跳转到主内容
加入维修社区 - 创建账户
Sony Xperia Z1s Battery Replacement
你所需要的
    1. Sony Xperia Z1s Battery Replacement, Battery: 步骤 1 中的图像 1,1
      • Insert the opening pick in the crease between the rear cover and the body of the phone.
      • Pry along the edge to lift and remove the back cover.
      询问修复机器人
      添加评论
    2. Sony Xperia Z1s Battery Replacement: 步骤 2 中的图像 1,1
      • Using the T4 Torx screwdriver, remove five 5 mm screws from the panel above the battery.
      • Remove the panel by grabbing its bottom edge and lifting upwards.
      询问修复机器人
      添加评论
    3. Sony Xperia Z1s Battery Replacement: 步骤 3 中的图像 1,1
      • Use the opening pick to pry off the battery flex cable.
      询问修复机器人
      添加评论
    4. Sony Xperia Z1s Battery Replacement: 步骤 4 中的图像 1,1
      • Using the T4 Torx screwdriver, remove two 5 mm screws from the bottom corners of the battery.
      询问修复机器人
      添加评论
    5. Sony Xperia Z1s Battery Replacement: 步骤 5 中的图像 1,1
      • Firmly press the suction cup onto the battery.
      • Pull the battery out using the suction handle.
      询问修复机器人
      添加评论
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Clemson, Team 4-4, Hunter Fall 2021 Clemson, Team 4-4, Hunter Fall 2021 的会员
CLEM-HUNTER-F21S4G4
5 名成员
创作了35篇指南
1指南评论
Step 1 - The gap is too small to simply use the pick. The suction tool also did not provide a big enough gap to get the pick in. In order to get the pick in I had to heat up the back and use the suction cup in order to get the pick. Then moved the pick around the perimeter to pull of the back. The battery was attached to the back with two glue strips. I unpluged the battery ribbon cable and got the glue off using the two pull tabs that were attached to the glue.
The rest of the steps were non existent in my case. Hope this reply helps
MrKoszmaro - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 31
过去 30 天: 53
总计 712
