跳转到主内容
Sony Xperia Z3 Compact Midframe Replacement
Sophia
Sophia10 其他贡献者
最后更新于 May 7, 2024
2 - 3 小时
中等
详尽分析
社区贡献指南
Replace your Sony Xperia Z3 Compact's midframe.
This involves removing the back panel and front screen, separating the main flex, reattaching it, and then reassembling.
你所需要的
配件
工具
查看更多...
  1. Sony Xperia Z3 Compact Midframe Replacement, Midframe: 步骤 1 中的图像 1,3 Sony Xperia Z3 Compact Midframe Replacement, Midframe: 步骤 1 中的图像 2,3 Sony Xperia Z3 Compact Midframe Replacement, Midframe: 步骤 1 中的图像 3,3
    • First, heat up.
    • And then place the suction cup and pull to open a gap. Insert into the guitar pick to cut the adhesive sticker under the back cover.
    • Finally, remove the back cover.
  2. Sony Xperia Z3 Compact Midframe Replacement: 步骤 2 中的图像 1,3 Sony Xperia Z3 Compact Midframe Replacement: 步骤 2 中的图像 2,3 Sony Xperia Z3 Compact Midframe Replacement: 步骤 2 中的图像 3,3
    • Disconnect the NFC flex press connector.
    • Unscrew the screws holding the black midframe in place.
    • Remove back frame.
  3. Sony Xperia Z3 Compact Midframe Replacement: 步骤 3 中的图像 1,1
    • Disconnect the battery flex cable.
  4. Sony Xperia Z3 Compact Midframe Replacement: 步骤 4 中的图像 1,3 Sony Xperia Z3 Compact Midframe Replacement: 步骤 4 中的图像 2,3 Sony Xperia Z3 Compact Midframe Replacement: 步骤 4 中的图像 3,3
    • Remove rear camera bracket.
    • Release connector, but take care not to damage the electronic components next to the connector. It is best to access the connector from the bottom (battery side), and not from the side as the picture shows.
    • Remove rear camera.
  5. Sony Xperia Z3 Compact Midframe Replacement: 步骤 5 中的图像 1,3 Sony Xperia Z3 Compact Midframe Replacement: 步骤 5 中的图像 2,3 Sony Xperia Z3 Compact Midframe Replacement: 步骤 5 中的图像 3,3
    • Release connectors and twist off screw.
  6. Sony Xperia Z3 Compact Midframe Replacement: 步骤 6 中的图像 1,3 Sony Xperia Z3 Compact Midframe Replacement: 步骤 6 中的图像 2,3 Sony Xperia Z3 Compact Midframe Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    • Remove motherboard.
    • Lift the red cover off the vibrating motor, and lift the motor with tweezers. The motor should stay attached to the cabling to the motherboard.
  7. Sony Xperia Z3 Compact Midframe Replacement: 步骤 7 中的图像 1,3 Sony Xperia Z3 Compact Midframe Replacement: 步骤 7 中的图像 2,3 Sony Xperia Z3 Compact Midframe Replacement: 步骤 7 中的图像 3,3
    • Remove headphone jack.
    • Use caution lifting the flex cables that are stuck to the midplate.
  8. Sony Xperia Z3 Compact Midframe Replacement: 步骤 8 中的图像 1,2 Sony Xperia Z3 Compact Midframe Replacement: 步骤 8 中的图像 2,2
    • Remove loudspeaker.
  9. Sony Xperia Z3 Compact Midframe Replacement: 步骤 9 中的图像 1,3 Sony Xperia Z3 Compact Midframe Replacement: 步骤 9 中的图像 2,3 Sony Xperia Z3 Compact Midframe Replacement: 步骤 9 中的图像 3,3
结论
9等其他人完成本指南。
Sophia
于03/25/14注册
43,861 声望
创作了62篇指南
4指南评论
i want to ask what is the purpose of that plastic frame that have some silver paths connecting to the main board, because i accidentally broke it and broke the one path
coleonyx1 - 回复
It is WIFI Antenna connectors
gak.vasilis.far -
I have same issue too did you fix it?
gak.vasilis.far -
This is potentially much more complicated, and fiddly, than the guide suggests - depending on where you get the midframe from, there are a number of additional parts that need moving across to the new one - specifically the rubber seals from the buttons, the small microphone channel near the bottom mic, the plastic defuser for the LED next to the headphone socket and the front camera holder. Removing the lower speaker from the midframe is likely to break it, simply down to the glue being used to hold it in. It's worth making sure you have a replacement to hand as they're fairly cheap.
Additionally to re-emphasise, be very careful with removing the mother board, the vibration motor lead is very delicate and easy to tear. Do make sure it's completely freed up before trying to remove the board!
Daniel - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 29
总计 17,025
