跳转到主内容
Xiaomi Mi 2 Screen Replacement Replacement
koppie007
koppie0072 其他贡献者
最后更新于 May 7, 2024
30 - 45 分钟
简单
社区贡献指南
Hi all,
Follow this guide to replace your screen for the Xiaomi Mi A2.
Note: It’s possible that you’ll need to transfer the backplate from the screen to the new screen. For some screens you need to transfer the bracket, backplate and small parts too. This guide only shows how to replace the full screen with all the small parts on it.
New adhesive is required to attach the bracket/earpiece/earpiece dust filter again if needed.
你所需要的
工具
查看更多...
  1. Xiaomi Mi 2 Screen Replacement Replacement, Remove screws and sim card: 步骤 1 中的图像 1,3 Xiaomi Mi 2 Screen Replacement Replacement, Remove screws and sim card: 步骤 1 中的图像 2,3 Xiaomi Mi 2 Screen Replacement Replacement, Remove screws and sim card: 步骤 1 中的图像 3,3
    • Remove the 2 Pentalobe screws.
    • Remove the sim card(s) from the phone.
  2. Xiaomi Mi 2 Screen Replacement Replacement, Remove adhesive: 步骤 2 中的图像 1,3 Xiaomi Mi 2 Screen Replacement Replacement, Remove adhesive: 步骤 2 中的图像 2,3 Xiaomi Mi 2 Screen Replacement Replacement, Remove adhesive: 步骤 2 中的图像 3,3
    • Insert the opening pick in the middle of the phone.
    • The 2nd image shows you where to put the opening pick in. You'll see that the screen will get loosen. There is lightly adhesive holding the screen.
    • Now take another opening pick and slide it around the whole screen.
    • Be careful not to put the opening pick in to far! This could damage the ribbon cable inside! Just slide it carefully around the screen.
  3. Xiaomi Mi 2 Screen Replacement Replacement, Loose the screen: 步骤 3 中的图像 1,3 Xiaomi Mi 2 Screen Replacement Replacement, Loose the screen: 步骤 3 中的图像 2,3 Xiaomi Mi 2 Screen Replacement Replacement, Loose the screen: 步骤 3 中的图像 3,3
    • The screen is now loose from the phone.
    • Do not remove the screen yet! It's still attached to the motherboard with the ribbon cable!
    • Just flip the screen carefully. The cable is short so please be careful! The ribbon cable can break easily. You could also hold the screen with your hand to be sure.
  4. Xiaomi Mi 2 Screen Replacement Replacement, Remove battery holder plate: 步骤 4 中的图像 1,2 Xiaomi Mi 2 Screen Replacement Replacement, Remove battery holder plate: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    • Remove the 3 PH00 screws from the battery holder plate.
    • Now remove the battery holder plate with your tweezers carefully.
  5. Xiaomi Mi 2 Screen Replacement Replacement, Remove the screen: 步骤 5 中的图像 1,3 Xiaomi Mi 2 Screen Replacement Replacement, Remove the screen: 步骤 5 中的图像 2,3 Xiaomi Mi 2 Screen Replacement Replacement, Remove the screen: 步骤 5 中的图像 3,3
    • Now you will see multiple cables attached to the motherboard.
    • Remove the battery ribbon cable first. This will prevent the phone from turning on accidentally by pressing the button. Please remove it straight out of it's socket with your finger nail or spudger (circled red).
    • Now remove the LCD ribbon cable straight out of it's socket with your finger nail or spudger (circled green).
  6. Xiaomi Mi 2 Screen Replacement Replacement, Screen removed: 步骤 6 中的图像 1,1
    • You successfully removed the screen now!
结论
Don’t forget: It’s possible that you need to transfer the backplate and/or bracket and/or small parts! How to transfer those items are NOT included in this guide.
Note: New adhesive is required to attach the bracket/earpiece/earpiece dust filter again if needed.
6等其他人完成本指南。
koppie007
于08/22/13注册
26,800 声望
创作了9篇指南
团队
Protectors Of The Game Systems Protectors Of The Game Systems 的会员
Community
6 名成员
创作了35篇指南
4指南评论
Now how to fix it
Paro Mita - 回复
Hi!
Depends on how your new screen came in. Some of them do not have the frame where it fits in, so you need to transfer the frame from the old one.
It’s glued, so you need to heat it to detach the screen from the frame and need to glue it to the new screen. Then follow the guide in reverse order to reassemble it.
Note: The silver plate is attached to the frame, be carefull for it and also for the small parts on it.
koppie007 - 回复
This isn't a guide for the Xiaomi Mi 2/2S, please fix the title.
Ricky Cheung - 回复
Hi! This is regarding the Xiaomi Mi 2 only. Not sure if it’s applicable for the 2S. This device used in this guide is Mi 2.
koppie007 -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 56
总计 2,465
