跳转到主内容
Steam Deck Quick Access Button Replacement
你所需要的
  1. Steam Deck Quick Access Button Replacement, Prepare your Steam Deck for disassembly: 步骤 1 中的图像 1,3 Steam Deck Quick Access Button Replacement, Prepare your Steam Deck for disassembly: 步骤 1 中的图像 2,3 Steam Deck Quick Access Button Replacement, Prepare your Steam Deck for disassembly: 步骤 1 中的图像 3,3
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • During your repair, it can be helpful at times to lay the Steam Deck face-down into its case to protect the thumbsticks and prevent wobble.
  2. Steam Deck Quick Access Button Replacement, Remove the back cover screws: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    FixMat
    $36.95
    • Use a Phillips driver to remove the eight screws securing the back cover:
    • Four coarse thread 9.5 mm-long screws
    • Four fine thread 5.8 mm-long screws
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the snuggest into the screw head.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your Steam Deck.
  3. Steam Deck Quick Access Button Replacement, Unclip the back cover: 步骤 3 中的图像 1,2 Steam Deck Quick Access Button Replacement, Unclip the back cover: 步骤 3 中的图像 2,2
    • Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of the right grip.
    • If you're having trouble inserting your pick at the grip seam, try starting at either the top or bottom long edges first, then slide the pick towards the grip.
    • Pry up on the back cover to release it from the locking clips.
  4. Steam Deck Quick Access Button Replacement, Remove the back cover: 步骤 4 中的图像 1,3 Steam Deck Quick Access Button Replacement, Remove the back cover: 步骤 4 中的图像 2,3 Steam Deck Quick Access Button Replacement, Remove the back cover: 步骤 4 中的图像 3,3
    • Once the clips are disconnected from one edge, the rest disconnect easily.
    • Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
    • Remove the back cover.
  5. Steam Deck Quick Access Button Replacement, Uncover the hidden shield screw: 步骤 5 中的图像 1,2 Steam Deck Quick Access Button Replacement, Uncover the hidden shield screw: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • If you have a refreshed Steam Deck version with the black motherboard cover, skip this step.
    • Use a pair of tweezers to remove the piece of foil tape covering the hidden screw on the board shield.
    • If possible, try not to rip or tear this tape so it can be reused. If necessary, you can fashion a replacement by cutting a piece of aluminum foil tape to fit.
  6. Steam Deck Quick Access Button Replacement, Remove the shield screws: 步骤 6 中的图像 1,2 Steam Deck Quick Access Button Replacement, Remove the shield screws: 步骤 6 中的图像 2,2
    • Use a Phillips driver to remove the three screws securing the board shield:
    • One 3.4 mm screw
    • Two 3.7 mm screws
    • Only the two 3.7 mm screws along the left edge are present in refreshed Steam Decks.
  7. Steam Deck Quick Access Button Replacement, Remove the shield: 步骤 7 中的图像 1,3 Steam Deck Quick Access Button Replacement, Remove the shield: 步骤 7 中的图像 2,3 Steam Deck Quick Access Button Replacement, Remove the shield: 步骤 7 中的图像 3,3
    • Remove the board shield.
    • Depending on the age of your Steam Deck, this shield may stick to the thermal pads underneath.
    • During reassembly, ensure that the fan cable lays on the side of the board shield and isn't pinched underneath.
  8. Steam Deck Quick Access Button Replacement, Disconnect the battery: 步骤 8 中的图像 1,3 Steam Deck Quick Access Button Replacement, Disconnect the battery: 步骤 8 中的图像 2,3 Steam Deck Quick Access Button Replacement, Disconnect the battery: 步骤 8 中的图像 3,3
    • Grip the battery cable by its pull tab and pull it directly away from the motherboard to disconnect it.
    • Alternatively, use the flat end of a spudger or a clean fingernail to gently push the connector out of its socket, then disconnect it completely by hand.
  9. Steam Deck Quick Access Button Replacement, Unclip the right trigger: 步骤 9 中的图像 1,2 Steam Deck Quick Access Button Replacement, Unclip the right trigger: 步骤 9 中的图像 2,2
    • The right trigger will be on your left-hand side when working on the Steam Deck, as it's laying upside down.
    • The Steam Deck's triggers clip into place on two pegs on the trigger bracket, which doubles as the hinge.
    • Place the flat end of a spudger onto the inside edge of the trigger's right clip.
    • Pivot the trigger clip out, away, and up from the peg to unlatch it.
    • During reassembly, latch the outermost peg first. Once in place, push down on the trigger to latch the innermost peg, producing an audible "click" sound.
    • Check to make sure that the trigger spring is properly aligned. Test the trigger action before continuing reassembly.
  10. Steam Deck Quick Access Button Replacement, Remove the right trigger: 步骤 10 中的图像 1,2 Steam Deck Quick Access Button Replacement, Remove the right trigger: 步骤 10 中的图像 2,2
    • Remove the right trigger.
    • Take care to not lose the trigger spring. It press-fits onto a peg on the trigger's underside.
  11. Steam Deck Quick Access Button Replacement, Remove the trigger bracket screws: 步骤 11 中的图像 1,1
    • Use a Phillips driver to remove the three 5.2 mm screws securing the right trigger bracket.
  12. Steam Deck Quick Access Button Replacement, Remove the trigger bracket: 步骤 12 中的图像 1,1
    • Remove the right trigger bracket.
