跳转到主内容
加入维修社区 - 创建账户
Snowboard Binding Strap Replacement
你所需要的
  1. Snowboard Binding Strap Replacement, Binding: 步骤 1 中的图像 1,3 Snowboard Binding Strap Replacement, Binding: 步骤 1 中的图像 2,3 Snowboard Binding Strap Replacement, Binding: 步骤 1 中的图像 3,3
    • Release the binding straps by lifting up on the buckle and pulling towards the direction of the end of the ladder.
    • Not all binding straps will release the same way. If you are having trouble releasing your binding straps, please refer to your owner's manual.
    询问修复机器人
    添加评论
  2. Snowboard Binding Strap Replacement: 步骤 2 中的图像 1,2 Snowboard Binding Strap Replacement: 步骤 2 中的图像 2,2
    • Move the straps and the highback plate out of the way in order to have clear access to the foot pad screw.
    • The highback plate is the vertical support plate located on the heel side of the binding.
    询问修复机器人
    添加评论
  3. Snowboard Binding Strap Replacement: 步骤 3 中的图像 1,2 Snowboard Binding Strap Replacement: 步骤 3 中的图像 2,2
    • Use a #2 Phillips screwdriver to remove the panhead, 10mm wide, M4 x 12mm screw located in the middle of the foot pad.
    询问修复机器人
    添加评论
  4. Snowboard Binding Strap Replacement: 步骤 4 中的图像 1,3 Snowboard Binding Strap Replacement: 步骤 4 中的图像 2,3 Snowboard Binding Strap Replacement: 步骤 4 中的图像 3,3
    • Use a #2 Phillips screwdriver to remove the four ovalhead M6 x 12mm screws that attach the base plate of the binding to the board.
    • Lift or slide the binding off the board and set the screws aside.
    添加评论
  5. Snowboard Binding Strap Replacement, Binding Strap: 步骤 5 中的图像 1,3 Snowboard Binding Strap Replacement, Binding Strap: 步骤 5 中的图像 2,3 Snowboard Binding Strap Replacement, Binding Strap: 步骤 5 中的图像 3,3
    • Use a 5.5mm flathead screwdriver to anchor the backing bracket located on the inside of the binding.
    • Using a Phillips #2 screwdriver, unscrew the countersunk ovalhead M4 x 16mm screw connecting the heel strap ladder to the binding.
    询问修复机器人
    添加评论
  6. Snowboard Binding Strap Replacement: 步骤 6 中的图像 1,2 Snowboard Binding Strap Replacement: 步骤 6 中的图像 2,2
    • Unscrew the 10mm long thumb screw connecting the heel strap with its binding connector.
    • Pull the heel strap apart from its binding connector.
    询问修复机器人
    添加评论
  7. Snowboard Binding Strap Replacement: 步骤 7 中的图像 1,3 Snowboard Binding Strap Replacement: 步骤 7 中的图像 2,3 Snowboard Binding Strap Replacement: 步骤 7 中的图像 3,3
    • Using a Phillips #2 screwdriver, locate and unscrew the countersunk ovalhead M4 x 16mm screw holding the heel strap connector to the binding.
    询问修复机器人
    添加评论
  8. Snowboard Binding Strap Replacement: 步骤 8 中的图像 1,2 Snowboard Binding Strap Replacement: 步骤 8 中的图像 2,2
    • Flip the binding so that the bottom is accessible.
    • Using your hands, pry off the plastic bottom covering starting at the toe end.
    • The bottom may still remain attached on the heel edge. There is no need to completely remove it.
    询问修复机器人
    添加评论
  9. Snowboard Binding Strap Replacement: 步骤 9 中的图像 1,3 Snowboard Binding Strap Replacement: 步骤 9 中的图像 2,3 Snowboard Binding Strap Replacement: 步骤 9 中的图像 3,3
    • Remove the corner foam coverings by grabbing one edge and lifting up.
    • Slide out the toe strap ladder.
    询问修复机器人
    添加评论
  10. Snowboard Binding Strap Replacement: 步骤 10 中的图像 1,3 Snowboard Binding Strap Replacement: 步骤 10 中的图像 2,3 Snowboard Binding Strap Replacement: 步骤 10 中的图像 3,3
    • Using a Phillips #2 screwdriver, unscrew the button head M4 x 10mm screw holding the toe strap with its connector.
    • Slide the toe strap off of the toe strap connector.
    询问修复机器人
    添加评论
  11. Snowboard Binding Strap Replacement: 步骤 11 中的图像 1,2 Snowboard Binding Strap Replacement: 步骤 11 中的图像 2,2
    • Turn the binding on its side and slide out the toe strap connector.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Robert Torres
于01/14/14注册
214 声望
创作了2篇指南
团队
Cal Poly, Team 17-4, Forte Winter 2014 Cal Poly, Team 17-4, Forte Winter 2014 的会员
CPSU-FORTE-W14S17G4
5 名成员
创作了11篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 80
总计 51,360
