跳转到主内容
加入维修社区 - 创建账户
Tagital T7X Screen/ Digitizer Replacement
你所需要的
    1. Tagital T7X Screen/ Digitizer Replacement, Case: 步骤 1 中的图像 1,3 Tagital T7X Screen/ Digitizer Replacement, Case: 步骤 1 中的图像 2,3 Tagital T7X Screen/ Digitizer Replacement, Case: 步骤 1 中的图像 3,3
      • Place the Tagital T7X on a sturdy surface.
      • Insert the plastic opening tool into the crack and pry open the tablet. Move the tool along the edge, while continuing to pry up the casing.
      询问修复机器人
      添加评论
    1. Tagital T7X Screen/ Digitizer Replacement, Battery: 步骤 2 中的图像 1,2 Tagital T7X Screen/ Digitizer Replacement, Battery: 步骤 2 中的图像 2,2
      • Follow the attached wires to the positive and negative connections.
      询问修复机器人
      添加评论
    2. Tagital T7X Screen/ Digitizer Replacement: 步骤 3 中的图像 1,3 Tagital T7X Screen/ Digitizer Replacement: 步骤 3 中的图像 2,3 Tagital T7X Screen/ Digitizer Replacement: 步骤 3 中的图像 3,3
      • The soldering iron can destroy components on the motherboard. Only touch the soldering iron to the solder already on the board.
      • Touch the tip of the soldering iron to the solder connecting the negative wire.
      • Pull back on the wire with the iron in place, removing it from the hot solder.
      • The solder will be melted almost instantly. There is no need to hold the iron on the solder for more than a second or two. Visit iFixit's soldering guide for more info.
      • Repeat this step for the positive wire.
      询问修复机器人
      添加评论
    3. Tagital T7X Screen/ Digitizer Replacement: 步骤 4 中的图像 1,3 Tagital T7X Screen/ Digitizer Replacement: 步骤 4 中的图像 2,3 Tagital T7X Screen/ Digitizer Replacement: 步骤 4 中的图像 3,3
      • Use the nylon spudger to pry the battery from the back of the screen. Work your way around the edges, similar to opening the casing.
      • The adhesive used to hold the battery down is very strong. Don't be afraid to use some force.
      询问修复机器人
      添加评论
    1. Tagital T7X Screen/ Digitizer Replacement, Speaker: 步骤 5 中的图像 1,3 Tagital T7X Screen/ Digitizer Replacement, Speaker: 步骤 5 中的图像 2,3 Tagital T7X Screen/ Digitizer Replacement, Speaker: 步骤 5 中的图像 3,3
      • Remove the ribbon cable on the top left corner of the mother board.
      • Gently lift the black tape up to see the ribbon cable socket.
      询问修复机器人
      添加评论
    2. Tagital T7X Screen/ Digitizer Replacement: 步骤 6 中的图像 1,3 Tagital T7X Screen/ Digitizer Replacement: 步骤 6 中的图像 2,3 Tagital T7X Screen/ Digitizer Replacement: 步骤 6 中的图像 3,3
      • Push both side buttons away from the socket by using a spudger.
      询问修复机器人
      添加评论
    3. Tagital T7X Screen/ Digitizer Replacement: 步骤 7 中的图像 1,2 Tagital T7X Screen/ Digitizer Replacement: 步骤 7 中的图像 2,2
      • Gently pull the ribbon cable away from the socket.
      • Don't be afraid to use some force for this step.
      询问修复机器人
      添加评论
    4. Tagital T7X Screen/ Digitizer Replacement: 步骤 8 中的图像 1,2 Tagital T7X Screen/ Digitizer Replacement: 步骤 8 中的图像 2,2
      • Touch the tip of the soldering iron to the solder connecting the positive (red) wire.
      • Repeat this step for the negative wire.
      • The solder will be melted almost instantly. There is no need to hold the iron on the solder for than a second or two. Visit IFixit's soldering guide for more info.
      询问修复机器人
      添加评论
    5. Tagital T7X Screen/ Digitizer Replacement: 步骤 9 中的图像 1,2 Tagital T7X Screen/ Digitizer Replacement: 步骤 9 中的图像 2,2
      • Remove the speaker from the motherboard.
      询问修复机器人
      添加评论
    1. Tagital T7X Screen/ Digitizer Replacement, Camera: 步骤 10 中的图像 1,3 Tagital T7X Screen/ Digitizer Replacement, Camera: 步骤 10 中的图像 2,3 Tagital T7X Screen/ Digitizer Replacement, Camera: 步骤 10 中的图像 3,3
      • Use a spudger to hold the cameras in place.
      • Gently pull the black tape away using your finger.
      询问修复机器人
      添加评论
    2. Tagital T7X Screen/ Digitizer Replacement: 步骤 11 中的图像 1,3 Tagital T7X Screen/ Digitizer Replacement: 步骤 11 中的图像 2,3 Tagital T7X Screen/ Digitizer Replacement: 步骤 11 中的图像 3,3
      • Remove the ribbon cable from the motherboard.
      • Use a spudger to lift the two tabs, freeing the ribbon cable from the socket.
      询问修复机器人
      添加评论
    3. Tagital T7X Screen/ Digitizer Replacement: 步骤 12 中的图像 1,3 Tagital T7X Screen/ Digitizer Replacement: 步骤 12 中的图像 2,3 Tagital T7X Screen/ Digitizer Replacement: 步骤 12 中的图像 3,3
      • Gently pull the ribbon cable away from the motherboard.
      • Don't be afraid to use some force to pull the ribbon cable.
      询问修复机器人
      添加评论
    1. Tagital T7X Screen/ Digitizer Replacement, Motherboard: 步骤 13 中的图像 1,2 Tagital T7X Screen/ Digitizer Replacement, Motherboard: 步骤 13 中的图像 2,2
      • Next we will disconnect the digitizer ribbon cable from the motherboard.
      • Using the black spudger, gently push the tabs on each side of the socket to free the ribbon cable.
      询问修复机器人
      添加评论
    2. Tagital T7X Screen/ Digitizer Replacement: 步骤 14 中的图像 1,2 Tagital T7X Screen/ Digitizer Replacement: 步骤 14 中的图像 2,2
      • Gently pull on the ribbon cable, separating it from the socket.
      询问修复机器人
      添加评论
    3. Tagital T7X Screen/ Digitizer Replacement: 步骤 15 中的图像 1,3 Tagital T7X Screen/ Digitizer Replacement: 步骤 15 中的图像 2,3 Tagital T7X Screen/ Digitizer Replacement: 步骤 15 中的图像 3,3
      • Next, we will unscrew the three PH#0 screws anchoring the motherboard into the case.
      • You will need the Phillips Screw #0 to remove the screws of the motherboard.
      • Using the screwdriver, with the PH#0 attachment, carefully unscrew the screws of the motherboard in order to remove it from the device.
      询问修复机器人
      添加评论
    1. Tagital T7X Screen/ Digitizer Replacement, Screen/ Digitizer: 步骤 16 中的图像 1,3 Tagital T7X Screen/ Digitizer Replacement, Screen/ Digitizer: 步骤 16 中的图像 2,3 Tagital T7X Screen/ Digitizer Replacement, Screen/ Digitizer: 步骤 16 中的图像 3,3
      • Insert a plastic opening tool where the screen connects with the front face of the case.
      • Use a spudger to keep the screen from falling back into the casing.
      • The screen will slide out once the connection has been nudged on three sides.
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
USF Tampa, Team 2-1, Sullivan Spring 2016 USF Tampa, Team 2-1, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S2G1
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 27
总计 1,016
