跳转到主内容
Yamaha FG-425 Guitar String Replacement
Nicole Francheska Letigio
Nicole Francheska Letigio 另一个贡献者
最后更新于 April 21, 2021
30分钟
中等
This guide will show you simple steps on how to remove and replace your dull or broken strings on a Yamaha FG-425 guitar.
A ‘dull‘ sounding guitar and a broken string are some of the common issues that every guitar player faces in their lifetime. Replacing guitar strings is an important aspect of guitar maintenance because these issues occur often. If you would like to learn more about guitar maintenance or how to replace your guitar strings, visit this Guitar World article or this GuitarLessons.org article.
你所需要的
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. Yamaha FG-425 Guitar String Replacement, Guitar String: 步骤 1 中的图像 1,3 Yamaha FG-425 Guitar String Replacement, Guitar String: 步骤 1 中的图像 2,3 Yamaha FG-425 Guitar String Replacement, Guitar String: 步骤 1 中的图像 3,3
    • Turn the tuning peg clockwise using the All-In-1 Restringing Tool’s peg winder to loosen the tension of the strings.
    • Unwind the string from the tuning post and remove the string.
    • Caution: Be careful when removing the string from the tuning post because you may hurt your fingers while doing so.
  2. Yamaha FG-425 Guitar String Replacement: 步骤 2 中的图像 1,2 Yamaha FG-425 Guitar String Replacement: 步骤 2 中的图像 2,2
    • Use the pin remover in the All-In-1 Restringing Tool to remove the pin from the bridge
    • Remove the string from the bridge hole.
  3. Yamaha FG-425 Guitar String Replacement: 步骤 3 中的图像 1,2 Yamaha FG-425 Guitar String Replacement: 步骤 3 中的图像 2,2
    • Bend the string end on the string ball.
    • Place the string into the bridge hole.
  4. Yamaha FG-425 Guitar String Replacement: 步骤 4 中的图像 1,3 Yamaha FG-425 Guitar String Replacement: 步骤 4 中的图像 2,3 Yamaha FG-425 Guitar String Replacement: 步骤 4 中的图像 3,3
    • Place the bridge pin into the bridge hole.
    • Gently pull the string while pushing the pin into the hole.
  5. Yamaha FG-425 Guitar String Replacement: 步骤 5 中的图像 1,2 Yamaha FG-425 Guitar String Replacement: 步骤 5 中的图像 2,2
    • Insert the string through the tuning post hole.
    • Pull the string about half an inch or an inch through the tuning post.
    • Ensure that the string is lined up with the nut.
  6. Yamaha FG-425 Guitar String Replacement: 步骤 6 中的图像 1,1
    • Use the All-In-1 Restringing Tool's peg winder to turn the tuning peg counterclockwise to slightly tighten the strings.
  7. Yamaha FG-425 Guitar String Replacement: 步骤 7 中的图像 1,1
    • Cut any excess strings on the tuning post using the All-In-1 Restringing Tool’s clippers.
终点
另外一个人完成了本指南。
于01/18/21注册
207 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 317
