简介
This guide will teach you how to replace the battery for your Sony WH-1000MX5 headset. The headset uses lithium-ion batteries, which can swell.
In the event the battery looks swollen or hot to touch, stop and read this guide on how to handle a swollen battery
你所需要的
在这个步骤中使用的工具:iFixit Opening Tool$1.99
Place the edge of an iFixit opening tool under the earpad cushion.
Slide it alongside the edge of the cushion until it detaches from the rest of the headphones.
在这个步骤中使用的工具:Phillips #000 Screwdriver$5.49
Use a Phillips #000 screwdriver to remove the eight screws along the outer inside edge.
Flip the headphones to the other side and slowly lift up the back plastic cover piece.
Gently disconnect the touch sensor ribbon cable by pulling it out evenly from the main board.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
4等其他人完成本指南。
1指南评论
Hey folks, thanks for taking the time to layout this procedure. These headphones are amazing, and this really helps me get my friends onboard.
