跳转到主内容
Samsung Galaxy S6 Motherboard Assembly Replacement
Evan Noronha
Evan Noronha2 其他贡献者
最后更新于 November 7, 2022
没有估计
困难
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独使用。
Prereq to remove the motherboard.
This guide involves removing the rear glass. Removing the rear glass destroys the adhesive holding it in place. Follow this guide to reinstall the rear glass.
你所需要的
工具
  • Spudger
    Spudger
  1. Samsung Galaxy S6 Motherboard Assembly Replacement, Motherboard Assembly: 步骤 1 中的图像 1,3 Samsung Galaxy S6 Motherboard Assembly Replacement, Motherboard Assembly: 步骤 1 中的图像 2,3 Samsung Galaxy S6 Motherboard Assembly Replacement, Motherboard Assembly: 步骤 1 中的图像 3,3
    • Use the pointed edge of a spudger to disconnect the Bluetooth and Wi-Fi antenna cable connectors from their sockets on the motherboard.
  2. Samsung Galaxy S6 Motherboard Assembly Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy S6 Motherboard Assembly Replacement: 步骤 2 中的图像 2,2
    • Use the flat end of the spudger to disconnect the home button connector.
  3. Samsung Galaxy S6 Motherboard Assembly Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy S6 Motherboard Assembly Replacement: 步骤 3 中的图像 2,2
    • Use the flat end of a spudger to disconnect the display assembly cable from the motherboard.
  4. Samsung Galaxy S6 Motherboard Assembly Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy S6 Motherboard Assembly Replacement: 步骤 4 中的图像 2,2
    • Disconnect the earpiece speaker assembly cable connector from the motherboard.
  5. Samsung Galaxy S6 Motherboard Assembly Replacement: 步骤 5 中的图像 1,2 Samsung Galaxy S6 Motherboard Assembly Replacement: 步骤 5 中的图像 2,2
    • Lift the camera-side end of the motherboard to separate it from the display frame.
    • You may need to move some of the ribbon cables out of the way while you lift the motherboard. If the board is hard to lift, check that it is fully disconnected and not caught on any ribbon cables.
    • Do not fully remove the motherboard yet—it is still attached to the daughterboard via a ribbon cable on the underside of the motherboard.
  6. Samsung Galaxy S6 Motherboard Assembly Replacement: 步骤 6 中的图像 1,2 Samsung Galaxy S6 Motherboard Assembly Replacement: 步骤 6 中的图像 2,2
    • Use the flat end of a spudger to disconnect the daughterboard ribbon cable connector from its socket on the underside of the motherboard.
结论
To reassemble your device, follow these instructions in reverse order. When reinstalling the rear glass, refer to the rear glass adhesive replacement guide.
3等其他人完成本指南。
Evan Noronha
于02/05/15注册
226,252 声望
创作了168篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 908
