跳转到主内容
Toshiba Satellite L15W-B1320 Hard Drive Replacement
你所需要的
  1. Toshiba Satellite L15W-B1320 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,3 Toshiba Satellite L15W-B1320 Hard Drive Replacement, Battery: 步骤 1 中的图像 2,3 Toshiba Satellite L15W-B1320 Hard Drive Replacement, Battery: 步骤 1 中的图像 3,3
    • Close the laptop and flip it over so that the base is facing upward.
    • Using the JIS #0 screwdriver tip unscrew all 10, M2X4 size screws holding down the lid.
    • Using a spudger pry the bottom lid of the laptop from the rest of the laptop.
  2. Toshiba Satellite L15W-B1320 Hard Drive Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite L15W-B1320 Hard Drive Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite L15W-B1320 Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Remove the yellow tape that connects the battery to the rest of the laptop by simply pulling it off.
    • Disconnect the indicated cable from the cable connector by gently pulling on it.
    • Lift up the battery carefully.
  3. Toshiba Satellite L15W-B1320 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,1
    • The hard drive is connected at the end of the white barcode.
    • To remove, first pull up on the end of the hard drive opposite of the barcode.
  4. Toshiba Satellite L15W-B1320 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • After pulling up on the hard drive, pull in the opposite of the direction of the white barcode.
结论
Elizabeth Zapata
于09/25/17注册
190 声望
创作了2篇指南
一条评论
Excelente tutorial... más especifico no podría ser
Muchas gracias por compartir el conocimiento..
Luis - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 12
总计 1,380
