跳转到主内容
加入维修社区 - 创建账户
Samsung P241 Front Panel Button replacement
你所需要的
    1. Samsung P241 Front Panel Button replacement, Top Case: 步骤 1 中的图像 1,2 Samsung P241 Front Panel Button replacement, Top Case: 步骤 1 中的图像 2,2
      • You will need to be near a power source for this guide.
      • With the back of the DVD player facing you, remove the three 1 cm black screws on the right, left, and top sides using a Phillips #1 screwdriver.
      询问修复机器人
      添加评论
    2. Samsung P241 Front Panel Button replacement: 步骤 2 中的图像 1,2 Samsung P241 Front Panel Button replacement: 步骤 2 中的图像 2,2
      • Pull the top cover towards you until you can lift it up and off.
      询问修复机器人
      添加评论
    1. Samsung P241 Front Panel Button replacement, Front Panel: 步骤 3 中的图像 1,2 Samsung P241 Front Panel Button replacement, Front Panel: 步骤 3 中的图像 2,2
      • With the front of the DVD player facing you, turn the power on and eject the disc tray.
      • Press down on the disc tray with your thumbs while also pressing up with your pointer finger on the left and right edges of the silver cover. The cover should easily pop up and off the disc tray.
      • Be careful not to crack or bend the disc tray by pulling too hard.
      询问修复机器人
      添加评论
    2. Samsung P241 Front Panel Button replacement: 步骤 4 中的图像 1,3 Samsung P241 Front Panel Button replacement: 步骤 4 中的图像 2,3 Samsung P241 Front Panel Button replacement: 步骤 4 中的图像 3,3
      • To remove the front panel, lift up the clips on the bottom, left and right sides of the DVD player.
      • Be sure to have all clips lifted up at the same time otherwise it will be difficult to get the panel off.
      • If you are having trouble removing the panel, try wedging an object underneath the two clips on the bottom to keep them from falling back into place.
      询问修复机器人
      添加评论
    3. Samsung P241 Front Panel Button replacement: 步骤 5 中的图像 1,1
      • Gently remove the front panel by pulling it forward.
      询问修复机器人
      添加评论
    4. Samsung P241 Front Panel Button replacement: 步骤 6 中的图像 1,1
      • Press the eject button again to make the disc tray slide back into place.
      • Turn off the DVD player and unplug it from the wall before proceeding to further steps.
      询问修复机器人
      添加评论
    1. Samsung P241 Front Panel Button replacement, Front Panel Buttons: 步骤 7 中的图像 1,2 Samsung P241 Front Panel Button replacement, Front Panel Buttons: 步骤 7 中的图像 2,2
      • Holding the front panel so the Samsung logo is visible, rotate the panel to view the opposite side.
      询问修复机器人
      添加评论
    2. Samsung P241 Front Panel Button replacement: 步骤 8 中的图像 1,2 Samsung P241 Front Panel Button replacement: 步骤 8 中的图像 2,2
      • Locate the button panel on the inside towards what is now the right of the front panel.
      询问修复机器人
      添加评论
    3. Samsung P241 Front Panel Button replacement: 步骤 9 中的图像 1,1
      • To unjam a button, use a finger or flathead screwdriver, and firmly press against the jammed portion of the button panel.
      • Press until the button slides back into it's designated button slot.
      询问修复机器人
      添加评论
    4. Samsung P241 Front Panel Button replacement: 步骤 10 中的图像 1,1
      • If the button panel is broken, use a flathead screwdriver to pry the button panel from the back of the front panel.
      • With strong plastic adhesive, glue the new button panel into place with each button in it's designated button slot.
      • Allow the adhesive time to properly dry before pressing buttons.
      询问修复机器人
      添加评论
    5. Samsung P241 Front Panel Button replacement: 步骤 11 中的图像 1,1
      • If the button panel is not the cause of the problem, the button sensors on the motherboard need to be replaced.
      • You can refer to this guide for directions on how to solder new sensors on your motherboard if you don't want to replace the entire motherboard.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Matt Russell
于01/14/11注册
116 声望
撰写一个指南
团队
Cal Poly, Team 14-7, Forte Winter 2011 Cal Poly, Team 14-7, Forte Winter 2011 的会员
CPSU-FORTE-W11S14G7
5 名成员
创作了28篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 28
总计 1,544
