跳转到主内容
加入维修社区 - 创建账户
Skateboard Wheel Replacement
你所需要的
  1. Skateboard Wheel Replacement, The skate board fix up: 步骤 1 中的图像 1,1
    • With a 13mm wrench, remove the axle nut located in the center of the wheel.
    • Set the axle nut aside, and remove the wheel.
    添加评论
  2. Skateboard Wheel Replacement, Remove the Bearings: 步骤 2 中的图像 1,1
    • Position the wheel at the end of the axle.
    • To remove the bearings, gently pry the wheel at a downward angle.
    • Perform this prying process on both sides of the wheel.
    • A bearing spacer should fall out once the bearings are removed.
    询问修复机器人
    添加评论
  3. Skateboard Wheel Replacement: 步骤 3 中的图像 1,1
    • Position the new wheel on a flat surface.
    • Press the bearing into the hole of the new wheel.
    • Press firmly until the bearing snaps into place. The bearing's outside edges should be flush with the inside bottom edge of the wheel.
    询问修复机器人
    添加评论
  4. Skateboard Wheel Replacement: 步骤 4 中的图像 1,1
    • Flip the wheel over.
    • Insert the bearing spacer into the back the wheel.
    询问修复机器人
    添加评论
  5. Skateboard Wheel Replacement: 步骤 5 中的图像 1,1
    • Repeat the method from Step 3 to insert a bearing into the backside of the wheel.
    • With the bearings in place, the wheel can be placed on the axle.
    询问修复机器人
    添加评论
  6. Skateboard Wheel Replacement: 步骤 6 中的图像 1,1
    • Slide one washer onto the axle.
    询问修复机器人
    添加评论
  7. Skateboard Wheel Replacement: 步骤 7 中的图像 1,1
    • Slide the wheel onto the axle.
    • The axle should go through both bearings and the bearing spacer.
    询问修复机器人
    添加评论
  8. Skateboard Wheel Replacement: 步骤 8 中的图像 1,1
    • Slide the second washer onto the axle on the outside of the wheel.
    询问修复机器人
    添加评论
  9. Skateboard Wheel Replacement: 步骤 9 中的图像 1,1
    • Tighten the axle nut firmly.
    • Do not over tighten. The wheel should spin freely.
    • Repeat steps 1-9 for the remaining wheels.
    询问修复机器人
    添加评论
结论
Once your wheels are installed, you can ride your skateboard. If you feel your wheels hitting the bottom of your deck when you are turning, you may want to refer to the Wheel Bite Prevention guide.
取消:我没有完成这个指南。
9等其他人完成本指南。
Jared Stine
于10/05/12注册
800 声望
创作了3篇指南
团队
Cal Poly, Team 6-32, Regan Fall 2012 Cal Poly, Team 6-32, Regan Fall 2012 的会员
CPSU-REGAN-F12S6G32
5 名成员
创作了6篇指南
3指南评论
Very helpful - just got a skateboard for my son and used this guide to adjust two wheels.
emvxl - 回复 分享
thanks- i needed to upgrade my enjoi wheels to ricta clouds. thanks
Kenzie Peck - 回复 分享
Great and awesome post. It is very helpful. This blog shows the importance of blog commenting. Thanks https://skatingkits.com/best-skateboard-...
Kelly Brien - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 70
总计 79,576
