跳转到主内容
Skateboard Skateboard Trucks Replacement
你所需要的
  1. Skateboard Skateboard Trucks Replacement, Skateboard Trucks: 步骤 1 中的图像 1,2 Skateboard Skateboard Trucks Replacement, Skateboard Trucks: 步骤 1 中的图像 2,2
    • Insert bolt hardware through the factory drilled holes from the top side of the skateboard.
    • If you have a riser and would like to install it, please reference the Wheel Bite Prevention guide.
  2. Skateboard Skateboard Trucks Replacement: 步骤 2 中的图像 1,1
    • Slide the truck onto the four protruding bolt hardware screws, while using your hand to prevent the screws from popping out the top of the skateboard.
  3. Skateboard Skateboard Trucks Replacement: 步骤 3 中的图像 1,1
    • Hand tighten the nut hardware onto all four bolts.
  4. Skateboard Skateboard Trucks Replacement: 步骤 4 中的图像 1,1
    • While holding the nuts on the bottom side of the skateboard in place with the 3/8" wrench, tighten the screws from the top side of the skateboard with a screwdriver. Tighten the screws in a diagonal pattern until the head of the screw sinks slightly into the grip tape.
    • Repeat steps 1 - 6 to install the second truck.
结论
To uninstall your trucks, simply follow these steps in reverse order. To continue assembling your skateboard deck, see the Wheel Installation guide.
2等其他人完成本指南。
Cameron Nye
于10/03/12注册
79 声望
撰写一个指南
团队
Cal Poly, Team 6-32, Regan Fall 2012 Cal Poly, Team 6-32, Regan Fall 2012 的会员
CPSU-REGAN-F12S6G32
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 22
总计 13,250
