跳转到主内容
Samsung Gear Fit Motherboard Replacement
Nathan Powell
Nathan Powell5 其他贡献者
最后更新于 May 7, 2024
15 - 30 分钟
中等
特色学生指南
The motherboard of the Fit is hidden deep insde the device, but once it's revealed, removal is just a matter of disconnecting a few ribbon cables.
你所需要的
工具
查看更多...
  1. Samsung Gear Fit Motherboard Replacement, Watch Band: 步骤 1 中的图像 1,2 Samsung Gear Fit Motherboard Replacement, Watch Band: 步骤 1 中的图像 2,2
    • Place your thumbs on the ends of the screen.
    • Push the watch outward while pulling the band away from the watch.
  2. Samsung Gear Fit Motherboard Replacement, Screen: 步骤 2 中的图像 1,1
    • Heating the device with a hair dryer may warp the screen or damage the device. It it preferable to use an iOpener for this step.
    • For step-by-step instructions on using an iOpener, see the iOpener 指南.
    • Use a hair dryer, heat gun, or an iOpener to heat the Gear Fit for 1-2 minutes until it is hot to the touch.
  3. Samsung Gear Fit Motherboard Replacement: 步骤 3 中的图像 1,3 Samsung Gear Fit Motherboard Replacement: 步骤 3 中的图像 2,3 Samsung Gear Fit Motherboard Replacement: 步骤 3 中的图像 3,3
    • The screen is connected to the device by a ribbon cable on the left side with the power button facing you. Do not try to completely separate the screen from the device yet, and be careful.
    • Gently pry the screen loose using a plastic opening tool.
    • If the screen doesn't easily come loose, more heating may be required
  4. Samsung Gear Fit Motherboard Replacement: 步骤 4 中的图像 1,3 Samsung Gear Fit Motherboard Replacement: 步骤 4 中的图像 2,3 Samsung Gear Fit Motherboard Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Using tweezers as a lever, pry the inner assembly out of the external casing.
    • This will be harder than removing the screen. Moderate force may be required.
  5. Samsung Gear Fit Motherboard Replacement: 步骤 5 中的图像 1,3 Samsung Gear Fit Motherboard Replacement: 步骤 5 中的图像 2,3 Samsung Gear Fit Motherboard Replacement: 步骤 5 中的图像 3,3
    • Disconnect the ribbon cables connecting the screen to the motherboard by lifting their metal connectors up off of the board with tweezers.
  6. Samsung Gear Fit Motherboard Replacement: 步骤 6 中的图像 1,2 Samsung Gear Fit Motherboard Replacement: 步骤 6 中的图像 2,2
    • Gently peel the screen assembly up and away from the device using tweezers.
  7. Samsung Gear Fit Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,3 Samsung Gear Fit Motherboard Replacement, Motherboard: 步骤 7 中的图像 2,3 Samsung Gear Fit Motherboard Replacement, Motherboard: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    • Three ribbon cables hold the motherboard to the rest of the assembly.
    • The battery cable in the front.
    • When reassembling the device, make sure the battery cable is securely connected. Moderate force may be required to push it in all the way.
    • And two on the side.
    • Using a pair of tweezers, carefully pull each connector away to disconnect it from the rest of the assembly.
  8. Samsung Gear Fit Motherboard Replacement: 步骤 8 中的图像 1,2 Samsung Gear Fit Motherboard Replacement: 步骤 8 中的图像 2,2
    • The motherboard is a segmented three piece construction.
    • Use tweezers to first lift up, with a moderate amount of force, and free each ends of the motherboard from the assembly.
    • Be sure to use ESD safe tweezers to prevent static discharge from zapping your device.
  9. Samsung Gear Fit Motherboard Replacement: 步骤 9 中的图像 1,1
    • The motherboard should now be removable from the assembly.
    • Use tweezers to lightly pry, lift, and remove the board by its middle section.
    • If the motherboard is stuck it may be caught on the assembly. Wiggle it around to free it. You may also need to pull the edges of the assembly away from the motherboard to create space.
结论
2等其他人完成本指南。
Nathan Powell
于04/24/14注册
1,577 声望
创作了3篇指南
团队
Cal Poly, Team 11-49, Amido Spring 2014 Cal Poly, Team 11-49, Amido Spring 2014 的会员
CPSU-AMIDO-S14S11G49
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 4,285
