跳转到主内容
加入维修社区 - 创建账户
Samsung Refrigerator Icemaker Assembly Replacement
你所需要的
    1. Samsung Refrigerator Icemaker Assembly Replacement, Unplug your refrigerator: 步骤 1 中的图像 1,1
      • Unplug your refrigerator before you begin your repair.
      • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
      • Condenser fan motor
      • Compressor motor and thermal overload device
      • Water supply valve assembly
      询问修复机器人
      添加评论
    1. Samsung Refrigerator Icemaker Assembly Replacement, Open the refrigerator doors: 步骤 2 中的图像 1,2 Samsung Refrigerator Icemaker Assembly Replacement, Open the refrigerator doors: 步骤 2 中的图像 2,2
      • Open both French doors for the refrigerator compartment.
      添加评论
    1. Samsung Refrigerator Icemaker Assembly Replacement, Remove the ice bucket: 步骤 3 中的图像 1,1
      • The ice bucket should be located in the upper left side of your refrigerator. It may have "Ice Master" or "Ice Max" on the outside.
      询问修复机器人
      添加评论
    2. Samsung Refrigerator Icemaker Assembly Replacement, Remove the ice bucket: 步骤 4 中的图像 1,3 Samsung Refrigerator Icemaker Assembly Replacement, Remove the ice bucket: 步骤 4 中的图像 2,3 Samsung Refrigerator Icemaker Assembly Replacement, Remove the ice bucket: 步骤 4 中的图像 3,3
      询问修复机器人
      添加评论
    3. Samsung Refrigerator Icemaker Assembly Replacement, Check the ice bucket condition: 步骤 5 中的图像 1,1
      • Check for cracks or fractures in the ice bucket and auger assembly. Replace the bucket as needed.
      • Check the gasket around the edge of the bucket. If the gasket's ripped, cracked, rolled or has become too rigid, the bucket won't seal properly and cause condensation to seep in and freeze.
      询问修复机器人
      添加评论
    1. Samsung Refrigerator Icemaker Assembly Replacement, Unfasten the cable cover panel: 步骤 6 中的图像 1,2 Samsung Refrigerator Icemaker Assembly Replacement, Unfasten the cable cover panel: 步骤 6 中的图像 2,2
      • Remove the wire harness screw securing the cable cover panel.
      询问修复机器人
      添加评论
    2. Samsung Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: 步骤 7 中的图像 1,3 Samsung Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: 步骤 7 中的图像 2,3 Samsung Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: 步骤 7 中的图像 3,3
      • Use your fingers to slide the cable cover panel towards the front of the refrigerator to unlatch it.
      • Remove the cable cover panel.
      • During reassembly, make sure this panel clips fully in place, or the ice tray won't slide in properly.
      询问修复机器人
      添加评论
    3. Samsung Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker harness: 步骤 8 中的图像 1,2 Samsung Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker harness: 步骤 8 中的图像 2,2
      • The exact configuration of the connectors may vary on your refrigerator.
      • Disconnect the left-most yellow connector:
      • Squeeze the locking tab with your fingers.
      • Rock the connector gently side to side to disconnect it.
      • Use your fingers or a screwdriver to guide the wire harness out of the wall clips.
      询问修复机器人
      添加评论
    4. Samsung Refrigerator Icemaker Assembly Replacement, Unfasten the air tunnel: 步骤 9 中的图像 1,1
      • Remove the ice maker screw securing the air tunnel flap.
      添加评论
    5. Samsung Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: 步骤 10 中的图像 1,3 Samsung Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: 步骤 10 中的图像 2,3 Samsung Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: 步骤 10 中的图像 3,3
      • A plastic clip holds the air tunnel flap in place.
      • Use a flathead screwdriver to pry and loosen the air tunnel flap from the plastic clip.
      询问修复机器人
      添加评论
    6. Samsung Refrigerator Icemaker Assembly Replacement: 步骤 11 中的图像 1,2 Samsung Refrigerator Icemaker Assembly Replacement: 步骤 11 中的图像 2,2
      • Use your fingers to pull the air tunnel flap down enough to access the internals.
      询问修复机器人
      添加评论
    7. Samsung Refrigerator Icemaker Assembly Replacement: 步骤 12 中的图像 1,2 Samsung Refrigerator Icemaker Assembly Replacement: 步骤 12 中的图像 2,2
      • Use a flathead screwdriver to gently pry the refrigerant loop down by 1–1.5 cm.
      • During reassembly, use your fingers to push the refrigerant loop back up.
      询问修复机器人
      添加评论
    8. Samsung Refrigerator Icemaker Assembly Replacement: 步骤 13 中的图像 1,3 Samsung Refrigerator Icemaker Assembly Replacement: 步骤 13 中的图像 2,3 Samsung Refrigerator Icemaker Assembly Replacement: 步骤 13 中的图像 3,3
      • A plastic clip holds the icemaker in place.
      • Use your fingers to press and release the plastic clip.
      • This clip is stiff and may require substantial force.
      询问修复机器人
      添加评论
    9. Samsung Refrigerator Icemaker Assembly Replacement: 步骤 14 中的图像 1,2 Samsung Refrigerator Icemaker Assembly Replacement: 步骤 14 中的图像 2,2
      • Pull the front edge of the icemaker assembly down slightly to loosen it.
      • Be careful not to bend the refrigerant loop too much as you pull the front edge, or you'll damage the loop.
      • Carefully slide the icemaker assembly out of its housing.
      询问修复机器人
      添加评论
    10. Samsung Refrigerator Icemaker Assembly Replacement, Removing the Ice Maker: 步骤 15 中的图像 1,2 Samsung Refrigerator Icemaker Assembly Replacement, Removing the Ice Maker: 步骤 15 中的图像 2,2
      添加评论
结论
Be sure to dry any moisture that remains in the ice room before reassembly to prevent repair failure.
Repair didn’t go as planned? Ask our Answers Community for help.
取消:我没有完成这个指南。
3等其他人完成本指南。
nicO
于04/14/15注册
15,990 声望
创作了89篇指南
团队
Team Vulcan Team Vulcan 的会员
Staff
6 名成员
创作了673篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 44
过去 7 天: 314
过去 30 天: 1,299
总计 27,547
