骤 0 中的图像 2,3 Apple AirPort Express Base Station Power Supply Kit: 步骤 0 中的图像 3,3
  • The voltage regulator has 3 pins:
  • Pin 1: V in (5 V)
  • Pin 2: V out (3.3 V)
  • Pin 3: "Adjust"
  • Use a pair of pliers to carefully bend pin 1 down 90°, pin 3 up 90° and pin 2 up as far as possible without touching pin 3.
  • Do not worry about getting exact angles, as you will likely need to adjust the pins when you go to fit the IC to the PCB.
  • Do not repeatedly bend and unbend the pins, as repeated bending will weaken the metal and eventually cause it to break.
在此插入翻译
在此插入翻译
在此插入翻译
在此插入翻译
在此插入翻译
在此插入翻译
在此插入翻译
您的所有投稿皆享有基于开源创作共享许可协议(CC BY-NC-SA)著作权利
