跳转到主内容
加入维修社区 - 创建账户
Skateboard Trucks Replacement
你所需要的
  1. Skateboard Trucks Replacement, Trucks: 步骤 1 中的图像 1,2 Skateboard Trucks Replacement, Trucks: 步骤 1 中的图像 2,2
    • Insert bolt hardware through the factory drilled holes from the top side of the skateboard.
    • If you have a riser and would like to install it, please reference the Wheel Bite Prevention guide.
    询问修复机器人
    添加评论
  2. Skateboard Trucks Replacement: 步骤 2 中的图像 1,1
    • Slide the truck onto the four protruding bolt hardware screws, while using your hand to prevent the screws from popping out the top of the skateboard.
    询问修复机器人
    添加评论
  3. Skateboard Trucks Replacement: 步骤 3 中的图像 1,1
    • Hand tighten the nut hardware onto all four bolts.
    询问修复机器人
    添加评论
  4. Skateboard Trucks Replacement: 步骤 4 中的图像 1,1
    • While holding the nuts on the bottom side of the skateboard in place with the 3/8" wrench, tighten the screws from the top side of the skateboard with a screwdriver. Tighten the screws in a diagonal pattern until the head of the screw sinks slightly into the grip tape.
    • Repeat steps 1 - 6 to install the second truck.
    询问修复机器人
    添加评论
结论
To uninstall your trucks, simply follow these steps in reverse order. To continue assembling your skateboard deck, see the Wheel Installation guide.
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
Cal Poly, Team 6-32, Regan Fall 2012 Cal Poly, Team 6-32, Regan Fall 2012 的会员
CPSU-REGAN-F12S6G32
5 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 37
总计 13,910
