Shark Flex DuoClean Motor Replacement
简介
转到步骤 1If you need to replace the motor of your Shark Flex DuoClean, follow this guide. To remove the motor, soldering skills are required. See this guide for soldering instructions.
Open the garage door by sliding both of the release buttons away from you.
Lift off the garage door.
Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
Orient the vacuum so you are looking down at the open garage of the vacuum.
Using your right hand, rotate the top of the silver motor towards the brush roll of the vacuum so the motor fits through the opening.
6等其他人完成本指南。
7指南评论
Can this motor we test it before taking it out
craigfranz - 回复
Can this motor be tested before taking it out?
craigfranz - 回复
How do I know if the motor is burned out
