跳转到主内容
Toshiba Satellite L15W-B1320 Hard Drive Replacement
Elizabeth Zapata
Elizabeth Zapata2 其他贡献者
最后更新于 January 18, 2023
5 - 10 分钟
简单
The hard drive may need replacement due to a variety of reasons such as malfunction, overuse, etc. This guide will demonstrate how to find, and remove the laptop's hard drive in order for replacement.
你所需要的
工具
  1. Toshiba Satellite L15W-B1320 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,3 Toshiba Satellite L15W-B1320 Hard Drive Replacement, Battery: 步骤 1 中的图像 2,3 Toshiba Satellite L15W-B1320 Hard Drive Replacement, Battery: 步骤 1 中的图像 3,3
    • Close the laptop and flip it over so that the base is facing upward.
    • Using the JIS #0 screwdriver tip unscrew all 10, M2X4 size screws holding down the lid.
    • Using a spudger pry the bottom lid of the laptop from the rest of the laptop.
  2. Toshiba Satellite L15W-B1320 Hard Drive Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite L15W-B1320 Hard Drive Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite L15W-B1320 Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Remove the yellow tape that connects the battery to the rest of the laptop by simply pulling it off.
    • Disconnect the indicated cable from the cable connector by gently pulling on it.
    • Lift up the battery carefully.
  3. Toshiba Satellite L15W-B1320 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,1
    • The hard drive is connected at the end of the white barcode.
    • To remove, first pull up on the end of the hard drive opposite of the barcode.
  4. Toshiba Satellite L15W-B1320 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • After pulling up on the hard drive, pull in the opposite of the direction of the white barcode.
结论
Elizabeth Zapata
于09/25/17注册
190 声望
创作了2篇指南
一条评论
Excelente tutorial... más especifico no podría ser
Muchas gracias por compartir el conocimiento..
Luis - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 9
总计 1,377