    • Replacement triggers require calibration to work as expected. To calibrate new triggers, follow this calibration guide.
  13. Steam Deck Quick Access Button Replacement, Disconnect the right thumbstick: 步骤 13 中的图像 1,3 Steam Deck Quick Access Button Replacement, Disconnect the right thumbstick: 步骤 13 中的图像 2,3 Steam Deck Quick Access Button Replacement, Disconnect the right thumbstick: 步骤 13 中的图像 3,3
    在这个步骤中使用的工具:
    • Use the pointed end of a spudger to lift up the small locking flap on the thumbstick cable's ZIF connector.
    • Use a pair of tweezers to slide the cable out of its connector.
    • Grip the cable by the blue pull tab, not by the cable itself.
  14. Steam Deck Quick Access Button Replacement, Remove the thumbstick screws: 步骤 14 中的图像 1,2 Steam Deck Quick Access Button Replacement, Remove the thumbstick screws: 步骤 14 中的图像 2,2
    • Use a Phillips driver to remove the three 5.2 mm screws securing the thumbstick.
    • During reassembly, you may need to hold the Steam Deck off of the work surface so it isn't resting on the new thumbstick while you tighten down the screws.
  15. Steam Deck Quick Access Button Replacement, Remove the right thumbstick: 步骤 15 中的图像 1,2 Steam Deck Quick Access Button Replacement, Remove the right thumbstick: 步骤 15 中的图像 2,2
    • Remove the right thumbstick.
  16. Steam Deck Quick Access Button Replacement, Disconnect the button board cable: 步骤 16 中的图像 1,3 Steam Deck Quick Access Button Replacement, Disconnect the button board cable: 步骤 16 中的图像 2,3 Steam Deck Quick Access Button Replacement, Disconnect the button board cable: 步骤 16 中的图像 3,3
    • Use the pointed end of a spudger to lift up the small locking flap on the button board cable's ZIF connector.
  17. Steam Deck Quick Access Button Replacement, Disconnect the interconnect cable: 步骤 17 中的图像 1,3 Steam Deck Quick Access Button Replacement, Disconnect the interconnect cable: 步骤 17 中的图像 2,3 Steam Deck Quick Access Button Replacement, Disconnect the interconnect cable: 步骤 17 中的图像 3,3
    • Use the pointed end of a spudger to lift up the small locking flap on the button board interconnect cable's ZIF connector.
  18. Steam Deck Quick Access Button Replacement, Disconnect the remaining button board cables: 步骤 18 中的图像 1,3 Steam Deck Quick Access Button Replacement, Disconnect the remaining button board cables: 步骤 18 中的图像 2,3 Steam Deck Quick Access Button Replacement, Disconnect the remaining button board cables: 步骤 18 中的图像 3,3
    • If any connectors are covered with tape, use a pair of tweezers to remove it.
    • Use the pointed end of a spudger to lift up the small locking flaps on the rest of the button board ZIF connectors. Use a pair of tweezers to slide the cables out of their connectors:
    • Disconnect the action buttons cable.
    • Disconnect the touchpad board cable.
    • Disconnect the touchpad cable.
  19. Steam Deck Quick Access Button Replacement, Disconnect the right haptics: 步骤 19 中的图像 1,3 Steam Deck Quick Access Button Replacement, Disconnect the right haptics: 步骤 19 中的图像 2,3 Steam Deck Quick Access Button Replacement, Disconnect the right haptics: 步骤 19 中的图像 3,3
    • Exercise caution when lifting this connector—pry up on the connector itself, not its housing.
    • Use the pointed end of a spudger to lift up on the haptics cable to disconnect it.
    • Alternatively, you can leave the haptics connected to the button board and flip the board up and over the edge of the shell and out of the way.
  20. Steam Deck Quick Access Button Replacement, Remove the button board screws: 步骤 20 中的图像 1,1
    • Use a Phillips driver to disconnect the four screws securing the right button board:
    • Three 5.2 mm screws
    • One 3.9 mm screw
  21. Steam Deck Quick Access Button Replacement, Remove the button board: 步骤 21 中的图像 1,2 Steam Deck Quick Access Button Replacement, Remove the button board: 步骤 21 中的图像 2,2
    • Remove the right button board.
    • Keep track of the quick access button and its membrane, as once the right button board is removed, they're no longer secured in place.
  22. Steam Deck Quick Access Button Replacement, Remove the quick access button membrane: 步骤 22 中的图像 1,2 Steam Deck Quick Access Button Replacement, Remove the quick access button membrane: 步骤 22 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to remove the quick access button membrane.
  23. Steam Deck Quick Access Button Replacement, Remove the quick access button: 步骤 23 中的图像 1,2 Steam Deck Quick Access Button Replacement, Remove the quick access button: 步骤 23 中的图像 2,2
    • Use a pair of tweezers to remove the quick access button.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
另外一个人完成了本指南。
Carsten Frauenheim
于03/10/20注册
155,526 声望
创作了439篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,648篇指南
3指南评论
My all buttons not working just touch screen,volume and power button works
Kindly guide me which thing is faulty
Bilal Ahmed - 回复
Why did I imagine just popping the back of the case off and getting right at it? lol
Can I just pay a professional to do this for me? Does someone certified offer this service?
Brandon Nebitt - 回复
Donde obtener la placa completa del lado derecho “Steam Deck L R Button Board” la Mia es de 12 pines
Wladimie - 回复
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 143
过去 30 天: 888
总计 8,994
