跳转到主内容
Samsung Galaxy Watch4 Classic Motherboard Replacement
Adriana Zwink
Adriana Zwink 另一个贡献者
最后更新于 April 3, 2025
10 - 20 分钟
中等
Use this guide to replace the motherboard on your Samsung Galaxy Watch4 Classic.
你所需要的
工具
查看更多...
  1. Samsung Galaxy Watch4 Classic Motherboard Replacement, Power down your watch: 步骤 1 中的图像 1,1
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. Samsung Galaxy Watch4 Classic Motherboard Replacement, Unscrew the back cover: 步骤 2 中的图像 1,1
    • Use a Tri-point Y00 screwdriver to remove the four 4.0 mm-long screws securing the back cover.
  3. Samsung Galaxy Watch4 Classic Motherboard Replacement, Pry open the back cover: 步骤 3 中的图像 1,2 Samsung Galaxy Watch4 Classic Motherboard Replacement, Pry open the back cover: 步骤 3 中的图像 2,2
    • Insert an opening tool into the seam between the back cover and the metal housing.
    • Twist the opening tool to create a gap.
    • Don't try to remove the back cover all the way yet. The sensor flex cable is still connected to the motherboard.
  4. Samsung Galaxy Watch4 Classic Motherboard Replacement, Disconnect the sensor flex cable: 步骤 4 中的图像 1,2 Samsung Galaxy Watch4 Classic Motherboard Replacement, Disconnect the sensor flex cable: 步骤 4 中的图像 2,2
    • Lay the watch face down.
    • Carefully swing open the back cover by folding it to the opposite site of the created gap.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
  5. Samsung Galaxy Watch4 Classic Motherboard Replacement, Remove the back cover: 步骤 5 中的图像 1,1
    • Remove the back cover.
    • Make sure the rubber gasket is undamaged. If damaged, replace it with a new one during reassembly to maintain proper water resistance.
  6. Samsung Galaxy Watch4 Classic Motherboard Replacement, Disconnect the hall sensor flex cable: 步骤 6 中的图像 1,2 Samsung Galaxy Watch4 Classic Motherboard Replacement, Disconnect the hall sensor flex cable: 步骤 6 中的图像 2,2
    • Use the pointed end of a spudger to disconnect the hall sensor flex cable.
  7. Samsung Galaxy Watch4 Classic Motherboard Replacement, Disconnect the display flex cable: 步骤 7 中的图像 1,2 Samsung Galaxy Watch4 Classic Motherboard Replacement, Disconnect the display flex cable: 步骤 7 中的图像 2,2
    • Use a spudger to disconnect the display flex cable.
  8. Samsung Galaxy Watch4 Classic Motherboard Replacement, Disconnect the side buttons: 步骤 8 中的图像 1,2 Samsung Galaxy Watch4 Classic Motherboard Replacement, Disconnect the side buttons: 步骤 8 中的图像 2,2
    • Use a spudger to disconnect the crown button flex cable.
  9. Samsung Galaxy Watch4 Classic Motherboard Replacement, Unscrew the motherboard: 步骤 9 中的图像 1,1
    • Use a Phillips screwdriver to remove the 4.4 mm-long screw securing the motherboard.
  10. Samsung Galaxy Watch4 Classic Motherboard Replacement, Remove the motherboard: 步骤 10 中的图像 1,3 Samsung Galaxy Watch4 Classic Motherboard Replacement, Remove the motherboard: 步骤 10 中的图像 2,3 Samsung Galaxy Watch4 Classic Motherboard Replacement, Remove the motherboard: 步骤 10 中的图像 3,3
    • Use your fingers to lift the motherboard out from the watch assembly towards the bottom of the watch.
    • During reassembly, make sure none of the flex cables become trapped underneath the motherbaord.
结论
If possible, turn on your device and test your repair before resealing.
Adriana Zwink
于12/18/19注册
56,693 声望
创作了167篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,632篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 82
总计 2,195
