跳转到主内容
加入维修社区 - 创建账户
Spy Net Ultra Vision Goggles Microphone Replacement
你所需要的
  1. Spy Net Ultra Vision Goggles Microphone Replacement, Open the Device: 步骤 1 中的图像 1,1
    • Using the screwdriver, remove the six silver 11.4 mm Phillips #0 screws that hold the device shell in place.
    • Pull apart the back of the device, using the plastic opening tool if needed. To do this, locate the groves running along the side of the entire device and wedge it open.
    询问修复机器人
    添加评论
  2. Spy Net Ultra Vision Goggles Microphone Replacement, Un-Solder the Wiring from the Circuit Board: 步骤 2 中的图像 1,1
    • Find the connection of the red and black wires to the circuit board behind the LED screen.
    • Un-solder the wires from the board using the soldering iron.
    • Need Help Soldering? Check out 如何焊接和拆焊
    询问修复机器人
    添加评论
  3. Spy Net Ultra Vision Goggles Microphone Replacement, Un-Solder the Microphone: 步骤 3 中的图像 1,1
    • Find the connection of the red and black wires to the funnel-shaped lens cover.
    • Un-solder the wires from the microphone using the soldering iron.
    • Remove the red and black wires from the device and solder on the replacement.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
团队
USF Tampa, Team 4-5, Brown Fall 2014 USF Tampa, Team 4-5, Brown Fall 2014 的会员
USFT-BROWN-F14S4G5
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 27
总计 650
