跳转到主内容
加入维修社区 - 创建账户
Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement
你所需要的
  1. Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Open the Device: 步骤 1 中的图像 1,2 Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Open the Device: 步骤 1 中的图像 2,2
    • Remove the six silver 11.4 mm Phillips #0 screws that hold the device shell in place.
    • Pry open the device shell using the plastic opening tools if necessary. To do this, locate the groves running along the side of the entire device and wedge it open.
    询问修复机器人
    添加评论
  2. Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Remove the Foam Covering the Main Circuit Board: 步骤 2 中的图像 1,1
    • Use your fingers to peel off the foam pad that covers the main circuit board.
    • Be careful not to tear the foam pad.
    询问修复机器人
    添加评论
  3. Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Remove the Circuit Board: 步骤 3 中的图像 1,2 Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Remove the Circuit Board: 步骤 3 中的图像 2,2
    • Remove the eight black 7.2 mm Phillips #0 screws from the top of the circuit board and lift it out of its place.
    • Be careful not to put too much tension on the various wires.
    询问修复机器人
    添加评论
  4. Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Remove the MicroSD Card Reader: 步骤 4 中的图像 1,3 Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Remove the MicroSD Card Reader: 步骤 4 中的图像 2,3 Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Remove the MicroSD Card Reader: 步骤 4 中的图像 3,3
    • Remove the one black 7.2 mm Phillips #0 screw from the plastic piece that holds down the microSD card reader wires.
    • Remove the two black 7.2 mm Phillips #0 screws that hold the microSD card reader in place.
    • You should now be able to lift the microSD card reader out of place.
    询问修复机器人
    添加评论
  5. Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Remove the Camera & Display Screen Assembly: 步骤 5 中的图像 1,2 Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Remove the Camera & Display Screen Assembly: 步骤 5 中的图像 2,2
    • Remove the two black Phillips #0 screws that hold down the camera & display screen assembly.
    • Pull the camera & display screen assembly up from its slot in the device.
    询问修复机器人
    添加评论
  6. Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Detach the Screen Assembly: 步骤 6 中的图像 1,1
    • Remove the four black 7.2 mm Phillips #0 screws that hold the screen assembly in place.
    添加评论
  7. Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Remove the Lens & Filter Assembly: 步骤 7 中的图像 1,3 Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Remove the Lens & Filter Assembly: 步骤 7 中的图像 2,3 Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Remove the Lens & Filter Assembly: 步骤 7 中的图像 3,3
    • Turn the device around to the other side and lift up the screen assembly.
    • Remove the four black 7.2 mm Phillips #00 screws that hold the lens & filter assembly in place.
    • Pull the lens & filter assembly away from the circuit board.
    询问修复机器人
    添加评论
  8. Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Detach the Wires: 步骤 8 中的图像 1,2 Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Detach the Wires: 步骤 8 中的图像 2,2
    • Using the soldering iron, de-solder the various wires from the front and back of the circuit board.
    • There are three pairs of wires on the front side, along with a set of 7 leads for the main circuit board connector.
    • On the back side, there is a set of 9 leads for the microSD card connector.
    • Check out This Guide for tips on soldering and de-soldering.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
USF Tampa, Team 4-5, Brown Fall 2014 USF Tampa, Team 4-5, Brown Fall 2014 的会员
USFT-BROWN-F14S4G5
3 名成员
创作了12篇指南
2指南评论
Boa tarde , na verdade não um comentario, meu spy ney esta com defeito( LCD display)gostaria quem pode me ajudar a me fornecer outro LCD com a placa, nome da loja, site, para exportar pro Brasil.
ribeiro928 - 回复 分享
I’ve just bought one of these for £3, wondered if it’d be too risky to experiment with if I was to circuit bend it? I create visuals & if I added a couple of potentiometers to it, I’d be interested to see if I could get any wild effects from it. It’d be great if I could achieve it with this as I’d hopefully be able to save the videos too in order to put into my animations. Do you think I should avoid it, or has anyone attempted circuit bending one of these? Cheers
Neil Beil - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 38
总计 1,628
