简介
您可以参考本指南更换Steam Deck的扬声器。左右两个扬声器使用同一条电线,因此需要成对更换。
注意:请在维修设备时严格遵循静电释放 (ESD) 安全程序。
你所需要的
在这个步骤中使用的工具:Magnetic Project Mat$19.95
用十字螺丝刀拆卸固定后盖的 8 颗螺丝:
四个 9.5 毫米长的粗螺纹螺丝
四个 5.8 毫米长的细螺纹螺丝
老版本的 Steam Decks: 用十字螺丝刀松开并卸下将散热器固定在主板上的两颗螺丝。
一颗3.5毫米的紧固螺丝
一颗3.4毫米的螺丝
新版本的 Steam Decks: 用十字螺丝刀松开并卸下将散热器固定到主板上的三颗螺丝:
两颗 2.9 毫米的螺丝
一颗 3.7 毫米的螺丝
为确保走线正确,将一根扬声器电缆粘合剂粘在机体的顶部边缘,在顶部留出约 3 毫米不要粘住。
使用三角撬片让粘合剂包裹在电池托盘的边缘,将其粘贴到内侧边缘。
参照步骤安装第二个电缆粘合剂,并继续重新组装。
如需重新组装你的设备,请遵照这些说明进行反向操作。
请把您的电子垃圾送到 R2或e-Stewards认证的回收处 进行回收处理。
维修结果未达预期?您可以尝试 基础故障排除流程 ,或者向 Steam Deck 社区 寻求帮助。
4等其他人完成本指南。
由衷感谢以下译者:
93%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
3条评论
Hello.
Thanks for your great doc.. I got a problem on my steam deck that the left speaker sounds louder and more clear than the right side. Tried many games and other music resourses, also checked the balance setting in desktop mode, right side seems to be a liitle weaker.
Especially the treble range is especially obviously like this.
Do you think if it Is a hardware failure? Did you ever see this ptoblem?
Thanks a lot.
Hey there,
Guess im a bit late to answer you but, the thing you are saying is a firmware issue and “not” a hardware issue. Pretty much every steam deck have this issue. I even changed my speakers hoping to fix this problem… but no.. same results. The left speaker is louder than the right one by default, for some reason. Even sometimes you will hear some crackling sound coming from only the left speaker when the volume is too loud. Idk why this firmware issue wasn’t fix yet. But anyway!
Good teardown and replacement guide! I managed to damage my speaker wire while doing something else and this made it clearer how to get that darn buried right side out and replaced. I was a bit worried at first due to just how much disassembly was needed to get to it. In the end, not difficult, just needed some patience with properly reattaching the ribbon cables and a few tips from the guide helped alot.
