跳转到主内容
加入维修社区 - 创建账户
Steam Controller (2nd Gen, 2026) Right Trigger Replacement
你所需要的
    1. Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Before you begin: 步骤 1 中的图像 1,3 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Before you begin: 步骤 1 中的图像 2,3 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Before you begin: 步骤 1 中的图像 3,3
      • Let your controller's battery drain below 25% before starting this repair.
      • Unplug all cables and accessories from the controller, including the Steam Controller Puck.
      • During your repair, it can be helpful to lay the Steam Controller on a clean, soft cloth for stabilization and to prevent scratches.
      询问修复机器人
      添加评论
    2. Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the back cover screws: 步骤 2 中的图像 1,2 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the back cover screws: 步骤 2 中的图像 2,2
      在这个步骤中使用的工具:
      TR6 Torx Security Screwdriver
      $5.99
      添加评论
    3. Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the back cover: 步骤 3 中的图像 1,2 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the back cover: 步骤 3 中的图像 2,2
      • Remove the back cover.
      询问修复机器人
      添加评论
    1. Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the battery: 步骤 4 中的图像 1,3 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the battery: 步骤 4 中的图像 2,3 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the battery: 步骤 4 中的图像 3,3
      • If your battery is swollen, take appropriate precautions. Never reinstall a swollen battery—replace it with a new one.
      • Lift the right edge of the battery to remove it.
      • During reassembly, first slide the left side of the battery into place so its connector is fully seated. Then, press the right side into place to secure it.
      询问修复机器人
      添加评论
    1. Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the mounting bracket screws: 步骤 5 中的图像 1,2 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the mounting bracket screws: 步骤 5 中的图像 2,2
      • During the rest of your repair, don't forcefully push the controller down onto your work surface—you may damage the thumbsticks and trackpads.
      • Use a T6 Torx screwdriver to remove the four 7.4 mm‑long screws securing the battery mounting bracket.
      询问修复机器人
      添加评论
    2. Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the mounting bracket: 步骤 6 中的图像 1,2 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the mounting bracket: 步骤 6 中的图像 2,2
      询问修复机器人
      添加评论
    1. Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the hinge pin: 步骤 7 中的图像 1,3 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the hinge pin: 步骤 7 中的图像 2,3 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the hinge pin: 步骤 7 中的图像 3,3
      • The right trigger will be on your left-hand side since the controller is laying upside down.
      • With one hand, fully depress the right trigger.
      • Don't let go of the trigger, or it will eject and you may lose its spring.
      • With your free hand, use tweezers to pull the hinge pin straight out and remove it.
      • During reassembly, hold the trigger down and slide the pin through both hinge holes—the pin will stop sliding once it's fully inserted. Test the trigger to ensure the pin was properly installed.
      • When correctly inserted, the pin's end will be alinged with the white rectangle on the board (labeled PIN)—there should be no wobble.
      询问修复机器人
      添加评论
    2. Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the trigger: 步骤 8 中的图像 1,3 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the trigger: 步骤 8 中的图像 2,3 Steam Controller (2nd Gen, 2026) Right Trigger Replacement, Remove the trigger: 步骤 8 中的图像 3,3
      • Remove the right trigger.
      • The spring will likely stick to the trigger's magnet.
      • If the spring stayed on its post, leave it in place.
      • During reassembly, make sure the spring goes over both of its posts (one on the controller and one on the trigger) and that the hinge holes are all aligned.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Spencer Day
于09/14/22注册
197,340 声望
创作了1,243篇指南
1指南评论
What are the lengths and diameters of the springs? Making them stiffer is what I want to do as they do feel a bit too soft.
Deividas “IHickUp” Misevicius - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 62
过去 30 天: 270
总计 1,220
