跳转到主内容
加入维修社区 - 创建账户
如何启用Steam Deck的电池存储模式
    1. 如何启用Steam Deck的电池存储模式, 启动到BIOS: 步骤 1 中的图像 1,1
      • 关闭你的Steam Deck电源
      • 在电源关闭之后,长按音量提升(+)键并按下电源
      • 松开所有按键
      • Steam Deck应会开机,启动到BIOS菜单。
      询问修复机器人
      添加评论
    2. 如何启用Steam Deck的电池存储模式, 启用电池存储模式: 步骤 2 中的图像 1,3 如何启用Steam Deck的电池存储模式, 启用电池存储模式: 步骤 2 中的图像 2,3 如何启用Steam Deck的电池存储模式, 启用电池存储模式: 步骤 2 中的图像 3,3
      • 在BIOS中,使用D-Pad来引导然后用A键来选中
      • 引导到Setup Utility菜单
      • 引导到Power菜单
      • 选中Battery storage mode
      • 选中Yes来确认。
      • 你的Steam Deck应会关闭电源进入电池存储模式。
      • 处于存储模式下,你的Steam Deck将不会响应点击开机键的任何操作。要退出存储模式,将充电器插入你的Steam Deck。
      添加评论
结论
要退出电池存储模式,请将你的 Steam Desk 插入充电器。
维修没有按计划进行? 尝试一些 基本故障排除,或向我们的 Steam Deck 社区寻求帮助。
取消:我没有完成这个指南。
129等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Carsten Frauenheim
于03/10/20注册
168,626 声望
创作了438篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了63,112篇指南
18指南评论
I thought that this mode is also for when you not going to use your Steam Deck for more than a week. And if so, what is the percentage of battery you should leave the Steam Deck with before putting it in storage.
Uzi Batish - 回复 分享
The help page valve provides via the device indicates not to engage the mode above 80% state of charge.
From my personal experience with other devices and the state of charge the device ships at, I'd recommend something around 50% to 60% as a desirable storage point for best battery life during long-term storage
bensmith88 - 回复 分享
You discharge below 25% before repairs and upgrades to reduce the risk should you short or physically damage the battery, but they also recommend enabling Storage Mode in order to ensure the Deck is fully powered down, to avoid damage to the electronics.
William Feely - 回复 分享
Lithium batteries usually needs to be stored at around 50% SOC, however when you want to store such a battery, you also have to keep in mind the self discharge rate, and the fact that once over-discharged (even through self discharge) a lithium based battery could be dead and should never be recharged as it could burst in flame. That's why 60-65% is a good choice, as it will allow you to store it a lot longer without reaching over discharge state.
Adrien ASESIO - 回复 分享
Help! I followed these instructions to a T and also replaced my SSD following that guide to a T and now I'm presented with this message:
"Default Boot Device Missing or Boot Failed. Insert Recovery Media and Hit any key
Then Select 'Boot Manager' to choose a new Boot Device of to Boot Recovery Media."
I don't know what any of this means and I can't find a single straight answer anywhere.
Dane H - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 83
过去 7 天: 588
过去 30 天: 2,821
总计 267,518
