跳转到主内容
加入维修社区 - 创建账户
Screen Removal
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Screen Removal, Heat the bottom edge: 步骤 1 中的图像 1,1
    • Completely power off your device before you begin.
    • Apply a heated iOpener to the bottom edge of the device to loosen the adhesive underneath.
    • The display adhesive of the Galaxy Tab S7+ is extremely strong, and it's likely you need to reheat and reapply the iOpener several times before starting the display removal and during the removal procedure.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  2. Screen Removal, Screen removal information: 步骤 2 中的图像 1,3 Screen Removal, Screen removal information: 步骤 2 中的图像 2,3 Screen Removal, Screen removal information: 步骤 2 中的图像 3,3
    • While you're waiting for the adhesive to loosen, note the following:
    • There's a long circuit board attached to the screen that sits parallel to the bottom edge.
    • Don't insert the pick more than 2 mm to avoid damaging the circuit board.
    • This image shows an example of the display separating from the glass panel.
    • Don't insert the pick more than 3 mm to avoid damaging the display.
  3. Screen Removal, Insert an opening pick: 步骤 3 中的图像 1,3 Screen Removal, Insert an opening pick: 步骤 3 中的图像 2,3 Screen Removal, Insert an opening pick: 步骤 3 中的图像 3,3
    • Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction cup to the screen.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an opening pick into the gap between the frame and the screen.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  4. Screen Removal, Separate the bottom adhesive: 步骤 4 中的图像 1,3 Screen Removal, Separate the bottom adhesive: 步骤 4 中的图像 2,3 Screen Removal, Separate the bottom adhesive: 步骤 4 中的图像 3,3
    • Insert a new opening pick into the gap you created.
    • Slide the new pick along the bottom edge of the device towards the bottom-right corner.
  5. Screen Removal, Heat the right edge: 步骤 5 中的图像 1,1
    • Apply a heated iOpener to the right edge of the device to loosen the adhesive underneath.
  6. Screen Removal, Separate the bottom-right corner adhesive: 步骤 6 中的图像 1,3 Screen Removal, Separate the bottom-right corner adhesive: 步骤 6 中的图像 2,3 Screen Removal, Separate the bottom-right corner adhesive: 步骤 6 中的图像 3,3
    • Rotate the opening pick around the bottom-right corner of the device.
  7. Screen Removal, Separate the right adhesive: 步骤 7 中的图像 1,3 Screen Removal, Separate the right adhesive: 步骤 7 中的图像 2,3 Screen Removal, Separate the right adhesive: 步骤 7 中的图像 3,3
    • Don't insert the pick more than 3 mm to avoid damaging the components along the right edge.
    • Slide the new pick along the right edge of the device towards the top-right corner.
  8. Screen Removal, Heat the top edge: 步骤 8 中的图像 1,1
    • Apply a heated iOpener to the top edge of the device to loosen the adhesive underneath.
  9. Screen Removal, Separate the top-right corner adhesive: 步骤 9 中的图像 1,3 Screen Removal, Separate the top-right corner adhesive: 步骤 9 中的图像 2,3 Screen Removal, Separate the top-right corner adhesive: 步骤 9 中的图像 3,3
    • Rotate the opening pick around the top-right corner of the device.
  10. Screen Removal, Separate the top adhesive: 步骤 10 中的图像 1,3 Screen Removal, Separate the top adhesive: 步骤 10 中的图像 2,3 Screen Removal, Separate the top adhesive: 步骤 10 中的图像 3,3
    • Slide the new pick along the top edge of the device towards the top-left corner.
  11. Screen Removal, Heat the left edge: 步骤 11 中的图像 1,1
    • Apply a heated iOpener to the left edge of the device to loosen the adhesive underneath.
  12. Screen Removal, Separate the top-left corner adhesive: 步骤 12 中的图像 1,3 Screen Removal, Separate the top-left corner adhesive: 步骤 12 中的图像 2,3 Screen Removal, Separate the top-left corner adhesive: 步骤 12 中的图像 3,3
    • Rotate the opening pick around the top-left corner of the device.
  13. Screen Removal, Separate the left adhesive: 步骤 13 中的图像 1,3 Screen Removal, Separate the left adhesive: 步骤 13 中的图像 2,3 Screen Removal, Separate the left adhesive: 步骤 13 中的图像 3,3
    • Slide the new pick along the left edge of the device towards the bottom-left corner.
  14. Screen Removal, Separate the bottom-left corner adhesive: 步骤 14 中的图像 1,3 Screen Removal, Separate the bottom-left corner adhesive: 步骤 14 中的图像 2,3 Screen Removal, Separate the bottom-left corner adhesive: 步骤 14 中的图像 3,3
    • Rotate the opening pick around the bottom-left corner of the device.
    • At this point, the perimeter of the screen should be separated from the frame. If there's still resistance around the edges of the screen, use an opening pick to cut the adhesive again.
  15. Screen Removal, Remove the screen: 步骤 15 中的图像 1,3 Screen Removal, Remove the screen: 步骤 15 中的图像 2,3 Screen Removal, Remove the screen: 步骤 15 中的图像 3,3
    在这个步骤中使用的工具:
    • Don't try to remove the screen all the way yet; it's still connected to the frame by a flex cable.
    • With the top of the device facing you, pull the screen up and away from you like you're opening a book.
    • Rest the screen upside down and parallel to the frame before continuing.
    • Don't twist the screen or move it too far away from the frame to avoid damaging the flex cable.
    • During reassembly:
    • This is a good point to power on your tablet and test all functions before sealing it up. Be sure to power your tablet back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
    • If you're using custom-cut adhesives, follow this guide. If you're using double-sided tape, follow this guide.
  16. Screen Removal, Disconnect the display cable: 步骤 16 中的图像 1,2 Screen Removal, Disconnect the display cable: 步骤 16 中的图像 2,2
    • Use the flat end of a spudger to pry up and disconnect the display cable's press connector secured to the screen.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  17. Screen Removal: 步骤 17 中的图像 1,2 Screen Removal: 步骤 17 中的图像 2,2
    • Use tweezers, or you fingers, to hold the display cable in place.
    • Use the flat end of a spudger to pry up and disconnect the fingerprint sensor's press connector attached to the display cable.
    • Take note of the display cable's position; you will need to bend it in the same way when connecting a new screen.
  18. Screen Removal, Remove the screen: 步骤 18 中的图像 1,3 Screen Removal, Remove the screen: 步骤 18 中的图像 2,3 Screen Removal, Remove the screen: 步骤 18 中的图像 3,3
    • Remove the screen from the frame.
结论
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Tab S7+ Answers community for help.
Alex Diaz-Kokaisl
于01/16/22注册
216,864 声望
创作了1,047篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,922篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 14
总计 192
