跳转到主内容
Xbox Series X Back Panel Replacement
Carsten Frauenheim
Carsten Frauenheim3 其他贡献者
最后更新于 March 11, 2025
10 - 20 分钟
中等
Use this guide to remove or replace the back panel on an Xbox Series X.
Before you begin, completely power down and unplug all cables from your console. Remember to follow general electrostatic discharge (ESD) safety procedures while repairing your console.
你所需要的
工具
查看更多...
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. Xbox Series X Back Panel Replacement, Uncover the back panel screws: 步骤 1 中的图像 1,2 Xbox Series X Back Panel Replacement, Uncover the back panel screws: 步骤 1 中的图像 2,2
    • Before you begin, completely power down and unplug all cables from your console.
    • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
  2. Xbox Series X Back Panel Replacement: 步骤 2 中的图像 1,3 Xbox Series X Back Panel Replacement: 步骤 2 中的图像 2,3 Xbox Series X Back Panel Replacement: 步骤 2 中的图像 3,3
    • For cleaner removal, use an iOpener or hair dryer to heat the sticker.
    • Use a pair of blunt tweezers to peel back the large sticker on the back panel to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
  3. Xbox Series X Back Panel Replacement, Remove the back panel screws: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  4. Xbox Series X Back Panel Replacement, Unclip the back panel: 步骤 4 中的图像 1,3 Xbox Series X Back Panel Replacement, Unclip the back panel: 步骤 4 中的图像 2,3 Xbox Series X Back Panel Replacement, Unclip the back panel: 步骤 4 中的图像 3,3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
  5. Xbox Series X Back Panel Replacement: 步骤 5 中的图像 1,2 Xbox Series X Back Panel Replacement: 步骤 5 中的图像 2,2
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
  6. Xbox Series X Back Panel Replacement, Remove the back panel: 步骤 6 中的图像 1,3 Xbox Series X Back Panel Replacement, Remove the back panel: 步骤 6 中的图像 2,3 Xbox Series X Back Panel Replacement, Remove the back panel: 步骤 6 中的图像 3,3
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
  7. Xbox Series X Back Panel Replacement: 步骤 7 中的图像 1,3 Xbox Series X Back Panel Replacement: 步骤 7 中的图像 2,3 Xbox Series X Back Panel Replacement: 步骤 7 中的图像 3,3
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
Carsten Frauenheim
于03/10/20注册
136,248 声望
创作了371篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,540篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 53
过去 30 天: 318
总计 1,289
