跳转到主内容
加入维修社区 - 创建账户
Grip Tape Application
你所需要的
  1. Grip Tape Application, Grip Tape Application: 步骤 1 中的图像 1,1
    • Peel off the paper backing from the sheet of grip tape.
    • Make sure you do not fold or wrinkle the grip tape.
    询问修复机器人
    添加评论
  2. Grip Tape Application: 步骤 2 中的图像 1,1
    • Center the sheet of grip tape evenly over the top of the skateboard deck.
    询问修复机器人
    添加评论
  3. Grip Tape Application: 步骤 3 中的图像 1,2 Grip Tape Application: 步骤 3 中的图像 2,2
    • Starting from the very middle and moving outward, firmly press down on the grip tape while smoothing out any air bubbles that start to form.
    询问修复机器人
    添加评论
  4. Grip Tape Application: 步骤 4 中的图像 1,2 Grip Tape Application: 步骤 4 中的图像 2,2
    • Use a screwdriver to scrape along the edges of the skateboard. This will remove some of the grip around the edges making the trimming process easier on you and your equipment.
    • You can use the utility knife to cut a perpendicular line in the excess grip tape if it is resisting the screwdriver too much.
    询问修复机器人
    添加评论
  5. Grip Tape Application: 步骤 5 中的图像 1,3 Grip Tape Application: 步骤 5 中的图像 2,3 Grip Tape Application: 步骤 5 中的图像 3,3
    • Use a utility knife to begin cutting around the edge of your skateboard to remove excess grip tape.
    • Angle your knife towards the inside of the skateboard to make it easier to cut a straight line.
    • Be careful when using the utility knife and always keep it pointed away from yourself and others.
    询问修复机器人
    添加评论
  6. Grip Tape Application: 步骤 6 中的图像 1,1
    • Once you have removed all of the excess grip tape, you can use the scraps to sand the edges of your cut to smooth out any small inconsistencies.
    • Use caution when sanding as the grip tape can become heated.
    询问修复机器人
    添加评论
  7. Grip Tape Application: 步骤 7 中的图像 1,1
    • If air bubbles persist, gently use a utility knife to poke a small hole in the grip tape at the center of the bubble and press out the air.
    询问修复机器人
    添加评论
  8. Grip Tape Application: 步骤 8 中的图像 1,2 Grip Tape Application: 步骤 8 中的图像 2,2
    • After you have finished applying your grip tape, you can use a small screwdriver to poke holes where your truck hardware will be installed.
    添加评论
结论
The next logical step in the assembly of a skateboard is to install skateboard trucks, please reference the Truck Installation guide.
取消:我没有完成这个指南。
4等其他人完成本指南。
Jared Stine
于10/05/12注册
800 声望
创作了3篇指南
团队
Cal Poly, Team 6-32, Regan Fall 2012 Cal Poly, Team 6-32, Regan Fall 2012 的会员
CPSU-REGAN-F12S6G32
5 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 28
总计 8,523
