跳转到主内容
加入维修社区 - 创建账户
ZTE Max XL Front-Facing Camera Replacement
你所需要的
    1. ZTE Max XL Front-Facing Camera Replacement, Front-Facing Camera: 步骤 1 中的图像 1,2 ZTE Max XL Front-Facing Camera Replacement, Front-Facing Camera: 步骤 1 中的图像 2,2
      • Before disassembly, assure the phone is powered off.
      • Use the SIM Card remover key, remove the SIM Card tray. To do this insert the key into the hole on the side of the phone near the SIM Card tray.
      询问修复机器人
      添加评论
    2. ZTE Max XL Front-Facing Camera Replacement: 步骤 2 中的图像 1,2 ZTE Max XL Front-Facing Camera Replacement: 步骤 2 中的图像 2,2
      • Apply the iOpener to the back of the phone. For instructions of how to use the iOpener, use this guide.
      • On our phone there was adhesive on the top and bottom of the phone backing, so we specifically heated these areas.
      • Do not heat the phone too much in one area - it may warp the plastic backing.
      询问修复机器人
      添加评论
    3. ZTE Max XL Front-Facing Camera Replacement: 步骤 3 中的图像 1,3 ZTE Max XL Front-Facing Camera Replacement: 步骤 3 中的图像 2,3 ZTE Max XL Front-Facing Camera Replacement: 步骤 3 中的图像 3,3
      • Start at one corner, and use the plastic opening pick from the iFixit kit to wedge underneath the plastic backing to start undoing the tabs that connect the backing to the phone. There are 3 tabs on top and bottom and 6 on each side.
      • Use extreme caution to not puncture the lithium ion battery.
      询问修复机器人
      添加评论
    4. ZTE Max XL Front-Facing Camera Replacement: 步骤 4 中的图像 1,2 ZTE Max XL Front-Facing Camera Replacement: 步骤 4 中的图像 2,2
      • Carefully undo the ribbon wire for the fingerprint scanner before full removal of the backing.
      • There are two 3.4mm JIS #00 screws that hold the wire in place, one may be under a lock sticker. Remove the screws with the JIS #00 screwdriver.
      询问修复机器人
      添加评论
    5. ZTE Max XL Front-Facing Camera Replacement: 步骤 5 中的图像 1,2 ZTE Max XL Front-Facing Camera Replacement: 步骤 5 中的图像 2,2
      • After removal of the two 3.4mm JIS #00 screws, disconnect the connector that attaches the ribbon wire from the main part of the phone.
      询问修复机器人
      添加评论
    6. ZTE Max XL Front-Facing Camera Replacement: 步骤 6 中的图像 1,3 ZTE Max XL Front-Facing Camera Replacement: 步骤 6 中的图像 2,3 ZTE Max XL Front-Facing Camera Replacement: 步骤 6 中的图像 3,3
      • Remove the nineteen 3.4mm JIS #00 screws on the perimeter of the back using the JIS #00 screwdriver.
      询问修复机器人
      添加评论
    7. ZTE Max XL Front-Facing Camera Replacement: 步骤 7 中的图像 1,3 ZTE Max XL Front-Facing Camera Replacement: 步骤 7 中的图像 2,3 ZTE Max XL Front-Facing Camera Replacement: 步骤 7 中的图像 3,3
      • Use a plastic pick between the screen and side trim battery cover to remove the screen.
      • If the SIM Card is still in place during removal of the siding, take care during removal to avoid damaging the SIM Card.
      询问修复机器人
      添加评论
    8. ZTE Max XL Front-Facing Camera Replacement: 步骤 8 中的图像 1,3 ZTE Max XL Front-Facing Camera Replacement: 步骤 8 中的图像 2,3 ZTE Max XL Front-Facing Camera Replacement: 步骤 8 中的图像 3,3
      • Now there is access to the phone's components; use the spudger to flip the metal connector to release the camera.
      • The camera itself is lightweight so take care during the removal of the connector not to lose it.
      询问修复机器人
      添加评论
    9. ZTE Max XL Front-Facing Camera Replacement: 步骤 9 中的图像 1,1
      • With the metal connector detached, the camera is fully disconnected from the phone and ready to be replaced.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Olivia Wolf
于02/15/18注册
1,400 声望
创作了5篇指南
团队
UW Stout, Team S8-G2, Ogden Spring 2018 UW Stout, Team S8-G2, Ogden Spring 2018 的会员
UWSTOUT-OGDEN-S18S8G2
4 名成员
创作了45篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 24
总计 638
