简介
This guide shows how to remove and replace the motherboard for a Samsung Galaxy S10e.
你所需要的
Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole in the SIM card tray.
Press firmly to eject the tray.
Turn your phone off completely before you begin this repair.
Prepare an iOpener and heat the back of the phone along the right edge for about two minutes. This will help soften the adhesive securing the back cover.
In the following steps, you'll be cutting through the adhesive securing the back cover.
As seen from the outside of the phone, you'll be slicing through the adhesive in the highlighted areas.
The adhesive is the thinnest on the right side of the phone, just below the Bixby button.
Secure a suction cup to the back cover, as close to the heated edge as possible, just under the Bixby button where the adhesive is thinnest.
Prop up the heated edge of the phone on something that is about 0.5 inches (13 mm) thick. This will angle the phone so that the opening tool is easier to insert.
Lift the back cover's right edge with your suction cup, opening a slight gap between the back cover and the frame.
This may require a significant amount of force. If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
Press the edge of an opening tool into the gap.
Remove the eight 3.9 mm Phillips screws securing the upper midframe to the phone.
Use the flat end of a spudger to pry the battery connector straight up from its socket and disconnect it.
Use a Phillips driver to remove the seven 3.9 mm screws securing the loudspeaker.
Use the flat end of a spudger to pry up and disconnect the screen connector from its motherboard socket.
Use a spudger to pry up and disconnect the front facing camera connector from its motherboard socket.
Use the point of a spudger to pry up and disconnect the fingerprint sensor connector from its motherboard socket.
Use a spudger to pry up and disconnect the headphone jack connector from its motherboard socket.
Use a Phillips driver to remove the three screws securing the motherboard:
One 3.7 mm screw above the rear-facing camera
Two 3.7 mm screws flanking the USB-C port
Use your fingers to lift the top edge of the motherboard out of the frame.
Gently pull the motherboard towards the top of the frame to release the lightly adhered USB-C port.
Remove the motherboard.
Seat the USB-C port end of the motherboard firmly against the bottom frame edge.
Lay the motherboard into the frame and make sure not to trap any connectors underneath it.
Flip the motherboard over.
Use a spudger to pry up and disconnect the two camera connectors from their motherboard sockets.
Apply a heated iOpener to the camera module for one minute to loosen the adhesive.
After you've completed the repair, follow this guide to test your repair.
9等其他人完成本指南。
4条评论
replacement mother board
Great job.
After a screen replacement (with chasis included so basically was a board replacement ) I got a really bad cell signal. Any tips about it ?
Hi Carlos,
Check if the black plastic loudspeaker assembly is fully clipped into the frame. The loudspeaker has a few silver antenna lines that connect to the motherboard with spring clips. If it doesn't make good contact, your signal may suffer.
